Question about Weber Genesis Silver B Grill
Grill does not reach max temp where flavorizer bars glow red
I have tried different propane tanks, did what weber said to do with cancelling the high pressure shut off and have replaced the regulator. Is it time to replace the burners. My cross over bar is alittle rusty.
SOURCE: Weber grill
Can you tell if the gas is flowing? Its either dirty or perhaps your regulator got damaged.  I'd check that out.  Above all else, though, be careful!
Posted on May 19, 2008
burzerko
  • 254 Answers
SOURCE: low flame
This problem most likely is with your regulator. if you decide to replace it please make sure you get the right size replacement. Some salespeople dont know the difference there are four common sizes from class 1 to class 4. If you take the old one with you make sure you match the numbers up with a new one.
Hope this helps You
please rate me.
Posted on Jul 20, 2008
SOURCE: Weber Grill, Genesis Silver A Burner Replacement Instructions
Thanks for your inquiry. In checking around, new parts will cost me $45- $50, plus your fees for instructions and several hours of my time. I checked prices at Home Depot today and have decided just to buy a new grill and enjoy it without all the mess.
Stu
Posted on Sep 11, 2008
gcken
  • 140 Answers
SOURCE: I inherited my son's BBQ. The diffusers are a bit rusty...order new flavor bar to replace. Can I BBQ in the meantime using the rusty diffusers?
yes it won't hurt it
Posted on Apr 28, 2009
SOURCE: low flame
Adjust the screw hidden under a sticker on the adjustment knob. That will increase the flow.
Posted on May 05, 2009
What is the steel production at Columbus Stainless Steel?
to know more about it visit
http://instinox.com/steel-pipes/
Dec 09, 2014 | Weber-Stephen Products Weber Genesis...
After running for a few minutes, my bottle top heaters start flaring and burning irregularly. The same thing happen when I hooked it up to another heater. Also when I turn the gas off it takes a lot of...
Are the propane tanks fitted with a pressure regulator?
The propane gas regulator is one of the most important parts of a propane gas system (or a compressed natural gas system as well).
The purpose of the regulator is to control the flow of gas and lower the pressure from the tank to the appliance(s) in the gas system.
The regulator not only acts as a control regarding the flow and distribution of propane (or CNS) but also as a safety barrier between the high pressure of the tank and the end use appliance(s).
Without it, you can cause serious damage to the appliance's gas valve and create a disaster- fire or explosion.
Nov 30, 2013 | Mr. Heater Model MH12TS - Single Tank-top...
Unable to get gas our of 'Blue Rhino" propane
The problem is an easy fix. Replace the current Hose/Regulator Assembly with a new one. They run about $30.00, at home centers and hardware stores that sell grills and accessories.
Once you install the new one and connect it to the gas tank, open the gas tank valve Very Very Slowly (Slow Motion, Slow) until it's fully open. If you don't do it this, the new regulator will lockup.
Hope this helps you & thanks for choosing FixYa.
Aug 25, 2011 | Weber Spirit? E-310 Propane Grill
My weber grill doesn't seem to be getting enough gas thruogh the jet to heat to proper temp.
The most likely problem is that food drippings have clogged some of the pin-hole gas outlets in the burner tubes. If those are clean and open, then either your propane tank is not releasing the gas or the controls on the grill are not releasing the gas. If you look at the flame level, probably best done with the flavorizer bars removed, and they are all the same with the controls on high, then it it probably the tank valve. If the flame heights are different, the lower one(s) are the ones where the control valve(s) are not working and need to be replaced. Good luck!
Jul 25, 2011 | Weber Genesis Silver C Grill
We converted our weber Q q120 so it would work off our RV propane tank. It has a very low flame. We took the regulator off the grill and are using quick connect and a 15 ft hose to the grill. Help?
Your RV Propane System works on a different pressure than your, gas grill. Reinstalling the regulator may correct the pressure difference. Then install a short pipe nipple into the regulator and install a shutoff valve. After the shutoff valve, reinstall your quick disconnect hose. from here on after, each time you connect the hose to the grill, be sure the shutoff valve is OFF before making the connection. Then open the shutoff valve very, very, slowly, so as not to lock up the regulator.
Hope this helped you. Please let me know. Happy Grilling!!
Jun 24, 2011 | Weber Q Grill
Does not heat up right
Disconnect tank - remove cooking grates and flavorizer bars - use a soft metal brush and lightly brush the burner tube (where the flame comes out) and make sure they are not clogged up. While you have the grates and bars out you should clean them as well with hot soapy water and a brush. Put all pieces back in when done cleaning and re-connect the propane tank. Open propane tank valve 1/3 of a turn and light grill. After it ignites, open valve further. Usually a good cleaning will take care of it. If not, it may be the gas regulator. Weber has great customer service and will be more than glad to help you with just a phone call. On your grill there should be a label showing your model and serial number. It is very helpful if you have this info if you call Weber (but not totally necessary). Weber contact number is 1-800-446-1071
Apr 24, 2011 | Weber Genesis Silver B Grill
Need photo of how to replace the 5 "V" shaped
The 'V' shaped metal bars are the flavorizer, flame tamer or whatever Weber wants to cal them. They go over top of each burner from front to rear, setting on the ledge of the interior of the grill, just above the burners. make sure that cover each burner equally. Now's a good time to clean them if they have a lot of grease on them.
Since the grill was blown off your deck ... make sure all the burners are intact are not damage and there are no gas leaks from tank to the grill.
Feb 11, 2011 | Weber Spirit? E-310 Propane Grill
My weber genesis silver starts up, but doesn't get hot enough to cook the food. Seems like not enough flame out of either front or back burners. I tried Outting in a full propane tank, but that didn't...
Try these steps in order.
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
Sep 06, 2010 | Weber Genesis Silver B Grill
I have a Weber Q grill, propane tank is full but propane is not getting to burners. I do have a spark when I press the ignition. Where is it likely to be plugged up?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Aug 20, 2010 | Weber Q300 Grill
Weber Genesis Silver B Grill Logo
172 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Weber Grilling Expert? Answer questions, earn points and help others
