Question about Canon PIXMA iP1800 Printer
Printer is jamming when paper is trying to feed, on right side
    Problem Solver:
  • 11 Answers
There are two possible problems:
1. A part that holds the feed roller which normally breaks in the Canon iP1800 series
2. The spring that guides one of the gears at the rear of the cartridge parking position is loose.
This is the usual problem I had with my canon printers, I had 80 printers in the past two years.
If you can dare to dis-assemble your printer, I might be able to guide you through it.
Posted on Jul 31, 2010
Paper jams on right side when facing the printer
Please follow these steps :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to t
May 01, 2009 | Office Equipment & Supplies
C4180 paper jam problem
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Apr 26, 2009 | Office Equipment & Supplies
Paper jam message, but actually no paper jam
Mar 08, 2009 | Lexmark X2350 All-In-One InkJet Printer
The paper will not feed correctly. The Right side is getting jam
First jam a paper on purpose then you will know where the jam is . and you will also know where to find the paper which is under the white cylinder.
Feb 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Printer 2480- my printer is pulling paper only on right side
Try this :
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Jan 16, 2009 | Lexmark X2470 All-In-One InkJet Printer
Printer had paper jam
Dec 06, 2008 | HP Deskjet 6940 InkJet Printer
Paper jam...
Aug 18, 2008 | Lexmark X2350 All-In-One InkJet Printer
Paper does not feed - GRABS RIGHT SIDE
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
Aug 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printer will not feed paper correctly
there were may situation that can help with this trouble,
1- try to see if the trays are seated correctly no bend or twisted
2- try to check the quality of your paper no concave nor convex ( like U or N)
3- clean the feed roller from either side by moistened cloth, ( only on one direction evenly
4- ensure no hindrance on the paper path inside the machine
5- reset the unit once more
let me know if you need some more
Jul 25, 2008 | Office Equipment & Supplies
Paper fed
Mar 08, 2008 | Lexmark P915 InkJet Photo Printer
Canon PIXMA  iP1800 Printer Logo
old marine
old marine
