Question about Microwave Ovens
GE advantium SCA2001FSS
My Advantium turntable rotates only intermittently. I suspect the motor or a partially broken ceramic square shaft that extends up from the motor at the bottom of the unit into the oven itself that the turntable assembly sits on. I've looked for a part schematic in order to identify parts that may need to be replaced with no luck. Any help here? It is a 220V 1100-1200 watt oven. Model no. SCA2001FSS 02
Thanks
  • Microwave Ovens Master
  • 9,098 Answers
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 02, 2008
GE Advantium Oven stopped working
Could be an open internal fuse, magnetron, or control board failure
Aug 29, 2017 | GE Microwave Ovens
Turntable does not turn, Replaced Rotating ring assembly still not turning?
It may be the servo motor that powers the turntable or the belt has snapped or come off. It is unlikely that you can get to the motor as the case is fitted with security screws. If so, you will need to take it to a service engineer.
Mar 18, 2016 | GE Advantium 120 Convection/Microwave Oven
Why is my GE Advantium SCA2001 blowing the main fuse?
Yeah pal, you've not gone deep enough yet. You'll find a power wire bare inside the unit, pull it apart and tape that wire up to stop it from grounding out and blowing the fuse.
Aug 31, 2014 | GE Microwave Ovens
I have a GE profile advantium oven 120 that is just over 1 year old the turntable rotates but as soon as I put on the glass or mental tray it will not rotate what is the problem?
Either the coupler is cracked, the motor is defective, or the turntable support ("rotating ring asm") is worn or defective.
The service manual is here and you can find links to helpful exploded view diagrams and order parts here.
Sep 26, 2011 | GE Advantium 120 Convection/Microwave Oven
Replace fuse on GE Advantium Speedcooker Oven
there is a fuse located underneath the outer cover, its called a ceramic fuse and is of cartridge type about 1" long by 1/8" diameter and has a white body and 2 silver ends and you can take it to a hardware store they have them but make sure to get correct amperage rating 15 or 20 amp
Sep 05, 2009 | GE Advantium 120 Convection/Microwave Oven
My turntable will not rotate. I've checked the piece underneath and it appears to on correctly.
it could be be bad turntable motor.to chk this open up the bottom plate by removing the screws around it.then disconnect the wire connector from the motor.start the unit and chk the voltage with multimeter.if u read voltage then motor needs to be replaced.make sure turntable function is on and not off at the control.if there is no power at the connector then it could be control.chk for any loose wires etc.
Aug 16, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Advantium Microwave: No rotation
The screw heads on rear of GE microwave is special, what do i need to ask for to remove them.
Thanks Gayle
Mar 29, 2009 | GE Advantium 120 Convection/Microwave Oven
Arcing
My Advantium was arching at the turntable. Replaced the turntable roller assembely (that hold the metal or glass plate) and the arching went away.
Nov 16, 2008 | GE Advantium 120 Convection/Microwave Oven
Advantium Microwave Oven
it is automatic, you can not turn it off. it is placed there so that the food you are heating is heated evenly. not on one side only.
tnx 4 using fixya.
drcool
Aug 26, 2008 | GE Advantium 120 Convection/Microwave Oven
Advantium Turntable On and off
I would suspect the motor is failing, but it's also possible that you have an issue with a door switch or door switch mount, depending on your model number.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Jul 17, 2008 | Microwave Ovens
Microwave Ovens Logo
243 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
