Question about Jandy Air Energy Heat Pump - 115,000 Btus - Chiller Model
Spa heater is not firing up and heating
The spa was heating up, and then not heating up. Now we can't get it to heat up. It shows on the remote that it is switching on, but doesn't fire up. We switched everything off on the remote and it is still showing the pool heater as on, but when I go down to the heater the pool heater mode has not been selected. Don't know what to do?
  • bernierudy Jul 31, 2010
    thanks. I am a lay person and have no idea how to do anything you suggested it is too complicated, but I appreciate your response and I will call in a professional to deal with it.
  • 4,323 Answers
Hi
Please check whether there are any disconnected wires on your Jandy heater. Make sure that the fan is working and the thermistor is not disconnected. Check the following diagram---
Jandy heater exploded diagram
If the thermistor is fine then please check the expansion valve, whether it is blocked or kinked. Also check the wiring on the terminal box. If this is fine there might be an issue with the limit switch and you might need to get it replaced. Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Posted on Jul 31, 2010
Pentair Mastetemp Pool and Spa Heater will heat to about 91 or 92 degrees and thats it. We have it set at 102 but it stops at 92 at the most.. It fires up then quits, fires up then quits. What could be...
This could be a number of things. Most often it will be the internal by-pass. You find the assembly inside the water header, it controls water flow through the heater. When it goes bad it can open at a low temp and keep the water from going through the heater.
Also you will want to check the temp probe on the side of the header. If this is bad it will usually show up on the temp display though.
Nov 19, 2010 | Pentair Mastertemp Pool & Spa Heater Dual...
Pilot lights but burner will not fire
what burner where on the oven or the cooktop, if its the oven it may need new gas valve w\ thermocoupler
Jul 07, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Rheem model p-m266a-en-c digital gas pool heater runs, shuts down
CFH is call for heat not sure what spk is, but will find out and let you know.
Jul 05, 2009 | Solar Rheem Gas Fired Pool & Spa Heater...
Error code 126
This is a bad thermister or heat sensor. It mounts in your water manifold and if it goes bad no error will show. The bad sensor is telling the heater that the water is to hot and it wont let the heater fire. This is a farley inexpensive part and easy to change out. With a new one it should read the proper temp and call for heat then fire the heater. Good luck.
Jun 17, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Jandy Air Energy Heat Pump - 115,000 Btus - Chiller Model Logo
71 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
