Question about Airhead Kwik Tek Hot Dog 3 Person Towable
Need replacement center (largest) tube for 3 person Hot Dog. Where/how to purchase?
Hi. My dog won't take his worming tablet even mixed n food. I've heard that nexgard spectre chewable tablets may be the answer as they are given as a treat. What do you think?
They work, sometimes, but if your dog is to picky it doesn't do any good. However, I've had luck sicking it in a small peace of hot dog, just cut the hotdog in to bite size peaces and act like it's a treat. Get the dog excited and doing good and toss him a treat with medicine.
On the other side,
I have 1 dog that nothing works on, not chewables, not hot dog. I have just open his mouth and push the pill back in his throat. For this I purchase the smallest pill I can. I don't like doing it, but if it is back far enough he cant spit it out. If you grab his mouth correctly then you don't have to worry about him biting you either. I do it with a full size Doberman.
Jul 09, 2017 | Dogs
In 10 minutes, the top three finishers in a hot dog eating contest consumed a total of 143 hot dogs.?
it is like- x+12+x+x-7= 143
solving the above equation, we get, x=46
which implies, A consumed x+12= 46+12= 58
B= x=46
C= 46-7= 39
If you need more help in your homework, contact Assignment Help 4 Me Get Rapid Homework Help from Professional Tutors
Jan 04, 2017 | Homework
Hello, I have a Bock Model 32E water heater (oil fired). When I take a shower, I have 10 minutes of really hot water and that is it. My water heater will not turn on while I am taking a shower and it...
This has to be one of two problems....
Either the dip tube is not in place properly or the hot and cold are reversed....
That is the ONLY way that you can be having that problem....
Make sure you have another person look at the heater...
Take off the piping on both the hot and cold lines and VERIFY that the dip tube is in place in the cold side, and that there is NO dip tube in the hot side....then also that the pipes are connected correctly...
heatman101
Apr 08, 2011 | RTO Bock Water Heaters 32E 32 gal 104,000...
Dog chewed up plug in receptical on this heater. the cord is fine I just need to replace plug.Before I do I need to know which side of the 3 prong outlet is continuous hot(white)and which side is the shut...
the side with the largest **** in the plug is going to be your neutral or which should be white and the smaller side will be the hot which is black hope this helps you out...
Jan 08, 2011 | Honeywell HZ-617 Baseboard Heater
Dog chewed the gray water mist cord, can i replace the cord?
mcdevito75 here, Best bet, Look for any appliance repair center in your area for replacement electrical line. If your handy yourself or know a handy person, simply match up the electrical cord with another at your local hardware store, Splice the new cord into the old one.
Jul 27, 2010 | Windchaser Outdoor Misting Fan WC161 Stand...
Blue Screen
You have a bad blue picture tube. If you replace it the red and green will be weak and probably go sooner than you think. Everytime I had to replace a tube in a sony projo tv i had to replace all 3 picture tubes at the same time. It's very expensive if you don't have any type of warranty coverage.
C-Dog
Feb 10, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
How can I get a replacement charger and cord
you may go to your service center for this brand, and purchase a new one. you can also purchase from video cam centers with a different brand as long as the same specs, the same port, the same voltage requirement(input & output )
Dec 16, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Airhead Kwik Tek Hot Dog 3 Person Towable Logo
66 people viewed this question
Top Airhead Water Sport Experts
Marvin
Marvin
Bill Boyd
Tom Chichester
Are you an Airhead Water Sport Expert? Answer questions, earn points and help others
