Question about Samsung Manual Inflate Blood Pressure Monitor
The small bulb which attaches to the tubing is missing. Where do I get another?
  • 10,865 Answers
I cannot get the one d cell battery left out of my 5 d cell mag flashlite I've done everything with no luck I don't want to destroy it with my frustration can someone help me please
Remove the lens end of the flashlight. Remove bulb. At the switch there is a small screw that should release the socket for the bulb and what ever else is left in the tube. If battery still stuck should be able to push it on through with what ever you have that will fit in the tube,.
Feb 06, 2016 | Camping, Backpacking & Hiking
How do I replace the Fuel primer plastic bulb?
It is a lot easier than first examination appears. The bulb is held in by two barbed clips. Remove the air cleaner and filter then you can see the bottom of the bulb assembly, and by looking carefully you can see the end of the clips (The only hard part is seeing the clips as they are pretty well hidden). Remove the two tubes that go to the bulb, from the bottom end -- leave them attached to the old bulb on the top end (so that you can tell which one goes where). Then with needle nose pliers squeeze the barbed clips and push up on the bulb assembly. Pull the bulb assembly out with the tubes attached if possible. Put the tubes on the replacement assembly then insert back in the hole with the tubes in first. (Examine the tubes to make sure they are not cracked or split -- replace if damaged). Snap in the new assembly then connect the bottom end of the tubes, put the air cleaner back on and you're done.
Oct 23, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Cratsman 40cc chainsaw will not run. i get it started and pull the throttle open and it wants to die, sounds like it starves for fuel. put new line from tank to carb, blew out carb, dont no settings for...
A quick test to see if it's running too lean (starved for fuel) is to gently push the primer bulb. If the motor spins up (revs), it's likely a clogged high speed jet. If it stalls immediately, then it's running too rich and you need to cut back on the high jet.
See http://www.repairfaq.org/samnew/lmfaq/lmadjc.htm for some quick and dirty (but good) instructions on adjusting the jets to fine-tune your engine.
As for the primer tube, if the bulb pulls fuel and fills up when pumped 3-8 times, then things are fine. If the bulb never gets fuel, then you may have identified a potential cause (missing tube).
Jun 01, 2010 | Garden
I have a small Holiday fridge and it is not cooling. The compressor is running and there is frost on the metering tube on the back
frost on the capilary tube is the sign of bad things, usually a resrtiction in the system, or uncondensables such as water or cooked oil,
this is a sealed sytem repair that would require a lic to repair
with is unit, you would need a minimum of an evaporator and system dryer installed
the dryer is the bulb attached between the evap and the cap tube
Oct 22, 2009 | Frigidaire FRT21P5A Top Freezer...
My Poulan Pro weed trimmer SM132 does not run. I replaced the primer bulb and spark plug and it ran fine for 10 minutes. Now it will only start with the choke on and dies immediately. It will not start...
The primer does require two lines attached as it is a Walbro style primer. All four SM132 models uses the WT628 Carb. Since the trimmer ran 10 minutes then you have got all the lines connected right. Mostly you got trash in your carb or it simply needs rebuilding as the diaphragm may have pin hole in it or the check valves are worn out. Depending on the age and use of your unit you may also have a sticking piston ring.
Aug 23, 2009 | Poulan Garden
My kenmore top load washer keeps filling, watere
the fill valve is bad or there is a hole in the tubing that attaches to it, this tube goes from the pressure switch to a bulb on the side of the tub only air pressure goes through this tube one small mouse bite and it is damaged
Jul 06, 2009 | Kenmore Washing Machines
Philips Projection TV Bulbs need changing
Buy a new television. The "bulbs" are actually small picture tubes, also referred to as CRT's or guns. There are three of them, Red, Green and Blue. The cost for the tubes alone will probably exceed the original purchase price of the television. If the new tubes do not have the lens assembly attached, then you will need to transfer the old ones. This involves draining, cleaning, and refilling the coolant chambers. Once installed in the set, there is a series of mechanical and electrical adjustments required, to get the picture aligned or converged. This procedure is not recommended for the inexperienced. If cost and time are not an issue, then everything can probably be found on the Internet. Simply search the web for your model number. You will need the remainder of the model number first. There are at least eight models starting with 46PP9302. You are missing three additional characters.
Discouraged yet?
Nov 15, 2008 | Philips 46PP9302 46" Rear Projection...
Samsung Manual Inflate Blood Pressure Monitor Logo
161 people viewed this question
Top Samsung Health & Beauty Experts
Marvin
Marvin
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
Joe Ball
Joe Ball
Are you a Samsung Health and Beauty Expert? Answer questions, earn points and help others
