COmfort Air A-HMC18AD
B zone will not cool. l3 and l4 led's are flashin g at 1 second intervals.
2 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: B zone is only cooling to 49 degrees and leds at
Hi
The L3 and L4 lights are blinking means that the filter is dirty and obstructed. You’ll need to clean the filter. Also Inspect whether the evaporator air is blocked, remove the blockage. Check the air intake and outlet ducts of the condenser side are obstructed. Check both of the ducts. Check whether the unit is set on dehumidifying mode. Set at cooling mode, Set at low fan speed Re-set the fan speed at high speed and check.
However, if this doesn't help then it might have happened that the compressor is not runing and the connection to the compressor is cut. Please check the wiring diagram on Pg 22 in this manual---
Comfort-Aire Air Conditioner Manual & wiring diagram
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Posted on Aug 02, 2010
Zdt12011fa dishwasher is built in and the flood alarm is in operation - how do I reset?
First you need to remedy failure or any leakage than reset appliance.
Under Reset I mean to delete all alarm stored in memory.
1. Turn off the dishwasher.
2. Press and hold S1 while switching on the dishwasher. Keep
holding the Program button until:
- LED L1 blinks, L2 and L3 is on
- Release S1
3. When L1 is blinking, L2 and L3 is on, press the S1 before L2 and
L3 is turned off.
- LED L2 is blinking, L1 and L3 is turned on.
4. Wait till L1 and L3 is turned off, then press S1
- All used LEDs flash 5 seconds on 1 second off repeatedly.
- If buzzer is equipped, it beeps for 5 seconds
- The alarms saved in the memory are erased
5. Switch off the appliance.
26259192-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Dado
Aug 14, 2016 | Zanussi Dishwashers
I have a Carrier Comfort Zone II with 2 controlled zones. The floor with just the sensor controls perfectly. I set that zone at 75 and it stays at 75. The other zone has the actual thermostat. If I se
Sounds to me like a bad damper or a bad zone panel. Turn tstat off and call for cooling on zone 2. Then see if your still getting cool air to zone 1.( where the main tstat is)
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 15, 2017 | Heating & Cooling
I have 2 air conditioners on my Hampton trailer. I can't get my furnance to kick on. I have a R V Comfort .ZC duel control thermostat with zone 1 ,liveing room, and -Zone 2 ,bedroom, zone 2 will say gas...
I need to know what the furnace is doing .
Since you said furnace that's means force hot air and you have 2 Zone damper that's runs on 1 furnace ,correct?
If it's 1 furnace with 2 Zone is Zone 1 working
May 31, 2017 | Coleman Rv Air Conditioner Control Box...
On the Amana comfort zone air conditioner, there is a switch that says exhaust closed. Do I want the exhaust open or closed when i have the cool on the air conditioner
Hi, when you are running it in the cooling mode, leave the exhaust open to remove the condenser hot air. If you want to run just the fan to circulate the air you can close it.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Aug 26, 2010 | Amana Comfort Zone 12M32PBEH Air...
B zone is only cooling to 49 degrees and leds at L3 and L4 are blinking at 1 second intervals at circuit card on outdoor condensing unit. Is there a service manual available for download?
Hi
Daniel
Aug 02, 2010 | Comfort-Aire HMC18AD-1 Air Conditioner
Change temperature from Celsius to Fahrenheit on a comfort zone h
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release. - VS
Nov 11, 2009 | Comfort Zone CZ-800 Heater
How do i wire pressure switch 034-0195
Just put in series after the switch before the wirings
go to the electric motor. Put the two electrical wires
to L1 and L2 (Line In). L1 must be with normally closed ontact L3 while L2 must be with L4. (L3 and L4 - is Line out) for the motor terminal wires. Before connecting wires at L3 and L4, Check for continuity at L3 and L4. Set the muti tester at 1 x 10 Ohms..Then put the multi tester probe on it. The reading must be infinity or no reading at all. Then
connect the motor wires at L3 and L4.
Oct 30, 2009 | Air Tools & Compressors
Rheem Criterion II air conditioner runs but it does not cool
Check air temp out vent should be approx 20 degrees colder than room temp if it is your unit is too small for the amount of space you are cooling.Rule of thumb 1 ton(12,000btu's) for every 400 sq ft of uninsulated space
May 30, 2009 | Amana Comfort Zone 12M32PBEH Air...
Failure in comfort zone one
There is a capacitor connected to the motor on the compressor. If it fails, the motor won't start and the safety thermal cutoff will stop voltage at the motor terminals. There are fuses inside the power interrupt box on the side of the outside unit. One of them may have blown
May 09, 2017 | Amana Comfort Zone 18M33PCEH Air...
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
