On my gateway NV5378u laptop the wireless access is turned off. How do I turn it on? There is no switch, and no hot key, and I need to get on the internet. Thanks!
  • angkleman Jul 31, 2010
    No, there is definitely no switch. My two-year-old pushed some random buttons and that is how it got shut off--but I have no clue what she pushed. My wireless router IS turned on (even if it weren't, the secured wireless networks my neighbors have would show up).
    The issue is with the computer--wireless access is disabled, and until I figure out how to re-enable it, I am stuck!
    Thanks for trying to help though. Any other ideas are much welcome!
    Ps: to add insult to injury, Gateway won't answer my phone calls because they don't recognize the serial number on their own product!
    Sergeant:
  • 170 Answers
Aha another gateway user. my laptop has a small slider switch that turns the wifi card on and off. look for yours. if you dont have an on n off
your is probably on.....you need to know if you have a wireless signal to connect to from the router. if you dont have wifi turned on ( on a router ) you cant connect wirelessly
Posted on Jul 31, 2010
How do I turn on wireless conection in a gateway acer laptop
There is usually a function key combination (Fn+F3) or a slide switch on the side.
Jul 26, 2014 | Gateway Computers & Internet
How do I turn on internal microphone in my NV5378u laptop?
Check it is not muted by right clicking on the loudspeaker icon and look at recording devices.
May 29, 2014 | Gateway NV5378u Notebook
Gateway screen black
Make sure it is not accidently set to display on an external monitor only by using the following keyboard hot-key:
Hold down the 'Fn' (function) key and click the 'F4' key.
If the screen still appears dead you will want to check if the PC is still under warranty and send it back to the manufacturer for replacement. If not, a nearby PC repair shop should be able to replace the screen.
Feb 13, 2013 | Gateway NV5378u Notebook
My Gateway nv5378u Laptop Fan makes a horrible noise when turning on.
fan is hit something or worn out take it and have it replace before you burn the processor up .good luck
Jan 16, 2013 | Gateway NV5378u Notebook
Can't access gateway 450rog wireless! Is there a toggle? Do I need to install a driver?
Yes, the wireless adapter needs a driver, but unless you deleted it, that is not the problem
The wireless function can be turned on and off by a Fn and special function key combo. Some laptops even have a switch on the front of the palm rest that turns the wireless on.
Once the wireless function has been turned on, you will be able to see networks in the area.
var fctb_tool=null; function FCTB_Init_46c140266c3642bdbdfe5931ee798ff0(t) { fctb_tool=t; start(fctb_tool); }
Dec 25, 2010 | Gateway 450ROG Notebook
My nv5378u does not turn on, all i get is the battery light blinks 5 times. help please.
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The motherboard could be defective & needs to be replaced.
Sep 26, 2010 | Gateway NV5378u Notebook
Laptop will not turn on
try remove your battery n insert again...or try use ac adapter without battery
Jul 31, 2010 | Gateway NV5378u Notebook
Need laptop manual on model#nv5378u
User manual can be found in the laptop itself , Go to Start Menu-> Programs-> Gateway Documentation -> Usermanual or quick guide Or got to Gateway -> recovery manager-> restore -> resote application and driver -> manuals
Jun 09, 2010 | Gateway NV5378u Notebook
Wireless wont turn on using F2 key. is this
There is a physical wireless switch on the left side of the computer. The switch turns both the wireless network adapter and the bluetooth on and off. You need to first make sure that this switch is on.
With switch in the ON postiton, then you can use the FN-F2 keys to toggle the wireless LAN on and off.
The wireless adaptor is probably a mini-pci card that can be access through a panel on the bottom. Wireless cards on laptops are not considered user-replaceable so Gateway does not show where the panel is or if it's mini-pci card. If there is a panel other than the hard drive and memory then that is where the wireless card is. They are not hard to replace though it's best to try to replace it with an exact model.
If the computer is in warranty, they Gateway will have you send it into their service depot to have it replaced,
Dec 27, 2009 | Gateway T-1625 Notebook
Wireless networking
the key combo is F2 + Fn key (the fn key is located on the bottom row all the to the left) a little blue light lights up that looks like this ((o)) that lets you know it's on. press the combo again to turn of wifi communications.
Nov 15, 2008 | Gateway 7330GZ Notebook
Computers & Internet Logo
161 people viewed this question
Alun Cox
David Payne
David Payne
