Question about Keurig B60 Coffee Maker
Descale light stays on and the rubber washer on tthe top spikeseems to be part of the problem. help me
    New Friend:
    Problem Solver:
  • 14 Answers
We have a Keurig ourselves and were stumped when we first saw that descale message on the brewer.
There are a number of ways to descale a brewer, the least expensive being to run some vinegar through the machine a couple of times, and then run cold water through a few more times to rinse it.
However, simply trying to clear the lines often doesn't work. And as you will see from the many comments below, by far the most reliable way to get your Keurig brewer working again is the "Slap and Burp" method.
Here is how you do it.
First, unplug the brewer and remove both the water reservoir and drip tray.
Next, hold the brewer upside down over the sink and slap the base a few times. And I mean really slap it.
Now put everything back together and try brewing again. Most of the time this works with a couple of good slaps. If not, try it again.
And don't worry, there are no laws against giving your Keurig a good slapping!
Posted on Jun 13, 2013
Descale a showerhead
  1. What to do
    1. Unscrew the head of the shower from the hose. This may be quite stiff. ...
    2. If it is possible, unscrew the rose attachment from the shower head. ...
    3. Soak the parts in the descaling agent or white vinegar overnight. ...
    4. Reassemble the parts, checking that the rubber washer for the hose is in place.
Descaling shower head
Jul 21, 2015 | Water Water Heaters
What does the red light descaling prompt light stay on? how can i know i have everything possible?
Fill it up the tank with descaler and start the machine on descaling. Leave it to trow all the liquid and must finish to the bottom,leave the machine to get AIR when descaler finished.Then the machine will stop and will tell you to put fresh water to clean . Fill the water tank to the MAX level and continue with the program. When the water is on minimum ,machine will stop,and the descaling process must be finished.
Good luck
Jan 11, 2018 | Gaggia Coffee Makers & Espresso Machines
Where is the windshield washer pump located under the hood?
it locate in tthe bottom of windshield water reservoir(tank)
Mar 04, 2015 | Chrysler PT Cruiser Cars & Trucks
Water runs out of soap box during rinse cycle
Hi there, given this a lot of thought. I had same problem. Could be that you are in a hard water area. Soap is not dissolving properly and building up in the rubber tube between soap box and drum. How I resolved this. Turn off power remove top cover of washing machine and massage the rubber pipe between soap box and drum to soften and cause undissolved saoa to drop into drum. This should rectify problem. Also consider using every month some descaler powder called Descaler cheapest from Axxxxn best wishes.
Feb 26, 2014 | Amana Tandem 7300 Washer and Dryer Stack...
When installing a strainer does the rubber washer and cardboard gasket go underneath the sink with plumbers putty on the top?
Yes. The cardboard washer is the last thing before the nut and the rubber goes next to the sink bottom. The cardboard washer is to keep the nut from grabbing the rubber washer so it stays flat.
Also over time the rubber will stick to the nut and if you ever need to take it apart it keeps that from happening.
Feb 16, 2011 | Kohler Plumbing
The red light is staying on, what do i need to do?
The light stays on if you do not follow the instructions when descaling. You must hold the button for 3 seconds to descale. It takes about 20 minutes. If you press the button for less than 3 seconds with the service disc you just run the water through quickly to rinse/clean and the machine doesn't reset the rescale light.
Feb 15, 2011 | Bosch Tassimo TAS4511UC Coffee Maker
I cannot get a full cup of coffee from my Keurig coffee maker.
I HAD A SIMULAR PROBLEM...AFTER DESCALING WITH VINIGAR I NOTICED THAT MY COFFEE CUP WASNT ALWAYS SERVED FULL....THEN AFTER A LITTLE DIGGING ON THIS SITE IT BECAME OBVIOUS....I HAD A PIECE OF SOMETHING STUCK IN THE ONE WAY VALVE...SO TO SOLVE THIS I DISCONECTED MY KEURIG,BROUGHT IT OUT TO MY SHED AND CAREFULLY BLEW OUT THE THE ENTIRE UNIT WITH MY AIR COMPRESSOR BEING CAREFUL NOT TO USE TO MUCH PRESSURE AND BLOWING OUT A SEAL.....BROUGHT IT BACK IN,FIRED IT UP,WORKS PERFECT AGAIN...EVEN THE DESCALE LIGHT NOW STAYS OFF.NO MORE PINCHING THE RUBBER RETURN VALVE IN THE RESIVIOR JUST TO BREW A CUP OF COFFEE. HOPE THIS HELPS SOMEONE........................
Jun 05, 2009 | Keurig B60 Coffee Maker
Descale red light, wont go off, and can i use any delcale tabs
Solution: Just refill the water tank with water (no descaling solution) all the way to the "Max Line". Then run the full descaling program again --takes approx. 20 minutes. After the program runs completely you will get the yellow "standby" light on and the red "descaling" light will be off.
Next time you descale, be sure and fill your water tank to the "Max Line" before running the descaling program.
Hint: An incomplete cycle (not full tank) is what makes the red light stay on. In other words, it's staying red to tell you to run a full cycle (beginning with the water tank filled to the "Max Line"). Hope this tip is helpful!
Mar 12, 2009 | Bosch Coffee Makers & Espresso Machines
Bosch tassimo
Sep 03, 2008 | Braun Tassimo Espresso Machine/Coffee...
Brake lights stay on
I think I have the same problem... I have a 98 Ford Escort, and I noticed yesterday that my brake lights won't go off (until the it runs the battery completley down, obviously). Where would this rubber washer/bumper be located in my car?
Jun 25, 2008 | 1998 Ford Escort
Keurig B60 Coffee Maker Logo
636 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
