Question about Amana ARGS7650SS Gas Kitchen Range
Door lock is stuck on
I tried to clean an oven I bought recently. It came up with "door" and then F9 indicating that the door was not closed. After various attempts I now realize that the door lock appears to be in the locked position and is preventing the door from closing now (the light stays on). I have cycled power and tried to manually move to lock out of the way in both the powered and unpowered mode to no avail.
    Genius:
  • 1,478 Answers
Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
Take care.
Posted on Jul 31, 2010
  • francis227 Jul 31, 2010
    Thanks for the advice. I have since made some calls and I think I am beyond simple solutions. The door lock is stuck out and the door is open. Based on the service persons advice I tried starting a cleaning cycle while holding in the door closed sensor; this makes the lock mechanism do a slow circular dance but never retracts. Sounds like a relay board issue. Thanks for the help, though.
Oven Lock stuck open before start of self-cleaning cycle I get a code F9, a flashing lock light, a continous beep and a dr code on the panel when I try to set self-cleaning cycle again.
Thank you for your inquiry, Lucie!
From what you have described your Frigidaire oven lock is stuck open and you are receiving error codes "F9" and "DR". The "F9" error code stands for runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. The "DR" code means that the door is not closed or the door latch is not recognizing the door is closed. This could be an issue with your door latch or control panel. If the reset does not help correct your issues I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
Apr 30, 2015 | Frigidaire Stove/Oven/Range Black Glass...
F9 door will not lock to self clean. Is there any way that we could test anything/hold door closed to help clean/take door off oven and re-install?
The "F9" fault code is indicating the control has detected a problem with the Door Latch Motor assembly (key#89) or latch motor circuit. The door latch motor and door latch switches will need to be checked. The door must be closed in order for the door switch to energize. Try pushing inwards on the door and keep tension on it while starting a clean cycle.
Apr 17, 2011 | Amana ARGS7650SS Gas Kitchen Range
I tried to "clean" the oven and only got a F9
The F9 error code indicates a problem with the oven door lock assembly. The door lock assembly will need to be checked and replaced if defective. If the door lock assembly is okay, then the electronic oven control board will need to be replaced.
Feb 07, 2011 | Maytag Ovens
Get message F9 on the display, I went to clean the oven in the self cleaning mode, heard the door latch trying to close, then it started beeping and flashing the F9 on the display. I turned off power for...
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 17, 2010 | Kenmore 95592 / 95594 / 95595 / 95599...
Cleaning Kenmore double ovens back to back. During second cleaning got F9 code and the bottom oven is locked. Cleared the F9 will the bottom oven unlock when it cools down?
Jan 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
F9 Flashing on Frigidaire 30" range
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Dec 31, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door locked, F9 indicator signal
F9 has to do with the door lock/latch monitoring switch, i would try to remove the oven for mthe counter andremove the back panel, in the approximate hieght levle of hte top of the lower oven mounted to the right side( standing behind) unit youll find a small lacth / motor assy, that drivesthe self clean latch, WITH POWER TURNED OFF> i wouldlook closely at the switch mounted to the assembly make sure its not out of line , (perhaps twiste doff to the side, not making contact, or something else real obvious.. definalty related ti a faulty read of that switch .chances are it got 2 hot and distortred teh mounting and/or function of that part.. worth a try any way good luck!
Nov 27, 2008 | Kitchen Ranges
Self Cleaning error F9
Oct 21, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven will not clean
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$%$^%#$
Apr 26, 2007 | Frigidaire PLCS389DC Dual Fuel (Electric...
F9 code
I hit the same F9 problem when trying to self-clean, except that the door was locked OPEN.
After much trial and error, I found the following fix: 1. Switch circuit breaker off. 2. Switch circuit breaker on. 3. Press Bake button. 4 Press the small/inside button which indicates that the oven door is closed.
The lock mechanism opened and the oven now works fine.
Nov 22, 2006 | Amana AOCS3040 Electric Single Oven
Amana ARGS7650SS Gas Kitchen Range Logo
119 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Ismael Rodriguez...
Oloyede Monsuru
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
