Question about Whirlpool Calypso GVW9959K Top Load Washer
Error code CA and CL -- washer stops during a normal cycle and shows these codes. What does this mean? This is a Whirlpool Calypso washer.
  • morris1615 Jul 31, 2010
    Our Whirlpool Calypso washer stops during a normal cycle and shows an error code "CA" or "CL" -- what does this mean and how can I determine what to check to correct the problem?
  • 8,197 Answers
The CA code means that the average current draw at the motor winding has exceeded 5.55 amps for more than two seconds. This could mean a problem with the drive motor, the thermal protector, or the motor controller board. Overloading the washer can also cause this fault. Page 57 of the manual gives specific tests for the drive motor and wiring harness. Start there.
CA or Cl
Average Current Limit or Instantaneous Curent Limit
If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings.
Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings.
This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
Press STOP/CANCEL to clear the display
Repair Manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
Good luck
Posted on Jul 31, 2010
  • 3,230 Answers
Well the error code CA and CL present If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings.
Solution: Press STOP/CANCEL to clear the display.
Good Luck!!
Thanks
    When you push Stop/Cancel, this stops the entire cycle.
    Where do we start in trying to determine what the problem is? -- motor controls, thermal control, etc.
  • Mukesh Kumar Jul 31, 2010
    Please follow the below link to know how to check the motor controller -
    http://www.applianceaid.com/pictures/Cal...
I ran a self diagnostic test on my Whirlpool calypso washer and got CA error code. Do I need to replace the drive motor?
Before replace, I would first check the power supply, wiring and electronic.
Dado
Dec 24, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
My calypso washing machine has an error code of "CA" What does this mean, it is squealing and will not drain water
CA means average current limit . this may signify problems with drive motor or motor controller over loading the washer may cause this problem. to clear this-press stop /cancel
Oct 04, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Waht does code CL mean when trying to fill washer
Cl Average current limit Or Instantaneous current limitIf a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip. Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings.
Sep 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Error code CA on calypso
http://www.applianceaid.com/calypso-codes.html#wash
CA Cl Average current limit Or Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
Sep 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
Whirlpool Calypso Washing Machine "Cl or Ca"
The control board is reading too high of an amp draw from the motor,Most likely a bad drive motor.
Sep 01, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite calypso codes a C1 and quite working
Maybe "CL" From User Manual:
“CA” or “CL” (Current Limit)
Jul 04, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
CA error code on Calypso Washer
CA Cl Average current limit Or Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip. Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings. Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
Meaning you had stuffed it full one time and then it was hard on the motor, you will have to change the drive motor most likely...
May 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
CA Error Code - AEG OKO LAVAMAT 86700
c-a error message poped-up.washer stop working.............please help.
Sep 15, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Calypso won't drain
CL or CA is an over amp draw most likely caused by the motor thermal protector or motor controller It can be caused by too large of a load try to press "STOP/CANCEL" to clear if the problem returns you will need to get inside the unit
Jul 09, 2008 | Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
71 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
