Question about Zanussi Washing Machines
When switched on the door locks and the pump runs for a few seconds then stops and the door opens zwd 16270w
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
An earth fault on the motor or heater can cause this. try the heater first disconnecting it and seeing if the machine can get past the fill stage .
Posted on Jul 31, 2010
Testimonial: "Problem solved great answer Many thanks"
Washing machine Hotpoint Aquarius WMF740
Its normal for the door not to open with water in the machine this is a safety feature the door will not open immediately after the wash cycle completes their is a delay before it can be opened.
May 04, 2015 | Washing Machines
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermostat
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Feb 08, 2013 | Microwave Ovens
I have a maytag Neptune NDE3000AYW and the dryer turns on, runs for a few seconds and stops. took it apart and cleaned all the lint and dust. after a while it will run again for a few seconds and stop. ...
Check the door switch. It may be at fault here. Open the door and hold the switch by hand and start the dryer. The switch should have a firm resistance to it when you push it. If you should find this bad, here is the replacement switch. If the switch is ok, then the motor is bad. Here is the motor to order.
Keep me posted!
Nov 05, 2012 | Maytag MDE2600 Electric Dryer
My Zanussi ZWD 1470W won't fill up with water. I
Story could be lengthly so in brief, check to see if drain pump is not blocked and if door latch is functioning correctly.(use a multimeter if you can). If it all measures out as good, then your control is faulty. Does the water fill up to the correct level when you start the cycle? Does the motor hum when trying to run. If so check the capacitor.
May 20, 2010 | Zanussi ZWD1470W Front Load Washer / Dryer
What does error code F26 mean? The washer will fill with water, work for about 5 minutes and then post error F26 and stop working. Where do I find the error codes?
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$
May 05, 2010 | Kenmore HE2 Plus Front Load Washer
Our Kenmore HE2t reads F26 and stops running half way through cycle
DOOR SWITCH ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
Mar 09, 2010 | Kenmore HE2 Plus Front Load Washer
Anussi ZWD 1271W stops at beginning of program
Did you fix this problem? We have the same with Zanussi ZWD 1472 W. It takes some water and stops after 2 minutes. We need to shut machine down and fill water manually. It works fine then.
Feb 02, 2010 | Zanussi Washing Machines
My Duet washer starts and runs for few seconds, then stops.
unplug machine take small panel off on bottom front of your washer, there should be a twist knob on pump, unscrew this (bearing in mind water will come out) you will find a strainer that catches debris before going through pump, clean out debris and re-intall. plug machine back in and try again.
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
At start of cycle, washer drum turns one direction for a few seconds,then spins in other direction for a few seconds and then stops. Next I hear a short buzzer coming from the door area repeat a few times....
There are 4 common trouble makers to consider.
One is the door switch, it can open circuit and stop the washer.
Second is water pressure. If the water pressure is low/poor, the washer will start to fill and then shut off. Check and clean the fill valve entrance screens and also check for any washer screens on either end of the fill hoses.
The third is possibly the most common trouble maker for this type of a complaint. The fuse blows on the motor control board This board can be found on the front bottom on the right side. The motor control board must be replaced when the fuse has blown. Most times now the motor control board is .
The fourth is a bad start switch, sometimes the contacts in the start switch will arc and burn causing starting up problems.
hope this helps.
May 03, 2009 | Washing Machines
F-7 display after running for a few seconds(without cooking)
Your subject line got cut off: "F-7 display after running for a few seconds(without..."
Are you saying that it runs for a few seconds without heating, then it shows you F7 and stops?
If not, please reply back here with more details.
If so, this is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Please reply back here if you still need help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 07, 2008 | Kenmore 64683 Microwave Oven
Washing Machines Logo
207 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
