Question about Honda Maxus Prosumer MX5223 Pressure Washer
Tipe of oil and quantity for 6.0hp 2750 psi (xr2750)
  • 700 Answers
Any sae10w-30 will do, 5.3litre of if you prefer 5.6us quarts.
manual is available on this site:
http://www.cpocampbellhausfeld.com/maxus_tools/pressure_washers/mx5223_spec.html
if you find my advice helpful, please do not hesitate to comment and vote4 for me, thanx!
Posted on Aug 02, 2010
Does a Wagner Paint Crew sprayer take lubricant?
The Wagner Paint Crew airless sprayer does not require oil for its operation like full professional sprayers. The piston is off-set from the pump chamber with the inlet and outlet valves opposite each other, however you need to protect the parts from corrosion between use and Wagner recommend running some light oil through it after cleaning. If you will be using it in a day or so for water based paint, you could run a 10% solution of their EasyGlide through it.
Sep 30, 2014 | Wagner Spray Tech Wagner Paint Crew 2750...
Oil type in Karcher gearbox
If you are talking about the water-pump gear box only, the correct oil type is 30W NON-Detergent oil. "ONLY"
Mar 15, 2014 | Karcher Garden
Excell xr2750
excell does NOT make the engine. telling us the engine information might help better but RARELY is it a timing issue. check for spark, if you have spark then shoot carb cleaner into the carb... does it start ???
Nov 27, 2013 | Garden
I just brought a 1987 suzuki dr600 yesterday, and i was wondering how much oil are they meant to take, and how do you check to see how much oil is in the engine, also i relised after it is meant to have a...
no
the sump oil deteriorates if too hot and that destroys the engine
It is designed to have an oil cooler so fit one
Probably removed because it was damaged
contact a dealer service for the oil quantities and viscosity requirements
Jan 30, 2018 | Suzuki Motorcycles
How many psi is there in the fuel line of a 1996 jetta 1.9L turbo diesel
before the fuel pump or after ,before the injector pump no pressure only a vacumn as the pump sucks the fuel up ,
Jan 05, 2011 | Volkswagen GLI Cars & Trucks
What type of fluid in adx 3030 pump/how much?
any good quality ANTIFOAMING OIL as for quantity I would be guessing but there should be a oil marker attached to the oil cap ---rule of thumb approx 1/2 way between 1/2 and 3/4 full .
Nov 06, 2009 | Northstar Professional Series Pressure...
What type of oil does the pump use? how much?
8.5 oz. to the red dot on the site glass.
SAE 30 / 30 wt Non Detergent Oil from your local auto parts house.
Oct 02, 2009 | Caterpillar Cat Pump Pressure Washer Pump...
I'm trying to find out how much oil should be in the water pump of a honda pressure washer model xr2750-1
it's an ex-cell pressure washer with a honda motor.
engine oil capicity: 0.61 qts(.58L)
view owner manual here:
http://www.excellpressurewasher.com/documents/pdf/a12338-e.pdf
Mar 10, 2009 | Honda Garden
Honda Maxus Prosumer MX5223 Pressure Washer Logo
851 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
