Question about Fluidmaster INC #B1F09 9" Faucet Connector
How to adjust water level in tank---Kohler Wellworth toilet
How do I adjust the water level on a Kohler Wellworth toilet?
  • 2,005 Answers
Please make sure the water is off!
the fluid master has a slip ring at the bottom of the float base it pulls up then you can adjust the float up or, down and, snap it back down.
at the top of the float you will see a cross-headed plastic bolt; this is adjusted for fine level control using a large conventional philips screwdriver.
Posted on Jul 31, 2010
No water coming out of fluidmaster
Is the water turned on OR the water hose connected to the tank?
Sep 06, 2012 | Kohler K-4620-TC-7 Wellworth Concealed...
After installing a new flush valve, the water level in the toilet bowl seems to be much lower than it was with the old flush valve. Is there any adjustment for the water level in the toilet bowl?
Yes,there it is!You can adjust your water level at the flush valve..You can see the ball there you need to adjust that so that the water level of your tank goes to your desired level.
Jul 29, 2011 | Kohler 3386-6 Rialto Skylight Round Front...
I have a Kohler elongated toilet and tank. The toilet does not fill up all the way. What should I do.
Hi chanryan...
You need to adjust your float level in the tank.
Look on the arm of the float ball and there should be a screw that you can adjust the level of the tank water.
Turn the screw to raise the level of the water in the tank, to just about a 1/2 inch of the overflow pipe
If it will not adjust then you will have to replace the float valve (ballcock...is what it is called)
Please take time to rate me
Jul 04, 2011 | Kohler Cimarron 2-PC Elongated Toilet with...
The water level is too low in my Kohler toilet bowl. Level in the tank is fine. How do I adjust the bowl level?
check the (white) tube in the tank. it should connect to the top of the black reservoir. mine came loose and had the same problem. you can check the diagram on the inside of the tank lid.
cheers
Jan 25, 2011 | Kohler Home
I just installed a Kohler Wellworth toilet. Wheni flush the tank only empties about 3 or 4 inches and then shuts off. The water level is at the highest. How do I correct this. Thanks
As long as this toilet is NOT a pressure assist toilet. Then it probably has a water saver flapper that you can replace with a non water saver flapper. This will allow it to flush more. Be advised you may have to adjust the water level after the change to prevent it from double flushing. Hope this helps.
May 21, 2010 | Home
I just install a toilet, when I go to flush it. the water come out underneath the toilet tank?
You did not get things sealed properly...Make sure that the foam seal is in place and the the bolts are not too lose...
It also is possible to crack the tank if you make the bolts too tight...
heatman101
Apr 21, 2010 | Kohler K-3422 - Wellworth Elongated...
Can't adjust flush time for complete flush, low bowl water level
flush time depends on how much water is in it,
the water level flote has an adjuster on it, but i cant rember were it is,,, sorry
Oct 24, 2009 | Kohler K-11470-0 White Wellworth Complete...
Toilet doesn't flush hard enough and some "particles" remain and need to be flushed a second time.
check water level in tank if low adjust float to proper level inside tank will see a level line also check flap as to opening all the way may have to adjust chain if problem continues hard water can cause build up in water holes and narrow tank to bowl tube
Oct 07, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Actuator/lever is broken
well there is a ring just 2 inch up from butim of tank on the fluhmater ....you can twist it up and adjust your water
Sep 28, 2009 | Kohler K-3422 - Wellworth Elongated...
Kohler two peice toilet the water just circles and will not flush.there is plenty of water in holding tank that run through
These models need to have a flush valve flapper that has a styrofoam float on the lift chaninof the flapper. Go to hardware store or home improvement store and get a 'Korky brand toilet tank flapper with float 'ball". Cut the rubber ring piece away from the flapper and you don't need it (see cut here marks on flapper). Install flapper and adjust the float fairly close to the flapper.
When the water level drops in the tank and reaches the level of the float on the opne flapper, the flapper quickly closes causing the toilet to have a "surge" of siphon action which forces the water in the bowl to be drawn out.
Jun 29, 2009 | Kohler K-3422 - Wellworth Elongated...
Fluidmaster INC #B1F09 9" Faucet Connector Logo
973 people viewed this question
Top Fluidmaster Plumbing Experts
Jim Goldsmith
Jim Goldsmith
Mack Baxter
Andrew Bugbee
Are you a Fluidmaster Plumbing Expert? Answer questions, earn points and help others
