Question about LG WM-0532HW Front Load Washer
Water Leaking from front of LG WM0532HW washer
Water leaking slowly from front of LG washer WM0532HW. Put washer on 5gal paint buckets so I could get underneath and see where water was coming from. Water is leaking on the front of the drum between black plastic and the drum. Any ideas?
dutchman05
  • 487 Answers
SOURCE: removing drum bearing on a
Remove motor stator and push in the drum shaft as far as you can. Try to put a hook in between the shaft and the bearing and pull rotating in every direction and keep pulling outward.
Good luck
Posted on Jun 05, 2008
  • 180 Answers
SOURCE: I have a LG WASHER,FRONT LOADER WM0532HW KEEPS
LE stands for locked motor error.  The first thing you should try is simply unplugging the machine for 10 minutes.  If the problem continues the next most likely cause is the hall sensor.  To get to the hall sensor remove the back cover, then remove the wheel that is attched to the drum.  Undre that wheel if the stator (motor).  At the bottom there is a sensor that spans about three of the windings.  This is the hall sensor.  It is not very expensive.  If neither of those work you will need to replace the Stator (motor)
Posted on Oct 25, 2009
Macmarkus
  • 2605 Answers
SOURCE: My LG Washer (model WM0532HW)leaks when it
Hi, open the door and check for any holes in the main boot/bellow's. If so you can either try a rubber "patch kit" or relpace the bellows. It is identified at repairclinic on-line as part # 1377586 and retails for approx. $55. Also check the bellows going from the bottom of the tub to the drain pump. It can also be the source of the leak. You should be able to examine it with the aid of a flashlight or trouble light from the opening at the bottom of you washer. If so repace it with part #1266823 also available at said vendor for around $15. Hope that helps. If so please leave a rating of how helpful this info was here at fixya. Thanks for coming to fixya and good luck. Macmarkus :)
Posted on Dec 07, 2009
  • 4088 Answers
SOURCE: water is slowly leaking into the drum even though
One or both of the water inlet solenoids is/are leaking. They are just inside the cabinet where the outside water lines connect. If you have a lot of sand coming in with your water, you might install a whole house filter to trap it. If sand is getting into the solenoid valve seats, that can cause the leaking condition. Hope this helps!
Posted on May 30, 2010
  • 106 Answers
SOURCE: Front loading LG washer WM0532HW squeeking
the belt that spins the drum could be worn out or loose. you can adjust it by moving the tenstioner by moving it an tietening it. you may have to use an apropriate spanner
Posted on Aug 15, 2010
What does it mean when my lg tromm WM2487HRM front load washer slowly fills the tub with water when the washer is off?
most likely water fill valve is defective and leaking. hot water or cold water? replace which ever is leaking
May 21, 2016 | LG Washing Machines
I have an LG front loader washing maching, model# WM2277H* I have changed both the hot/cold water value and the washer is still leaking.
if leaking on front unit : check rubber seal front glass door. if it ripped you should change it.
If leaking behind unit : check water hose , is it placed properly ?
If leaking under unit : call technician to repair it.
good luck.
Mar 25, 2011 | LG WM-2277HW Front Load Washer
Washer tub slowly (over several days) gets water inside
yes this is more than likely a leaking inlet valve, to confirm turn of water at wall valves
Sep 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My LG front loader is washer leaking water.
Could be the bladder from the drum to the door of the door seal. It could also be the drain pump hose.
Sep 13, 2009 | LG Washing Machines
Water leak from my washer underneath i have a Whirlpool Duet SportĀ® HT 3.7 I.E.C. cu
Check the filter, as it may be leaking. To do so, take white panel off the front, put a bucket in front of the unit, unseat the rubber feet holding in the white plug and pull the white plug out, unscrew it, allowing water to run into the bucket, clean filter, check the gasket, as it may need replacement (if so, replace it), then screw white plug back in, push plug back into unit, secure the rubber feet, and replace the front panel.
Apr 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking after i have installed a new drain pump in LG
Obviously you need to find the leak and repair it...duh
Mar 12, 2009 | LG WD-1280FHD Front Load Washer
LG Front load washer
I JUST FOUND THE LEAK ON MINE JULY 5. THE DISCHARGE HOSE ON THE BOTTOM SLOWLY ROTTED THROUGH. THIS GOES FROM THE TUB TO THE DISCHARGE PUMP. ABOUT $9-10 ONLINE- BE SURE TO FIND AND DOWNLOAD THE PDF SERVICE MANUAL. TELLS YOU HOW TO TAKE THE MACHINE APART THE RIGHT WAY.
Jul 04, 2008 | LG WM-2277HW Front Load Washer
Lg wm0532hw front load washer
LG wm0532hw, can not turn on washer, it's not the plug, i try to reset it by unplug for 2min then plug it back. help
Dec 12, 2007 | LG WM-1832C Front Load Washer
Washing Machines Logo
137 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
