Cannot get a picture,TV switches off when pressing any button,do;nt k now how to tune tv in Mums tv and unfortunately she has lost the tv manual.
  • 1,476 Answers
You can get the manual at http://www.retrevo.com . I am not sure what you mean by the TV switching off when pressing any button? If you mean the TV will not turn on when pressing the on button I have a tip at http://www.fixya.com/support/r4425498-basic_standard_tv_troubleshooting which should be helpful. It explains the problem, how to fix it and where to get the parts.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on Jul 31, 2010
Programming my tv with a remote
you can program the channel manually, just press the menu button in the tv panel. select preset and then manual fine tuning to tuned every channel you want to watch and then save it.to make a manual fine tuning, press manual then select channel you want to tuned and then press vol. up/down button to search right frequency channel.do this process in every channel you want to tuned. hope this can help.
Sep 15, 2012 | Haier HL24XLE2 LCD TV
Tuning Konka TV Model K2166EZ
my konka tv gets the screen narrow and will never switch on when the switch button is pressed , so what shall i do?
Mar 11, 2010 | Televison & Video
We cannot tune our Wega TV
Here's the procedure:
  1. Press MENU.
  2. Press LEFT ARROW to highlight Channel Menu.
  3. Press DOWN ARROW to highlight Cable. Press CENTER BUTTON to select.
  4. Press DOWN or UP ARROW to highlight On or Off according to how you connected your TV. Press CENTER BUTTON to select.
  5. Press DOWN ARROW to highlight Auto Program. Press CENTER BUTTON to search for channels.
  6. After Auto Program finishes, press MENU to exit.
Nov 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have tried re-tuning my mums tv but all I get now is no signal with a countdown from 5 minutes before it switches off. I have tried going back into menu then settings etc but I'm not getting this come...
It sounds like you are not getting a signal from your antenna connection. Check the cable & connector which goes into the back aerial connection of the TV. It will switch off after 5 minutes because it is not receiving a signal & if you are getting the menu box then the TV is working ok.
Oct 07, 2009 | Televison & Video
Technika tt-16 universal remote control codes for a beko tv
Auto code search
1. switch on the TV and select a channel eg. Bbc1 on the TV itself
2. press the appropriate device button eg. TV
3. press the green SET button for approx 5 seconds until the red light comes on.
4. release the green SET button and point the remote at the device to be controlled, the remote will emit a test signal about every 2 seconds.
5. when the TV switches itself off briefly press the green SET button to store the code found.
6. when the red light goes out the search is ended.
7. try out the remote if it works follow the same steps to set it to other devices eg. DVD. If it does not work follow the steps again.
cover other remote sensors on other devices when setting the remote.
Nov 10, 2008 | RCA Universal Remote Control
Sony Trinitron TV Model # KD-28DL10U - Freeview problem since Aug 5
press the button to left of the 0 button on the the remote for digital display, then press the blue button on remote to display main menu. scroll down to auto tuning and press ok, then press red button to begin tuning.
hope this helps!!!!!
mark
Aug 16, 2008 | Televison & Video
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
My samsung tv wont turn on, red light keeps flashing on the front.
i had this with my samsung and my mums instead of pressing red power button press either switch from analog tv to digital button or just press a number
Jun 04, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
