Question about Dremel 400 Series Xpr Rotary Tool Kit with Xpr Multisaw and Xpr Planer Attachment 400 - 6/90
Can't unscrew collet
Trouble with Dremel 400 XPR
Can't unscrew collet - even with wrench. While depressing the blue button (as instructed to do whether tightening or loosening), the threads seem to simply run right over the engaged stops - preventing the ability to loosen the collet.
I finally managed to get it off: but to prevent a repeated scenerio, do I need new parts or just maintenance?
  • 700 Answers
It is possible that you stripped lock mechanism on the collet, for the beginning, never, ever, use wrench to tighten the collet! just hand tied, if it slips, tight it bit more, but with hands only.
i never used wrench on the collet and never have any trouble with any of my dremels.
to close, just hold firmly in one hand pressing locket button, tighten up with other hand, to undo, reverse procedure.
if you find bit is too lose, then you have collet inserts, find that one which hold bit firmly and use it on this particular bit. standard collet is 1/8" (3.175mm), but in the set there are collets from 0.0394'' (1mm) to 0.177" (4.5mm). do not use wrench...
just inspect now if thread is not stripped, on spindle and on collar, if locket still hold, if these are damaged, you need to change damaged part. and follow the advice :-)
if you find this advice useful, pleasae do not hesitate leave your remark and vote4 for me, thanx!
Posted on Aug 02, 2010
Collet on my dremel is jammed and the hold button is not strong enough to keep it firm while trying to unlock it.
I would hate to try to jam something into the fan, so I think it would be safer to split the case open and then put the armature in a vise. I am pretty sure you can still do that with this model.
Another alternative would be to use an air impact on the collet, since it works on inertia and does not need the shaft to be locked. Of course then you would need to be able to slip a socket over the collet hex part, and you may have to cut off a bit in order to do that.
Feb 28, 2011 | Dremel 400 Xpr Rotary Tool
I have lost my user's manual for the Dremel 400 xpr Rotary Tool . Can I download it or do I have to purchase it? Thank you, Nancy
you can try going to "dremel.com" and downloading the manual, also there they have a toll free number for tech support which might be able to send manual as a PDF file. Let me know if you have trouble finding it and I will come up with another source
Feb 14, 2011 | Dremel 400 Xpr Rotary Tool
How to install brush spring
There is 2 blue caps on both sides of the Dremel.Just unscrew it with the Dremel wrench and replace the brushed.
Oct 06, 2010 | Dremel 400 Xpr Rotary Tool
It appears that the locking mechanism that is engaged in order to charge out bits has stripped out. No matter how hard I press the button to engage the lock, it always slips when attempting to loosen the...
This can happen if you accidentally depress the spindle locking button while the tool is running -- a common problem since Dremel did not include any type of interlock to prevent it, and the button is right where you'd hold the tool for best control. If that happens, you probably will need to replace the tool or send it to Dremel for repair.
Dec 15, 2017 | Dremel 400 Series Xpr Rotary Tool Kit with...
I have a collet nut that will not loosen. at one point while turning the shaft lock button pops up; even when pressed
Sorry, but I seem to have ( essentially ) the same problem... no positive lock. holding the button down while rotating the shaft to find the "best hold" then applying extra pressure sometimes helps. I had no problem with an older model. 400 XPR also seems to overhheat badly.
My ultimate solution: purchasing the model 4000.
Apr 25, 2010 | Dremel 400 Series Xpr Rotary Tool Kit with...
400 XPR - I am trying to remove a saw attachment. The housing cap is completely loosened, but the attachment won't budge. There is no room to use the wrench to9 attempt to loosen it. I have checked the...
The attachment is 'keyed to the motor assembly so it will only go on in one direction. If it was mistakingly forced on in a different manner it can get jammed. Try twisting it from left to right while pulling straight out.
Jan 13, 2010 | Dremel 400 Series Xpr Rotary Tool Kit with...
Flexible shaft not working all-in-one rotary tool
check and see if you have the right collet insert in the chuck if it is too big it wont lock the shaft. does the chuck turn? if so your collet is not locking the flex shaft
Jul 09, 2009 | Dremel 400 Series Xpr Rotary Tool Kit with...
How do you attach a wheel cutter to a dremel 400 xpr
Go to Dremel.com and download an owners manual for detailed instructions for this tool.
Jul 07, 2009 | Dremel 400 Xpr Rotary Tool
I can't get the head to open to take out the bit
Unplug it, then while pushing in the little silver button near the head use a wrench on the hex nut and turn counter clockwise about a 1/2 turn. Push the bit in, then pull it out (that releases the little fingers that hold it).
The silver button locks the head so it won't spin while you are changing bits. Always be sure it is released before plugging in or turning on the power.
Feb 19, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel 400 Series Xpr Rotary Tool Kit with Xpr Multisaw and Xpr Planer Attachment 400 - 6/90 Logo
698 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
