Question about Kenmore Elite HE4 Electric Dryer
Kenmore Elite Calypso washer won't fill with water!
When used on any cycle, my washer won't fill with water but will start to agitate and wash the dry clothes! Both cold and hot hoses are connected. I thought maybe inside the washer something came disconnected but I have no way of looking.
  • psmet Jan 15, 2009
    My Kenmore Elite Calypso washer won't fill with water from the top. Water comes in from somewhere and is in the bottom, but does not spray out from the top onto the clothes. It goes through all of its regular cycle except for that. I have run some operating tests and water comes out during the tests, but not during the actual washing cycle. Also, I used my tester and checked the fuse on the power board, which says it's fine. Thanks for any help you can give me. P
  • kpuddles Aug 19, 2009
    I have a Kenmore Elite (top load) washing machine. MODEL 110.16922501. It begins to fill with water but then stops. How can I fix this
    Genius:
  • 1,073 Answers
I assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Posted on Apr 25, 2008
Kenmore Elite Model 110.24082200 won't fill the tub completely with water on any cycle before washing begins. Nothing is wron with the water source. Why won't it fill?
Posted on Mar 08, 2009
    Problem Solver:
Kenmore Elite top loading washer agitates and spins but will not fill with water
Posted on Oct 02, 2009
    Problem Solver:
  • 17 Answers
Replace the pump.
I purchased a used calypso set. Nice looking but I am not sure if it is operating correctly. It does not fill and it appears as if it does start to spin then stops. Any idea if this is normal? It seems as if the cloths are always in the same spot.
Posted on Jun 19, 2010
My kenmore elite calypso washer won't fill up enough to get clothes completely wet.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jan 17, 2013 | Kenmore Washing Machines
Where is the filter located on a kenmore elite calypso washer
reomovethe 3 screws across teh lower acess panel, youll see the filter clean out right behind there , be warned before unscrewing get a plastic bag, or a few towells you will getwet!!!!!!
Mar 17, 2009 | Kenmore Washing Machines
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Calypso kenmore elite water level low sometimes
something is clogging recirculating pump inspected both pump that should fix
Nov 30, 2008 | Kenmore Elite 45986 Front Load Washer
Agitator not working 90 series model # 11026912691
Hello aksward,
Welcome to Fixya.
Here are some suggestions for any Kenmore washers
Let me know how it goes. I'm still thinking and searching my repair manuals!
Huuum
Please remember to leave a rating!
KENMORE ELITE TOP LOAD
Washer stops, won't fill, rinse or agitate
• Check the following:
Is the power cord plugged into a grounded 3 prong outlet?
Is the indicator on the Cycle Control knob properly lined up
with a cycle? Turn the Cycle Control knob to the right slightly
and pull to start.
Are the water inlet valve screens clogged?
Are both the hot and cold water faucets turned on?
Is the water inlet hose kinked?
• Does the water level seem too low, or does the washer
appear to not fill completely? The top of the agitator is
much higher than the highest water level. This is normal and
necessary for clothes to move freely.
• Has a fuse blown or is the circuit breaker open? If problem
continues, call an electrician.
• Are you using an extension cord? Do not use an extension
cord.
• Is the washer in a normal pause in the cycle? The washer
pauses for about 2 minutes during certain cycles. Allow the
cycle to continue. Some cycles feature periods of agitation
and soak.
• Is the washer overloaded? Wash smaller loads.
• Is the lid open? The lid must be closed during operation.
Washer will not agitate or spin with the lid open.
Oct 06, 2008 | Kenmore 22422 Top Load Washer
Kenmore Elite Calypso Washer agitator malfunction
you either have too much stuff in it or something that gets under
the agitator or it has a weak transmission
Mar 16, 2008 | Washing Machines
Kenmore Elite HE4 Electric Dryer Logo
1,249 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
