Question about Samsung ML-2510 Laser Printer
The copies are printed perfectly - but the page comes out with the imprint of a kind of track, as if it's being squeezed [about 1 inch from each side] running the length of the paper.
    Problem Solver:
  • 11 Answers
You will have to replace your OPC drum. You can buy one from third party sellers cheaply ($3.00 on average).
Posted on Jul 31, 2010
MY canon iR3035 ccd scanner position is faulty..
Re: canon ir 3035 copy not lined up 1/4 inch higher it scans but configuration page i
service mode > copier > adjust > adjust xy > adjust Y input the value from the label on the front cover
This is all I could find. Try adjusting by 1/4 inch. Thank you Santosh
Jun 25, 2016 | Canon imageRUNNER 3035 Black and White...
My lq 2180 printer is not aligned properly.printing starts 2 to 3 inches from start of page.jump in every next page is increased by half inch.kindly guide Thanks
Dear user,
please check the paper size and the procedure is below.
open printer properties and then go to the printing preferences and then there slect there appropriate paper size according to your paper being used in printer.
hopefully it will work perfect.
Sep 03, 2009 | Epson LQ-2180 Dot Matrix Printer
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer squeezes Web pages to left side of page and cuts lines
I found that the print margins on my browser were set incorrectly--four inches in on the right. I don't know how they got that way, and I found it only by looking at every possible setting on the browser. Thanks for your service, and I'll try it again if I ever need it.
Jun 02, 2009 | HP Office Equipment & Supplies
Printing Problem
My first copy comes perfect second copy the yellow color is getting shake
Nov 20, 2008 | Xerox DocuColor 12 Printer
Copying with page feed results in a vertical line on every page
There must be a strip of glass about one inch wide, next to
the large glass. There is the problem !
Clean that strip thourougly. When you use the feeder the pages
are scanned thru the small strip of glass.
Mar 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
After replacing my color cartridge my printer won't print in color. but it will copy color pages perfectly.
When you go to print from IE check the prefrences and see if it is set to Monochrome. It should be under the Advanced tab.
Mar 12, 2008 | Computers & Internet
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
Samsung ML-2510 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
