Question about Maytag Washing Machines
Water sloshing over top of washing machine tub.
Maytag top load washing machine LAT9606AAE will go into a slow rotation while agitating. This causes water to slosh over the top of the tub. Does the brake unit need to be replaced? Do I need a puller to remove the brake unit?
  • kvoigts Sep 14, 2010
    The brake unit was the culprit. I had to order a special wrench to remove the unit.
    For $18.95 plus shipping you can order from NIS, Inc. 242 East 90th Street, Davenport, IA
    Call them up and ask for part number 038315. They had 300 in stock when I ordered.
    Phone: (563) 285-6123
    Fax: (563) 285-6150
    E-mail: contact@nisia.com
I have the same problem model lat5006 still no answer
Posted on Sep 12, 2010
Agator not spinning
There is no belt on that unit. It is a direct drive machine. When the unit goes into the wash cycle, does the motor run but it does not agitate?
Nov 28, 2012 | Maytag MVWC400XW Centennial 27" Top-Load...
Unbalance when spinning
Unauthorized water gets into the tub ring. Sloshes about and cause unbalanced load even if nothing is in the washer. Rich mans solution: replace inner tub. poor mans solution: drill holes, drain water.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 18, 2010 | Maytag Bravos MTW6600T Top Load Washer
This is for an LW7503W2B washer. We have water on the floor during agitate with large loads. The water is comming over the edge of the tub. I have noticed the tub rotates in what I would call a slow...
I had the same problem. You need a brake kit. it holds the drum still while in the agitate mode. the centrifical force of the water during that slow spin is causing the water to spill over the top of your drum. easy and cheap fix.
Oct 18, 2010 | Amana ALW780QA
Maytag Legacy Series Top Load Washer model SAV515DAWW splashing
the agitator dogs are likely broken.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Maytag Legacy Series Top Load Washer
Washer fills with water, but does not agitate or spin rinse
This could be bad door switch or bad timer. You need to test it with a multimeter
Mar 31, 2009 | Whirlpool LHW0050PQ Front Load Washer
PAVT920AWW Noise in wash cycle no agitation
Your Belt still needs replacing or to be scuffed up with sand paper. If thes fails you need either new tub bearings or a transmission. either a 250-300.00 repair so tr the belt and rotate drain pump rotation while the belt is off
Mar 29, 2009 | Maytag PAV2300 Top Load Washer
Washer won't drain completely
water sond when tub is spun by hand is normal. there will always be wa terinside machine betwen tubs, maytag even uses a waterfilled tub ring for counter balance, totlly normal to hear. as far as mildew smells, use www.affresh.com
Apr 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
198 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
