Question about LG L1730SF 17" LCD Monitor
What has caused my LG Flatron 1730S which is responding with half display with vertical lines and the rest half of screen is right
SOURCE: LG Flatron 775FT monitor distortion
Doesn't look very good :( You can try returning to the "factory settings" in your monitor's menu. Maybe try the monitor in another computer to check whether your graphics card is faulty. But all in all it looks like a fault from the monitor :( Good Luck!
Posted on Jul 27, 2007
DosHog
  • 168 Answers
SOURCE: Shade difference in lg lcd diaplay
Based on your description, it appears that the monitor is faulty. Since it is only a week old, you should have no problem exchanging it.
Posted on Aug 22, 2009
gdlkn84as528
  • 89 Answers
SOURCE: LG Flatron L1930B lcd monitor - 3 vert. stripes, center one dead
sounds like the pixel controllers have gone bad or one or more of the color (RGB, RED, GREEN, BLUE) controllers have gone out. this is quite common in lcd monitors/tvs and is usually caused by pressure on the edges of the screen (you grabbed it too tightly when moving the monitor) or just faulty controllers. they are expected to eventually go bad, ask LG for yourself, they will tell you the same thing. If you just bought it, that can be considered a mfr defect that they will replace, IF IT IS IN WARRANTY!!!!! Unfort. there is no fix due to seal that placed on the actual lcd panel inside the plastic casing. Youd spend more money trying to find the part and install it than just buying a new monitor. hate to say it but im an avid gamer and have gone through about 4 lcd monitors in tha past 3 years due to everyday use
Posted on Sep 18, 2009
pra0099
  • 153 Answers
SOURCE: LG Flatron screen with green line
Hey man the screen is having manufacturing fault ...
please go and replace it immideatly.... with no doubts in your mind
regards
SOURCE: LG Flatron w1952TQ screen half darker on right side
Try clicking the auto adjust button on the screen. If this doesn't work it may be in demo mode, so click the fENGINEbutton on the monitor and make sure it is selected on the normal setting.
Posted on Oct 01, 2009
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
What causes vertical lines in right half of the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 12, 2015 | LG 42LH20 42 in. HDTV LCD TV
We have a 22" LG
Dear amy mcioynt,
Welcome, and thank you for using FixYa!
The issue you describe it caused by the video board going bad. All of the controls for video display, clocking, brightness, contrast, and input source is handled by this card.
They are replaceable, if you have the part number. Most of the time they range from $50 - $75
Have a great evening!
Sep 08, 2011 | LG 22" FLATRON LCD Monitor
My LG led has had several problems, it started out with the left half of the screen flipping as if viewed from a mirror with the right part of the screen normal. After that, it displayed vertical colored...
This problems are a very tipical of the coded pixels on the LCD screen panel passes through the board that call the T-CON decoder board to causing this problems.Vertical colors lines display on the LCD screen panel happen by itself.Yes.The T-CON decodering board it is dying and shorting out.This T-CON decodering board sit in the middle at the botton of the LCD screen panel.Replacing this T-CON decodering board will solved this problems,if does not the LCD screen panel itself it is shorting out,than the tv it is not worth fixing,because changing the whole LCD screen panel itself it is not practical and the cost will be the same as a new tv itself.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.
May 31, 2011 | LG 32LE5300 Widescreen 32 in. HDTV
Hi there, We have a LG Flatron W2253TQ monitor and the display is half normal, half very bright. There's a perfect line down the middle - the left half displays normal colours while the right half...
It could be some sort of "Demo" mode on the display, try going into the menu of the display and looking for settings relating to Flatron F-Engine, it has a demo mode that could be the problem. That is the most likely cause since its exactly half the screen.
May 17, 2011 | LG W2253TQ-PF Monitor
Aug 22, 2009 | LG L1915S 19" LCD Monitor
Shimmer and bands
i experienced a tainted vertical black lines on the boths sides of my lcd screen. There was no scratch or whatsoever that could be the reason why thsi balck colored vertical lines to spread. Hope you can help me solve this problem. Thank you..
Jul 12, 2008 | LG Flatron L1710M 17" LCD Monitor
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
LG L1730SF 17" LCD Monitor Logo
195 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
