Question about IBM ThinkVision L170 17" LCD Monitor
My IBM ThinkVision monitor flickers the correct display then blacks out. The light goes green a moment, then goes amber with the blackout. I think it may be stuck in the Energy Star/Power Saver mode. Is there any way to override this or fix it via hardware mod? (Or fix it in general). It flickers on and off once per second or so.
  • Harry Skelton Jul 31, 2010
    I've done the Flashlight-Test and saw nothing, then again, I have LED flashlights that would leave a halo on the screen. But in general tests I saw no image. It seems that it is going into power saving mode then comes back out of it. Like a false signal or something. A cap could cause that I suppose. Just have to figure what cap. Wish I could simply bypass the power saving mode (hardware wise) and see if that corrects things.
  • Harry Skelton Aug 02, 2010
    I have tested it with several PC's. The problem remains. The image is true and clear, when it appears, but is quickly blanked when it shifts power modes. The LED is GREEN for a moment then switches to AMBER, as if in Power Saving mode. Then switches back again, ad nauseaum.
    So far the only solutions I have read is a bad CAP or the chip that controls power saver mode is fried. If I knew which lead to cut I would try that. So far no luck on leads on this, or service manuals with schematics.
  • 732 Answers
Skeltonh, Have you connected your L170 to a different "known-good" PC that has ALL power-save and screen saver modes disabled? Have you connected an old monitor to your PC to see if it will act same way as the L170? 12fixlouie
Posted on Aug 02, 2010
  • Louis Ebert Aug 02, 2010
    skeltonh, Do some reading in my fixya profile (pages 32 and up) and those of "budmrtn" and "buddymc" and follow links you will find there. You will also need to look at the smps/inverter board with aid of large magnifying glass to inspect it for "thermally intermittant" "thermally fractured" solder joints that have over time caused this condition (symptom). What is "date of manufacture" of unit. Could be "time to retire" unit if 5 to 8 years old??? 12fixlouie
Monitorwont come on
When i turn on my IBM ThinkPad laptop the battery and power light is on green but the monitor remains black.
Jan 20, 2013 | IBM ThinkVision L170 17" LCD Monitor
I have a type 6734-LB1 17" Lenovo ThinkVision
where will i get to install the software/drivers of IBM 6734-L-B-1 for listening Music
Sep 30, 2011 | IBM L170M (Black) 17 in. Flat Panel LCD...
I have IBM Thinkvision L150, 15". when computer is started green light is lighting but LCD couldn't display and it looks blank or black. Ok.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Not sure about spending any money on 15" monitor.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
http://www.badcaps.net
Aug 20, 2010 | IBM ThinkVision L150p (Black) 15" LCD...
IBM ThinkVision L191p after power on, remain black.
First place to chaeck will be power supply, the problem can also be caused by bad inverter circuits, bad lamps, see example of failed monitors due to bad caps, lamps, http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Feb 11, 2010 | IBM ThinkVision L191p (Black) 19" LCD...
IBM ThinkVision 17" L170P, the problem is that the screen is black and power indicator is steady green on. Can not turn off the power indicator at all.
Check the DVI connections on your computer and your monitor. It is possible that there is not a good connection. Do you have access to another working monitor? If you connect a different monitor, and that monitor comes up, it could be the DVI cable or a bad monitor itself. If neither monitor comes up it could be a bad video card or port, or the computer may not recgonize it under Properties, Display, then settings when you right-click on the monitor, if you are using it as a second monitor.
Dec 01, 2009 | IBM ThinkVision L170p 17" LCD Monitor
IBM ThinkVision 17" Monitor displays for 1 second then black
This seems to be a common problem with these monitors. Have a look very closely and see if you can still see something there. From there, either send it to get repaired, or, if you are handy with a soldering iron, open it up and replace the 4 main capacitors (at least one of them will be "popped", but it is handy to replace them all.
In order to open the monitor, you will need to remove the stand, and make sure you get all of the screws out before attacking it with a screwdriver.
I have 5 IBM monitors at work with the same problem, and opening them up has shown the popped capacitors.
Again, only recommended if you know what you are doing. Screwing it up will leave you with nothing.
Jan 25, 2009 | IBM ThinkVision L170 17" LCD Monitor
LCD (IBM) monitor power light is green but no display
Make sure the monitor lead which goes behind the computer is in correctly and has not come loose.
Unscrew it from the PC and put it back in again.
Jan 06, 2009 | IBM ThinkVision L170 17" LCD Monitor
17 inch IBM Thinkvision
Well... a good way to tested the caps is to used a Blue ESR meter.
Oct 04, 2008 | IBM ThinkVision L170 17" LCD Monitor
Monitor is dead (black)
ask to moniter service technition
thanks
prasanna
Mar 08, 2008 | IBM ThinkVision L170 17" LCD Monitor
LCD image distorted and flickering.
The Thinkvision series has a known issue with capacitors on the power board.
It is an easy repair, though if your not confident with electronics then get your local TV man to have a look.
Your eBay link isn't working by the way.
Hope that helps.
Sep 03, 2007 | IBM ThinkVision L170 17" LCD Monitor
IBM ThinkVision L170 17" LCD Monitor Logo
951 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
