Question about Omega 1000 Juice Extractor
Plastic arm bracket to hold bowl and cap in place while in operation snapped. Can I replace this piece?
    Problem Solver:
  • 12 Answers
Wait if you have the old 1000 the new latch arm will not fit i tried it but if you the new 1000 go to omegajuicersdirect.com and find parts and email paula for info
Posted on Aug 17, 2010
    New Friend:
Give me owners manual showing how to clean after use the extractor.mahesh..........
Posted on Nov 28, 2014
I have a old model of 6001 I'm looking for part that keeps the bowl in place sjr105@yahoo.com
Well the cover locks in place and holds the juice bowl down. The clutch nut
secures the blade and basket. Either part can be obtained from Waring at
1 800 492 7464.
Feb 23, 2011 | Acme 6001 Juice Extractor
I need to remove the parts for washing How I do this?
Things You'll Need:
  • Soft-bristled brush
  • Stiff-bristled brush
  • Dishwasher (optional)
  • Mild detergent
  • Lint-free microfiber cloths
  1. Unplug your Acme 6001 Juicer. Carry it to a countertop near your kitchen sink.
  2. Remove the pusher and cover, and set the pieces in a sink. Unscrew the clutch, remove it and set it in the sink. Remove the cutter blade, strainer basket and juice bowl, and place the pieces in the sink.
  3. Discard or remove and store any pulp that you find in the strainer basket. When you're finished, rinse the remaining fruit and vegetable pulp and juice from the pieces under cool, running water. Dislodge hard-to-remove pulp from the cutter blade and strainer basket with a soft-bristled brush or with a stiff-bristled brush if necessary.
  4. Wash the pieces in a dishwasher or by hand. To wash in a dishwasher, place the stainless steel pieces in the lower rack and the plastic in the top rack and wash on a normal cycle with other kitchenware. To wash by hand, fill the sink with warm water and a few drops of mild detergent and wash with a lint-free microfiber cloth.
  5. Run the pieces through the rinse cycle in your dishwasher or rinse under running tap water by hand. Air or wipe dry the pieces.
  6. Wipe the base with a slightly soapy cloth. Rinse with a damp cloth and wipe dry. Reassemble your juicer by returning the pieces to the base in reverse order.
     for a visual:http://www.youtube.com/watch?v=alumocbDHg4
     "DON'T FORGET TO VOTE PLZ"
Jan 28, 2011 | Acme 6001 Juice Extractor
I cannot remove the broken latch arm on my Omega 1000 Juice Extractor to replace it with a new latch arm. I have tried to follow vague instructions on the web, but I cannot remove it. Thanks.
It's a real pain and even bigger pain to snap the new one in place. Best way to do it is remove
the 4 screws, not the center one, and separate the base. You will then have access to the
latch arm from within, but remember how everything goes back together again.
Jan 27, 2011 | Omega 1000 Juice Extractor
The left arm-clamp has come off. It seems to be different from the left arm-clamp. At first I thought I just needed to figure out how to reset the spring, but a neighbor seems to think that the arm was...
They break. The latch arm is one piece, spring and all. So if any part of it is still in the
juicer it's broken. Order a pair from Omega and have them walk you through replacing
them.
Nov 22, 2010 | Omega 1000 Juice Extractor
I got the latch arms for my omega 1000 juicer but only the bottom goes in how do i get top part in
With some difficulty. Sometimes replacement latch arms are not an exact fit for
older models. You may have to file them down a bit so they will snap in place.
Also make sure the fit at the cover is not too snug or else the arm will break again.
Removing the 4 screws on the bottom and separating the base will give you a better
view on what has to be done.
Aug 18, 2010 | Omega 1000 Juice Extractor
How to remove strainer/grater from vitamin bar juicer
I am assuming your juicer is the same as mine. The JC-6 White with "Vitamin Bar" and a carrot on the front.
There is most likely a tool that you insert in the back slot, but since I don't know of one, I had to get creative.
First unplug the juicer and undo the side locks, remove the clear cap. Look in the back, there is a 2-inch wide slot where you can see the motor and locking mechanism.
Take a butter knife and hold the mechanism in place. Use your other hand or have a partner spin the mesh/bladed bowl counter-clockwise.
With just some effort and a small "pop" noise, the piece should be free.
I searched forever for a solution, I hope someone with a similar plight finds this helpful.
Mar 15, 2010 | Salton Juicers
HOW DO YOU take apart the jack Lalanne juicer blade and top unit to clean
LIFT UP AND SLIDE COVER RETAINING BRACKET OFF COVER, REMOVE COVER AND
PLASTIC NUT THAT HOLDS DOWN BLADE. ALL PIECES JUST LIFT OUT, BUT KEEP TRACK
OF THE ORDER THEY ARE REMOVED IN TO REINSTALL CORRECTLY.
Jun 28, 2009 | Jack Lalanne Power Juicer 250 Watts
Broken bracket
Hi, I have the Acme 6001 Juicer and I love it! I would take the broken bracket and the juicer to a machine shop that does welding. Shouldn't cost more than a few bucks for them to spot weld the bracket back on. A good maching shop can fix this as they will have another bracket to reference the repair. hope this helps...gary One of our local shops can fix about anything and they are very reasonable and pretty quick.
Mar 10, 2009 | Acme 6001 Juice Extractor
One bracket broke. Tried to glue it with no success.
IF YOU ARE TALKING ABOUT THE LATCH ARM, YOU CAN BUY THEM FROM OMEGA AT
717 561 1105. TRICKY TO REPLACE. I REMOVED THE BOTTOM OF THE MACHINE AND
GAINED ACCESS THAT WAY. ONCE YOU SEE THE LATCH ARM SUPPORT PRY IT AWAY
FROM THE JUICER AND SLIDE IT OUT. CALL OMEGA THERE ARE 2 WAYS TO REPLACE
THE LATCH.
Sep 29, 2008 | Omega 1000 Juice Extractor
Safety Locking Arm
Depends on where you live they have Breville repair centers. I have problems with my juicer (not running) for Northern Virginia the closest place is NY. Check www.breville.com for a list of repair centers after warranty (not many) In California plenty of centers. Hope this helps.
Sep 29, 2008 | Breville JE95XL Juicer
Omega 1000 Juice Extractor Logo
384 people viewed this question
Top Omega Juicers Experts
eyecam
Andrew Taylor
Andrew Taylor
Are you an Omega Juicer Expert? Answer questions, earn points and help others
