Question about Poulan "" Push Mower
The poulan mower HD4QN20RE does not want to saty
The poulan mower HD4QN20RE does not want to stay on
  • Poulan Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all fuel and air passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me,
Thanks
Good Luck,
I hope this helped
Posted on Aug 15, 2010
    Problem Solver:
  • 7 Answers
Line leak or primer bulb is rotted - see below:
I have had this issue on several units (lawnmower and weed wackers) that are more than 5 years old. Most common problem in order most to least: Flexible fuel line is rotted somewhere (replace all of it), the primer bulb is rotted ($10 or less), the diaphragm in the carburetor is old/stiff/separated (rebuild kits or new carb).
If you rebuild, pay particular attention to the diaphragm position on old one and you will need to prime the carb heavily. Winter weather can cause varnish and so you will need to blast all orifices with carb cleaner thouroughly no matter on any rebuild.
Sometimes you can get a whole carb with primer bulb and it makes sense and $$ to just swap it all out. Ensure you change the fuel lines no matter what. Check eBay - I got a new name-brand carb kit for $5.00.
If you need to spend more than $50 in parts or service or both and the unit is more than 7 years old, consider a new purchase - don't waste your time as I did once.
Posted on May 03, 2012
Polan 14.5 rifding mower won't stay running when clutch released
Either a problem with the seat switch, or just make sure the block connecter that gose to the switch is fully pushed into the switch if its even slightly off it will stop the engine.
Jun 17, 2012 | Poulan Garden
I have a poulan 20"
Hi Sean,
Sounds like dirt in the carb.
Shut the gas off, or drain the tank, remove the carb bowl. There is a Jet in the stem of the carb where the fuel bowl screw was. you can blow air from a compressor up thru that and clean it out. also, clean out the screw that held the carb bowl on, there should be a couple small holes in it. Usually that will fix the problem, if not, then the carb would need to be taken off and rebuilt.
Sep 20, 2011 | Poulan "Poulan" Push Mower
Push lawn mower will start but won't stay started. Changed spark plug and filter. Does it have a fuel filter? Or what should I do next?
the way it sounds then, is the fuel metering hole in the carburetor bowl needs cleaned out. You clamp the fuel line, remove the nut off the bottom of the carburetor bowl, and clean out the passages in that nut. This should allow proper fuel flow, and let your engine fun full time.
Jun 08, 2010 | Poulan "Poulan" Push Mower
"Poulan" Push Mower: the mower will start but not stay running...
Have you checked the spark plug to see if it is fouled? If thats not it, maybe the air filter is clogged. If that still isnt the case try some B-12 small engines carb cleaner. Use it generously.
May 17, 2010 | Poulan "Poulan" Push Mower
Won't stay running
you may need to disassamble the carb and clean it thoroughly.
May 09, 2010 | Poulan "Poulan" Push Mower
My Poulan push lawnmower won't stay running
also check the fuel supply from the tank to the carb and the jets
May 09, 2010 | Poulan "" Push Mower
My poulan mower will turn on, but will not stay on. i have even tried to put carburator cleaner in it
your more likely need your carb over hauled and your sys flushed out. you may want to check your spark but i don't think this is your problem. We see this every day in our shop. bad fuel. fresh fuel at all times 24-7 stabilized all the time. Gas can't clean Gas
Oct 13, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Lawn tractor won't stay running if clutch is released.
There is an operator presence switch under the seat...it is more than likely faulty and must be replaced in order for the mower to run right.
Apr 28, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan "" Push Mower Logo
432 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
