Question about Kenmore Dehumidifiers
We have had a kenmore dehumidifier model #58051450100 but about a month ago it started blowing hot air. Hot enough to heat the whole cellar. It has never done this before. Can anyone help?
2 Suggested Answers
SOURCE: Overheating
Same problem, I cleaned the filter etc. seems to run ok, but gets very hot on the top and sometimes smells hot. No signs of burning etc.
Posted on Oct 15, 2008
My Kenmore dehumidifier isnt working. Clean filter and back. Frost on top of the dehumidifier. The round black cylinder- compressor is hot.No water in the bucket.
signs of frost on your machine is an indicator that (1) there's not enough air flow over coils
and (2) there has occurred a leak in your system and some or all of the gas has escaped out to the atmosphere
number 1 usually causes number 2 due to increase in heat
unplug for 48 hrs then try it again if no joy then you'll need to replace it
May 29, 2015 | Kenmore Dehumidifiers
My humidifier blowes hot air
if it's working well it should , unit should be removing all the moisture from air expelling out back , so its dry air
its when coils freeze up then you have a indication of problems
May 13, 2014 | Kenmore 54701 Dehumidifier
My dehumidier blows very hot air while working. Makes it hotter than it was before starting. Like a furnace.
It is normal for a dehumidifier to discharge warm air. A dehumidifier is really an air conditioner - a fan blows humid room air across a cold fin coil that causes the moisture to condense on it and drip into a container - thus cooling AND dehumidifying the air. The cool air is blown over the warm coil and discharged out the back. A dehumidifier WILL normally increase the temperature of the room it is in.
You can do the same thing with sitting an A/C unit on a stool in a room. Room air will be drawn in, cold air will come out the front, hot air out the back and water will drip on the floor. And, the room will get hotter, due to what is called "heat of compression" even though you're running an A/C unit.
Jun 26, 2013 | Windchaser WDH928 Dehumidifier
Should hot air blow out of a deumidifier
I had the same one and yes it is pretty warm air that blows out of it
Jul 07, 2012 | Kenmore 54701 Dehumidifier
I have a Kenmore Dehumidifer, model number 580.53650200 and it's been sitting around in the garage for a while. Before I plugged it in I ran the air compressor over it fairly well, blowing out the...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 05, 2011 | Kenmore 5365 Dehumidifier
I have a kenmore dehumidifier (about 2 years old), and i've found that after i turn the unit on and it is running for 2-3 minutes, it will then shut down even though no water has collected in the tray. any...
My first thought is that there's not enough moisture/humidity in the air, for the setting you have the humidifier set on. The higher the setting or percentage (i.e. 60%) means that the level you want to maintain. Which may be find in the cod winter months. In the Hot summer months, you want as low a level of humidity as possible (i.e. 45%).
My second thought is that the air intake filter and the coolant coils need cleaning, since it has been used in 2 years. It's just sat around gathering dust and spiders.
And finally, the collection bucket, may not be inserted properly and when the unit starts up the vibration dislodges the bucket just enough, so that it's not making contact with the safety switch. Sometimes when this happens, the Full light indicator will come ON, even if the bucket is empty.
Hope this helps you to start troubleshooting the problem. Please let me know.
May 01, 2011 | Kenmore 54501 Dehumidifier
Dehumidifier headaches!
There are three things that must be working to extract water. The 'coil' (a finned metal part that allows air passage) if it's filled with dust and obstructions, no air can move...no water. There is a blower motor that mus move the air. If it is seized up an not blowing air...very little or no water. The compressor uses condensation from the air moving across its coils (like the moisture than forms on a cold glass on a humid day) to extract the water from the air. If it's not working then no water.
So, if there is air blowing out of the dehumidifier the blower is working. If the air is room temp the compressor is not working. If it's real hot air, and the humidifier keeps cycling on and off quickly, the coil is dirty. Those are the 3 things that need to be working.
Jul 27, 2009 | Kenmore 54501 Dehumidifier
The dehumidifier is blow cold air
Is it collecting water? The air coming out the back top half should be cool/warm. It will be a little warmer at the bottom near the compressor.
Apr 07, 2009 | Kenmore 54701 Dehumidifier
Dehumidifier
Again, if your model is one that can be used in cooler temps so as not to ice up, the heat prevents this.
Aug 07, 2008 | Maytag M7DH45B2A Dehumidifier
30 pint model # M30H3082A
A common problem - low on refrigerant. Unfortunately it's not a simple fix. Check your warranty to see if you're still covered for "Sealed system repairs"
Nov 30, 2007 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
81 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
