Question about Tools & Hardware - Others
I have just purchased a Craftsmen 93067 nau=il gun at a garage sale. The nails(1 1/4 ' will not go in all the way(pine stock). I have approx. 1/2 ' of nail not driven home. How can I correct this?
  • hunter_ian Aug 01, 2010
    Hi, the braf/nail gun is an electric model. Sorry I didn't make that clear
  • 454 Answers
Check air pressure from compressor, should be 75-100psi. Add a few drops of air tool oil into the air inlet before use. If neither one of those helps, tool may have seals inside that are worn and need replaced.
Posted on Jul 31, 2010
Where do you find the model number approx 2004 model roofing nailer 1 1/4 &1 3/4 nails
ok what kind is it? the model number is usally on the magazine or depending on what it is could be in several locations,
bostitch are orangy yellow and they have it all over but mostly in the end bottom nearest where the nail comes out right above the black nose piece. should be several numbers, other wise check around on the body still but near the cap this time opposite the side you put nails in, or one last place on bostitch is on the rear of the gun opposite where you put nails in, if its silver is it a grip rite they sometimes put it right next to the trigger on the body and it wears off pretty easy. figure out what color it is and look at google images for the name you have on the gun or ebay , sometimes folks have the name of the gun and the model selling it, but without the color or the picture there could be thousands. hope this helps some.
Sep 30, 2015 | Air Tools & Compressors
How to load brads into stanley tre 550 electric staple/brad nail gun
HOW TO USE YOUR ELECTRIC STAPLER/NAILER
TO LOAD STAPLES
1. Unplug tool, (fig. 1)...(place on/off switch in "off" position, (fig. 2).)
2. Place on/off switch in "off' position.
3. Select proper staple length.
4. Use only staples identified by stock numbers on next page. Substitute staples may cause jamming.
5. Hold tool upside down. (Squeeze latch and pull, (fig.3).)
6. Drop staples in channel, legs facing upward. Push latch back in to lock in place, (fig. 4).
TO LOAD BRADS
2. Use only brads identified by stock numbers on next page. Substitute brads will cause jamming.
3. Look for the image of a brad nail on the front side of the tool (fig. 5). Load brads into this side only.
4. Hold tool upside down (Squeeze latch and pull, (fig. 3).)
5. Drop brads into the channel, tilt the tool so the brads lay against the channel wall, (fig. 5).
Push the latch back in watching that the brad strip does not fall over.
6. Use High/Low power when driving brads.
TO STAPLE OR NAIL
1. Make sure the on/off switch is in the "off" position, plug stapling tacker in.
2. Turn tool on by switching to position 1 which is the "on" position and hold firmly against work surface to
engage safety mechanism.
3. Apply adequate pressure on the top of the knob (fig. 6.) while the trigger is pulled.
You can find the figures mentioned above at the following link:
http://bdk.force.com/FAQ/servlet/fileField?retURL=%2Fapex%2FPKB_Article%3Fid%3DkA0C0000000CdtPKAS%26brand%3DStanley%26returl%3D%252Fapex%252Fpkb_search%253Fbrand%253DStanley%2526mode%253D0%2526model%253D%2526sortby%253D0%2526terms%253DTRE550&entityId=ka0C0000000CdqqIAC&field=File_1__Body__s
Jun 20, 2011 | Stanley Tools TRE550 Electric Staple/Brad...
I am thinking of getting a compressor for my husband for christmas...looking at Bostitch and Porter Cable..both 6 gal portable...cost is comparable, in stock at both Lowes and Home Depot. We are going to...
Eighter one of these will work good for nail guns personaly i have the porter cable and i like it i do a lot of construction work. And i think the porter cable comes a finish nail gun for small nails and staples mind did. But there not for running tools that require a large volume of air like air sanders air rachats or air cutters.
Dec 20, 2010 | Porter Cable C2002 150 Psi 6 Gal...
I bought a used Bostitch nail gun. Model/serial # N6408406208021. What parts do I change to go from a 1 1/2 inch nail (approx. #6) to a 3 inch nail (approx. #16)? Where do I get the parts?
I do not think that the n64 will take a 3" nail. N64 will most likely fit a 2 or 2 1/2 inch. To verify the length of nail open latch door and measure the width of the slot into the barrel. Take a look at the bostitch n80 series of nailers for more power and longer nail.
Dec 18, 2010 | Stanley Bostitch Coil Framing Nailer
Hitachi nail gun nr90ad leaks from trigger when air hose is connected
Orings, they have to be replaced every few years. Warranty does not cover them.
Any Hitachi service centre should stock them. Or find your model on Ebay:
http://shop.ebay.com/i.html?_nkw=hitachi+o-ring+kit&LH_IncludeSIF=1&_arm=1&_armi=0&_armm=20&_ruu=http://shop.ebay.com/i.html%3F_nkw%3Dhitachi%2Bo-ring%2Bkit%26_arr%3D1&_rdc=1
Hope this helps!
Thanks
Jan 20, 2010 | Hitachi Air Tools & Compressors
Paslode impulse cordless nail gun,doesn't pull the piston back far enough to catch the next nail, so when I fire it no nail is picked up by the firing pin. batteries are good(new), cylinder is new, any...
This is an easy fix luckily usually it means that the chamber is dirty and all you have to do is open the top front of the gun so that you can see the piston then take a q-tip and clean the area really well sometimes it requires a degreaser and then when you think that you have it clean make sure to lubricate the chamber really well with the paslode lubricant that came with the gun or they sell it right next to where you get the nails. Then the gun should work fine with no problem if this does not work then this means that the piston might be bent and that could turn into a big problem but is still fixable just harder.
Hope that this works for you
Nov 25, 2009 | Tools & Hardware - Others
What is the proper dept to drive nails
I set my nail guns to drive the nails just flush and then finish it with a nail set if you need to recess them. I find that you can set them deeper but it leaves an ugly mark from the drive hammer that needs to be puttied. The depth of drive will vary depending on the type of wood also. The nail will go in farther on pine versus oak even though the settings didn't change.
Jun 26, 2009 | Black & Decker Tools & Hardware - Others
My paslode nail gun needs to be cleaned
Use the Paslode cleaning spray (Lowes and home depot stock this)
Detailed instructions can be downloaded from the paslode site. http://www.paslode.com/owners-manuals.html
Jun 24, 2009 | RTO Paslode #650027 2500CT Placement Nail
Compressed air tool Usage
Craftsmen often prefer a compressed air tool over an electric power tool for certain jobs. Drywall and trim work are both made easier and accomplished more quickly with pneumatic tools. The most commonly purchased compressed air tool duo for homeowners is the pneumatic drill and nail gun. If you are a homeowner shopping for compressed air tools, be sure you understand how different models work and how the power is supplied. Read the manufacturer’s directions for use and maintenance, and be sure to have the proper sized hoses, fittings, and air compressor.
Aug 27, 2008 | Campbell Manufacturing Campbell Hausfeld...
Tools & Hardware - Others Logo
62 people viewed this question
Top Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
