Question about Canon NP 6650II Copier
6551 E01 When I get the screen after *4* how do I "reset" error codes? use the paperclip again? hit some other key? I don't have much time and the copier shuts down pretty fast.
  • 1 more comment
  • Joseph7756 Apr 29, 2008
    I assume that you speak of putting the pen in the front "door" switch, not the "lid". This does not reset the codes. I have had a tech here 2x and he punches a number of things on the key pad to call up the codes and then cancel them. The machine then runs fine for about 3000 copies or 1 month.
    No. Unplugging it does nothing. When switched on the error code E001 comes up, then the machine turns off in about 30 seconds. I've had a tech here and he somehow calls up and cancels the error codes by a series of keypad entries. The machine then works fine for about 3000 copies or 1 month. I suspect its the power switch which gets quite warm if I hold it in the on position.
    I had to unplug the connector to short J3 and J4. Never saw a count ratio indicator "F" display or any other change in the display. Turned copier off and on a couple of times. Everything is now working fine. So something worked, I'm just not sure what.
    Genius:
  • 1,665 Answers
    Genius:
  • 3,422 Answers
"E001" Abnormal fuser temp.Try this Press the power swithch to off and then back to on.
Goodluck..
Posted on Apr 29, 2008
  • Priya darshan Apr 29, 2008
    Here is how you will reset it:
    With the front panel open and the copier lid/carriage lifted up,use a paperclip and stuck it in the small hole on the front grey panel (DC
    controller) and simultaneously use a pen to hold down the tab in the
    slot on the lower left edge that makes the copier think the lid is
    down. It will reset the error code.
    Please don't forget to rate this solution as
    Please don't forget to rate or accept this solution as fixed.
  • 3,037 Answers
Try unplugging it for a few minutes first and see if that helps at all, and let me know and I will further assist you with this problem
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Apr 29, 2008
    To reset these codes perform the following:
    Remove the front panel and be careful not to bend or break the flexible
    cable connected to the panel and the DC Controller.
    Turn on the copier and short the jumper wires JP3 and JP4 on the dc
    controller pcb with a screwdriver.
    The count ratio indicator on the control panel turns on 'F'. When 'F'
    is turned on stop shorting the jumper wires
    Turn off copier and turn it back on and its then reset.
  • Benjamin Patri
    let me know if the above doesn't work and we can go from there, thanks
  • Benjamin Patri
    glad you were able to get it working, have a good day
I have an ninja 4 in 1 cooker. it comes up with an eo1 message. what can i do?
  1. The thermostat may temporarily lose calibration due to temperature changes resulting in an E01 error message on the display. Repeat the following steps to reset the unit.
  2. 1. Unplug the unit from the wall socket for approximately 10 seconds.
  3. 2. Plug the unit back into the wall socket.
  4. 3. Press the POWER button once. Within one second, press the COOK button once. The unit should now be reset
or Cooking pot is not inside the cooking system housing. Insert the cooking pot.
Search Results
SOLVED: When I turn it on I get E01 - Fixya
www.fixya.com/support/t305866-when_turn_get_e01 Dec 19, 2007 - When I turn it on I get E01 When I turn on power it is giving me E01. ... I had the same E01 error code. .... How to fix on a ninja crockpot e01. According to the manual it means the cooking pot is not inserted into the device.
ninja cooking system e01 error Questions & Answers (with Pictures ...
www.fixya.com > Forum > Tags Find solutions to your ninja cooking system e01 error question. ... ...fix error code eo1 and err i getting an error code eo1 and err and it not cooking For one, you ...
SOLVED: How to fix on a ninja crockpot e01 - Fixya
www.fixya.com/support/t17203774-fix_ninja_crockpot_e01 Mar 19, 2013 - how to fix on a ninja crockpot e01 - NINJA SEARious Slow Cooker question. ... According to the manual it means the cooking pot is not inside of the device. Same thing happened to ours .... you can use it. Here is a tip that will tell you how to fix the EO1 error code. ... ninja cooking system e01 e01. Feb 07 ...
Ninja cooking system e01 - Fixya
www.fixya.com/support/t23385060-ninja_cooking_system_e01 Feb 7, 2014 - ninja cooking system e01 e01 - NINJA SEARious Slow Cooker ... I have an E01 error code on my West Bend slow cooker, how do I fix it?
[PDF]3-in-1 Cooking System - The Home Depot
www.homedepot.com/catalog/.../3f/3f5a04f4-303f-482a-a702-eeb5ecab0bdb.pdf In the event of a loss of power, an error .... The Ninja® 3-in-1 Cooking System Steam Oven offers a revolutionary new way to cook your .... "E01" Appears on the.
ninja 4 in 1 cooker eo1 error - Google Search
Apr 02, 2017 | Kitchen Appliances - Others
Reset wate tank ricoh sg2100n
there is no way to reset it.
you need buy a new one.
May 19, 2014 | Office Equipment & Supplies
My pro 2018 was unplugged for a month or so and lost its memory,how do i reprogram,ive tried reset but i cant get it to take my freqs that i program in
  • After you reset the scanner you have to initialize it again.
  1. 1. Power the scanner off and on.
  2. 2. Press and hold the "TUNE/CLEAR" key and stick the end of a paperclip in the reset hole and hit the rest button.
  3. 3. Now remove the paperclip off the reset button and wait for the display to turn back on.
  4. 4. Now release the "TUNE/CLEAR" key.
  • The scanner is no initialized and ready to be programmed again.
  • Now program the scanner.
  1. 1. Press "PGM" key.
  2. 2. Now enter a channel you want to store a frequency.
  3. 3. Press "PGM" again.
  4. 4. Now you will be on that channel.
  5. 5. Now enter the frequency you want to program and don't forget the decimal.
  6. 6. Now press the "ENT" key.
  • Repeat steps to program more frequencies.
  • Hope this helps.
Nov 27, 2011 | Radio Shack Pro-2018 Scanner
Canon ir2200 printer error code e0000020000
1. Hit "additional functions" key on the printer's keypad.
2. Press and hold 2 & 8 at the same time for one second.
3. Hit additional functions key again.
4. You've entered service mode. Now hit "copier"
5. "Function" key
6. "Clear"
7. "Err" . There should be an error or the error code in this section select this part.
8. Hit "ok"
9. Restart the printer by switching off the physical black power switch on the side and switching it back on.
For more help visit cbrtechsolutions
Dec 14, 2010 | Canon Computers & Internet
I have a canon 6551 which is giving me an error E-005 turn switch off and on, but nothing happens. How to resolve?
The E005 error code means that the machine needs to have its Fixing Web replaced. After replacing the web, the error code will need to be reset. The part number for the Fixing Web is FY1-1046-000 . To reset the E005 code, you will need to access service mode by opening the front cover of the copier, insert a straightened paper clip into the small hole (located on the left, front side of the upper inner cover), press button with paper clip. Press the Additional Functions (*) button. A " $ " will appear in the display. Press *, 4, *, then you will need to navigate to web counter, select and then enter all 00000 to reset, press ok.
Jan 27, 2010 | Canon NP 6551 Black and White Copier
Canon 6551, service mode *28* DOES NOT WORK. Pressing the *, then a number from 1 to 6 then star again, gets you six different menus. None of them user-friendly just a bunch of numbers, counters,...
It is necessary to replace Cleaning belt. The DC controller keeps count of the activation of the cleaning belt solenoid, and issues ‘E005’ when the count reaches 250,000. The count can be cleared by resetting the cleaning belt counter ‘619’ in service mode.
50% of the time, you can get it removed by following the below procedure :-
Open the front cover and on the right or left side of the inner front cover there is a small diameter hole that if you stick a paper clip into it will activate the service mode switch which will be denoted by a dollar sign on the control panel. From there push the additional functions key then 4 then the additional functions key again. From there go to error/clear and power cycle and it should be good to go as long as the web has been replaced. This is off the top of my head and it has been awhile so I hope I gave you the correct order.
If problem still persists, call Canon.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 06, 2009 | Canon NP 6551 Black and White Copier
Ge adora problem with panel code e01
I'm almost having the same issues but the code displayed is E62. Can you help
Aug 23, 2008 | GE DCVH515EF Electric Dryer
Sharp al2030 error code h4 upon power up
Here is the solution straight from the lips of tec support at sharp.
This can happen due to a power outage.
Here is how you fix it.
1. Hit clear, then auto. (clear is on the right the red C, auto is on the far left)
2. Once again Hit clear, then auto. (clear is on the right the red C, auto is on the far left)
At this point wait for the screen to go dark.
3. Type in 14 (hit the 10 once an the 1 button 4 times)
4. Hit the Green Button.
The screen will go dark and reset the copier.
Jun 12, 2008 | Office Equipment & Supplies
Zwf1430w display problem
My Zanussi ZWG1120m is displaying fault code E60 and E62
I have ben told that the machine needs to be reset. lease can anybody tell me how to reset the machine.
Feb 08, 2008 | Zanussi ZWF1430W Front Load Washer
Dec 19, 2007 | West Bend 84496 6-Quart Slow Cooker
Canon NP 6650II Copier Logo
93 people viewed this question
old marine
old marine
