Question about Intel D102GGC2 Motherboard
I replaced my hard drive, and upgraded my cpu and in the process of replacing them had issues with my Power SW, Power LED and H.D.D. LED wires. I seemingly figured it out and powered up the computer however it is not working properly. At first the cpu cooling fan came on then stopped and has not come on since. So as of now when I power up I see the DVD drive is working, I can see power to the keyboard but only the power supply fan works and there is no output to the monitor. Anyone have an idea of what is wrong?
    Brigadier General:
  • 10,406 Answers
It probably is the power-supply, if the CPU-fan does not spin.
Try a different power-supply.
Posted on Jul 31, 2010
Int sw
Green and white is normally the power LED connection, as I recall. I may be wrong. Anyway, you need to trace the path of the wires back to the case and see what it's attached to. You normally will have a power switch connection, a hard drive LED connection, a power LED connection, a speaker connection, and possibly a reset switch.
Jun 05, 2012 | ASUS A8N32-SLI Deluxe Motherboard
Hi, I have bought this dell vostro 1015 laptop one and half year ago. Day before yesterday my windows XP hanged and I was unable to shut down. So I pressed power on button for few seconds to switch off...
It sounds like your hard drive has gone bad. As this is a laptop you can try to reseat the hard drive, if that does not help then it might be a case of hard drive crash.
Oct 29, 2010 | Dell Vostro 1510 Laptop
L20 197 model (celeron) laptop.
In 19 years of working on computers I've seen 1 bad Intel CPU and it still worked it just showed the wrong processor speed. I'd eliminate the CPU being the problem. Generally if you have a bare system with motherboard, ram, keyboard and video and they turn on the system is good. The video may cause a crash if it's bad somewhere in the bootup process going into windows but it shouldn't stop the initial bootup process. The area I would likely suspect is the hard drive. If the arm inside the drive that controls the heads is loose it can cause the drive to read sometimes when cool and then to start slipping and not read when the system is warmer. If you can get into the bios there should be someplace there to check your temperatures and voltages. Those might be a suspect area. If the power supply isn't delivering the proper voltages or the CPU is getting hot could cause problems also. I'd like to hear more about what you're seeing on the screen when this system fails to boot. Does is show the ram countup, system devices and hard drives as detected in the bootup process? Or is the screen just blank. When it doesn't boot does the hard drive light blink continuously?
Oct 04, 2009 | Computers & Internet
Need help with enachine t2528 wiring power sw wire on mother board
If you open the CPU cabinet you will find the front panel connection pins at opposite right corner to the motherboard IO ports (where we connect all the power,monitor,keyboard,mouse chords) You can easily identify it as below these pins it will be named as P_Sw or P_Bt,Pw_led ,Hdd_led etc
May 09, 2009 | Computers & Internet
Wire came loose on pavilion xe 734 that supplie power to hard dir
First of all these wires don't supply power to HDD. These wires are for indicator LEDs on the front
panel of the cabinet. One wire `power sw' is to switch on the system from the power button on front panel. `power led' wire is of the power led on the front panel. All these wires will be connected to the cluster of pins on one corner of the mother board. If you can see it will be indicated & printed near the cluster of pins on the mbd, that which pair of pins is meant for what connector. Try to correlate the names on connector with the print on the mbd.
Jan 06, 2009 | HP Computers & Internet
Gigabyte GA-8INXP Motherboard Problem- front connector pins
If the wires from the reset switch is white/blue the blue wire is positive, Hdd red/white red is positive power Green/white Green is positive etc. The wires on the speaker connector will be red/black/black/white - red is positive. The colored wire is always positive. On all GA mb's the positive connection is always towards the back of the MB and are marked with a + on the base of the pin as you can see on the photo. Hope this help.
Sep 19, 2008 | Gigabyte GA-8INXP Motherboard
Central processing unit for Gateway computer
For a couple of hundred dollars you can get a much faster bare-bones desktop or tower and mb cpu combination and move your hardware to it. Upgrading your 450 isn't worth the trouble though jumpers on the board should handle upgrades to maybe 600MHz.
Nov 02, 2007 | Gateway 450SX4 P4-M Notebook
Intel D102GGC2 Motherboard Logo
56 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
