Question about Motorola TalkAbout T5000 2-Way Radio
Hi i have the motorola talkabout t500 and they dont work once we get more than 2 blocks away from each other it said that they were good for 5 miles they are both on the same channel
    President:
  • 2,761 Answers
The 5 mile range claimed by the manufacturer might be possible if you were transmitting between two hilltops, with nothing between them except a body of water. The FRS/GMRS frequencies are "line-of-sight," which means that anything directly between the transmitter and the receiver (buildings, trees, cars, even people) can block the signal. Even the so-called 30-mile GMRS sets have an actual effective range of only about 1/2 mile.
Bill B
Posted on Aug 01, 2010
I need battery covers for T5000
ou can use the regular AAA or AAA NI-MH batteries
Apr 12, 2010 | Motorola T5000 Two Pack 2-Way Radios with...
I want to know talk range of Talkabout T5720
Handheld radios generally will talk "radio-to-radio", "line-of-sight" up to 2 miles. Once you start putting obstacles in between the radios you will shorten your range.
Advertising literature will sometimes give numbers such as "5 mile range". While this is possible in ideal conditions, it is not common in real-world situations. HEIGHT and PLACEMENT of the antenna determines the range of the radio. Example: Talking from a mountaintop you could talk far into a valley below, much further than the expected 2 miles. However, if you were to be in an congested city, you may only be able to talk a single city block due to obstacles.
To get the best range, use a well charged battery pack, wear your radio high on your body, and always hold the antenna perpendicular to the ground when using the radio.
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Apr 08, 2010 | Motorola Talkabout T5720 (7 Channels)...
1/2 mile range max
Advertising on these models is much like reading about a car's MPG, it must be in perfect conditions. Handheld radios generally will talk "radio-to-radio", "line-of-sight" up to 2 miles. Once you start putting obstacles in between the radios you will shorten your range. Even the body fluid of the person wearing the radio on their hip will absorb some of the range. Talking from inside of a building to outside you might expect 1/4 to 1/2 mile. Good rule of thumb: Height and placement of your antenna determines range. The higher the antenna, the further you can talk. If you are talking from on a mountain top to a valley below you can talk as far as you can see. Increasing Range: Hold your radio perpendicular to the ground, not slanted like you would hold a phone. This problem alone could decrease your range 2/3s. Face the direction you are wanting to communicate. Don't shout CB-style, shouting reduces talk-range. Lastly, use good batteries. This will ensure your transmit capability.
Jun 08, 2009 | Radio Communications
The working frequency range for talkabout T6210
Handheld radios generally will talk "radio-to-radio", "line-of-sight" up to 2 miles. Once you start putting obstacles in between the radios you will shorten your range. Even the body fluid of the person wearing the radio on their hip will absorb some of the range. Talking from inside of a building to outside you might expect 1/4 to 1/2 mile. Good rule of thumb: Height and placementof your antenna determines range. The higher the antenna, the further you can talk. If you are talking from on a mountain top to a valley below you can talk as far as you can see.
Increasing Range: Hold your radio perpendicular to the ground, not slanted like you would hold a phone. This problem alone could decrease your range 2/3s. Don't shout CB-style, shouting reduces talk-range. Lastly, use good batteries. This will ensure your transmit capability.
May 30, 2009 | Motorola Talkabout T6210 (14 Channels)...
Motorola T4500;what is bthe range of communication
hi there!
thanks for using fixya!!
you could visit this site to download the usermanual as well:
http://www.usersmanualguide.com/motorola/2-way_radio/t4500
info: maximum talk range is up to 2 miles.
Regards,
pls don't forget to rate my solution!! thanks!!!
Feb 25, 2009 | Motorola Talkabout T4500 (7 Channels)...
Motorola t5000 charger polarity
The Polarity of Motorola's equipment is always Center Positive.
Pat
Aug 13, 2008 | Motorola T5000 Two Pack 2-Way Radios with...
Hello kenyond,
The range that you can expect to see when using two-way radios is very dependent on local conditions. These radios are very line-of-sight dependent. Obstructions like mountains, hills, tall buildings, thick vegetation, and using the radio in a shielded environment such as inside of an automobile can block your line of sight and limit your effective communications range.
That “maximum 5 mile” advertised range is probably only practical in a situation where the user of one of the radios has some significant elevation (such as being on top of a tall hill) and therefore has increased line of sight. When communicating over relatively level ground that is clear of obstructions, you can probably expect a reliable communications range of about a mile.
Best Regards,
Agent Ken
"Go Ahead. Use Us."
Jun 28, 2008 | Motorola Talkabout T5720 (7 Channels)...
2-WAY RADIO TROUBLESHOOTING
In a Motorola T500, pressing the + button while powering on enables/disables the roger beep (release of PTT button).
Good luck and kind regards.
Nov 03, 2007 | Motorola T5000 Two Pack 2-Way Radios with...
Motorola TalkAbout T5000 2-Way Radio Logo
220 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
