Question about Cameras
The memory card is locked and I cant figure out how to unlock it...the camera wont take pictures and cant even erase the pictures
  • 3 more comments
  • LynnLewis May 24, 2008
    When I turn the camera on, it says "This card cannot be used." It won't let me look at the pictures or erase them. After a few minutes it turns itself off. I tried moving the tab up and down, but the card still won't work.
  • Anonymous Jul 18, 2008
    just slide the white tab on the card to unlock- problem fixed
  • Anonymous Jul 25, 2008
    i turn it on and it says "card locked" i can look at my pictures but i cant delete them or take anymore
  • Anonymous Nov 24, 2008
    cannot unlock card
  • Anonymous Feb 11, 2009
    I have the same problem. It won't unlock EVEN IF I SLIDE THE TAB BACK TO UNLOCK. and the camera isnt the issue either. I believe the problem is that the card is now defective for some reason staying in the lock position. I'm assuming the small parts inside that enable/disable the locking feature is broken and most likely won't be able to fix w/o opening up the card.
  • 477 Answers
Remove the memory card and look on the side of it their should be a little tab move it to the other possion and try the camera again. if that does not work with the card out gently tap the camera on the card side. and reinsert it their is a sensor that tells the camera their is a card inserted in it. it might be stuck. hope this helps.
Posted on Apr 24, 2008
Alright, so I'm an inexperienced 16 year old, but my grandfather's camera had the same problem. after looking at the card and the internal card slot in the camera and trying a few other suggestions I've found, none of which worked, I tried something new. For the card to be unlocked, the small tab on the side must remain in the down (towards the gold plates) position. The problem you are most likely having is this: when you put the memory card into the camera, the tab is being pushed to the up (lock) position. Try putting the tab down and sliding the card into the the card slot in the camera once or twice to see if it pushed back into the up position. If it is, then this is what you need to do..
Step 1) Take the memory card out of the camera.
Step 2) Slide the small (usually grey) tab into the down position.
Step 3) Take a paperclip and cut off a small section of it 1/8 inch long.
Step 4) Place this small piece of paperclip in the small space behind the tab on the memory card, so that the tab cannot be slid into the lock position. (for the paperclip piece to stay in place, you will need to hold the card in a sideways-upright position so that the paperclip's position is maintained by the card.)
Step 5) Carefully slide the memory card into the camera so that the paperclip stays in position behind the tab.
Step 6) Close the flap on the camera and turn on your camera.
That's it! I hope it works for you too!
Posted on Apr 12, 2009
If you have sandisk memory card there should be a little arrow pointing down with the word lock next to it. There is a grey tab on the side, if it is down, push it up. Now it should be unlocked.
Posted on Jun 15, 2008
Thanx a million ! It helped me !!!!
Posted on Dec 14, 2009
I was having a problem, where when i loaded either my old or my new memory card it would still say "card locked!"... so i took my memory card and battery out, opened up a paper clip, got a flashlight and looked in the memory card slot to find where the "lock" on the actual memory card lined up in there. I then ran my paper clip gently down the side where i thought the "lock/unlock" sensor may be in the camera itself (because i figured it was a problem with the sensor in the camera since it was doing it on both memory cards), loaded my memory card back in, and voila! it worked! i was shocked!
Posted on Oct 06, 2009
For some reason the memory card got locked and I can not figure out how to unlock it.
I can not delete pictures and I can not take pictures.
I would like to know if you can help me.
Posted on Apr 16, 2009
After locking memory card, do I then unlock it to take pictures and will that then erase the memory card or can you tell me how to so
Locking the memory card prevents you from taking and adding photos to the memory card. It also prevents you from deleting photos from the memory card.
If you want to erase all the photos off the memory card. unlock the memory card, go to the camera's Menu and scroll through the settings ti Format the memory card, then format the memory card.
Apr 10, 2013 | Cameras
My cammera is locked i dont know how and why i try to take picture it says THE CARD IS LOCKED i turn it on it says the same i pretty much cant do anything, how can i unlock it or fix it????
SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
There is also a software protection feature on some cameras, but this is used to protect a folder or individual picture from accidental deletion, not the whole memory. You set or release this protection from the camera menus.
If it is not that, then maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. Have you tried formatting the card in the camera? This would be one way of making sure that the camera can cope with the card, and it will also erase anything on the card. "SD" cards larger than about 1GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
Jan 08, 2011 | Casio Exilim Zoom EX-Z80 Digital Camera
The card, or memory chip in camera is locked, and i dont know how to unlock it, so now i cant take pictures, or upload my pictures, or even delete photos,i just need to know how to unlock my camera.
This used to happen when the write protect lock on in the memory card. Refer the manual to see how to remove the memory card.
After removing the memory card, unlock the write protect tab as shown in the fig. d7656e6.jpg
Apr 20, 2010 | HP Photosmart M547 Digital Camera
How to unlock a picture
Go to the playback menu and select it (you may have to adjust the circular option know to get to the playback menu). Once there, scroll to the picture(s) that are locked by using the sideways selection arrow buttons. Then select the up or down arrows, which will lock or unlock your picture. You can also erase any locked pictures, in case you want to, by formatting the xD card. Hope this helps.
Mar 25, 2010 | Olympus FE-210 Digital Camera
CARD LOCKED appears oo screen, camera wont work?
Does this camera take a memory card, separate from the built-in memory of the camera? If so, remove that memory card and look closely at all sides and edges, to make sure that there is not a read-only protection switch on it.
Many of these memory cards have tiny switches, sliders back and forth, that protect the memory from being erased.
If you slid that switch into the locked position without being aware that it is there, and without knowing that you did, then the error message makes sense.
Remove the memory card and look at it very carefully.
-a.
Dec 10, 2009 | Samsung Digimax L730 Digital Camera
How to unprotect the memory card
If I understand correctly what your asking what is the brand and size of the memory card. If I were to take a stab at it right now I would assume there is a lock/unlock switch on the card. Have you had this problem with the card before?
Good luck,
Lee
Jun 13, 2008 | Polaroid I533P Digital Camera
Locked memory card
There is a tiny switch located on the side of the memory card, might even say lock on it or beside it. Just flick the switch opposite of the way it is now and it should work fine after that. There might even be a small arrow showing which way to switch it. The reason for the lock button is "just" for this, so you don't accidentally erase some wanted pictures or someone else.
Jan 06, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Memory card
Sounds like to me that the card may be corrupt or the data on it is. I would suggest taking the card to walmart or another store with a picture kiosk machine and try to copy the pictures to a CD then once that is done format the card in your camera.
Oct 29, 2007 | Kodak EasyShare C613 Digital Camera
Cameras Logo
1,664 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
