Question about Compaq Presario CQ60-220US PC Laptop
Add more memory
To speed up loading i have cq206-206 us notebook pc i have no owners mannuel to understand all the plugs on the unit THANKS
    President:
  • 2,600 Answers
This is the link to the PDF file for the laptop tour and guide. If you do not have the PDF file reader Adobe Reader, the link is below this one. Copy and paste the entire link into your web browsers address bar.
http://h10032.www1.hp.com/ctg/Manual/c01540485.pdf
shortcut to Adobe Reader
http://h10025.www1.hp.com/ewfrf/wc/adobeLeavingHP?lc=en&dlc=en&cc=us&lang=en&product=3872070&
Posted on Jul 31, 2010
CAN I INSTALL DDR2 MEMORY OR DO I HAVE TO USE THE DDR TYPE FOR HP PAVILION DV5215US
Your unit uses:
DDR memory with support for DDR PC3200, DDR PC2700 speeds.
Because DDR memory is backward-compatible, you can safely upgrade your system with any of the guaranteed-compatible DDR speeds listed below, even if your manual calls for PC1600 or PC2100 speeds.
Each memory slot can hold DDR PC3200, DDR PC2700 with a maximum of 1GB per slot.*
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 27, 2010 | HP Pavilion dv5215 Notebook
How can increase memory/speed on my Acer notebook? What is 'FAT 32'?
memory is a hardware upgrade which usually plugs in into the bottom of the laptop. If you look on the bottom you will see a couple doors that unscrew and, but depending on the laptop you will be limited to how much you memory you can add. Also since you are asking about fat32 I will assume your laptop is at least 6 years old (FAT32 is the format of the hard drive, old DOS used FAT, when Microsoft released windows 95, it made options for bigger hard drives called FAT32, then with the release of Windows NT and later Windows machine use a hard drive format called NTFS. NTFS is still the current disk format even with windows 7) NTFS is more secure and can handle very large hard drives. If you let me know what ACER you have I can let you know how much memory you can add.
I’m happy to help further over the phone at https://www.6ya.com/expert/thomas_b83e841f114394f4
Nov 29, 2010 | Acer Aspire One PC Notebook
Hello, my pc has a CPU with 2.00 GHz and 1.12 GB of RAM, if I add another memory card of 1 gb for a total of 2.00 gb ram, this will increase the speed ?, thanks for you help
it would not increase speed as far as cpu speed,but it would make loading of things like programs and the loading of the OS faster.you would notice a difference.
Oct 22, 2010 | Dell Optiplex GX60 PC Desktop
How do yo get to the memory and can I add 1GB to the existing1!GB or do I have to purchase a 2 GB memory...thanks
Most laptops have 2 memory slots, if you have 1 Gb of RAM using two 512 Mb RAM then you need to replace them with two 1 Gb RAM modules. If you have one RAM module 1 Gb then you only need to add another 1 Gb RAM module. Try to use the same make and speed RAM.
Aug 19, 2010 | Acer Aspire One A150-1006 Notebook
Maximize my laptops memory and speed
See if you can "Upgrade" the processor would be one way... Maybe upgrade to a 64 bit OS. The rest you have already done. a large, fast/big cache, high speed Hard Drive.
Mar 05, 2010 | HP Pavilion tx1000z Notebook
What can I do to make my notebook faster? Thanks.
Hello Sir/maam, most notebook are usually upgradeable, there are several ways to speed up the performance:
  • replace or upgrade to a higher existing memory, the upgrade usually increases the performance to about 10%.
  • always defragand check for bad sectors on your hard drive every month.
  • do not load softwares that are not necessary or softwares that you may not use regularly.
  • run a virus scan program regularly.
Sep 27, 2009 | Samsung T10 XVC Notebook
I have a dv9730 with 2 1gb 5300 667mhz ram. can i
Generally speaking, you can add memory with a higher bus speed rating but it will run at a lower speed if it is used with lower speed memory or if the motherboard uses a lower speed bus. The default is always to the lowest speed.
Aug 14, 2009 | HP Pavilion dv9700t Notebook PC
How to add extra memory card in the mother board
well u may upgarde your ram to 1 or 1.5 GB if less ... and try installing Windows 7 on your computer i can tell you how to download or if you already have ... then the speed will not bother you any more...
Jun 23, 2009 | Dell Dimension™ B110 PC Desktop
Compaq lap top presario f700 won't do any thing
try taking the hard drive and memory cards out then turning the computer back on without hard drive and memory cards for 1 minute then power it off (unplug it ) then put the memory cards in only then plug cord in turn unit on for 1-3 minutes then power down (unplug it) then add hard drive make sure there is no power going to the computer when adding the hard drive to the unit. at this point do let the unit set for 8 hours then try rebooting it should restore itself. if this don't work sorry there is a limit for what I $hare online.
May 12, 2009 | Compaq Presario 700 470024-192 Notebook
Slow RT on loading new site or new page
Hi Jean,
sounds like you might need to add more memory to your PC. A fast Internet connection won't make a slow machine run any faster. If you right click on My Computer and choose properties, the box that comes up should tell you how much memory you currently have. If it's 512mb or less, that's a good indication that that is the problem.
Apr 18, 2008 | Dell Dimension 2400 PC Desktop
Compaq Presario CQ60-220US PC Laptop Logo
53 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
