Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Is there a way to change all of the settings back to normal. I hv messed with my camera so many times I don't know what I have done? Also what is the easiest way to change it just to night mode?
  • gbkc05 Jul 31, 2010
    Yes that was very helpful. Thank you very much
  • 10,515 Answers
For reset to default settings, you need to go into setup menu > 2nd folder ( the one with the tools icon ).Scroll down till you get to ' Reset all '. Select OK and then the Function / Set button.
You could also consult your Advanced user's guide - Page 28.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 31, 2010
This is a Disney watch. Somehow I messed with it and changed it to military time. Does anyone know how to change it back.
One of ur buttons is a "set" button..press it a couple of times or press and hold it for a few seconds..the screen will read "12h or 24h..make sure it clicks on 12 or 12h and that will change ur time display back to normal...
Dec 05, 2012 | Televison & Video
I just bought a Fujiflim Finepix L55 last week and now its screen becomes too bright that cannot see things clear, it comes suddenly, I try to reset all the setting but didnt help... the picture took still...
Its new, don't mess about with it, take it back to the seller and ask them to replace it under warranty. If you start to mess about with it, you may void the warranty.
Mar 03, 2012 | Cameras
Hello guys, please only reply if you have a realistic solution. I have a JVC HM100 camcorder and I have recently attached a cheap wide angle converter. Since then, my trouble started. When I take it off,...
When was the last time you white balanced your camera? I can't say for certain, but it sounds very similar to a problem I use to deal with all the time.
  1. set the ND filter according to the lighting
  2. set the WHT.BAL. switch to A or B
  3. locate a place with similar lighting conditions as the subject, place a white object near the center of the screen and zoom in to fill the screen with white
  4. press the auto white balance button
I got all of this from the manual. starting on page 35. I hope this turns out to be it. Let me know how it works out!
May 10, 2011 | JVC GY-HM100U High Definition Camcorder
I am taking twelve, one page documents and converting them to a unified 12 page document. I have done this several times & everything works perfectly. This year, however, when I select the pages to...
I do not know what program you are using but it sounds like you may have a default paragraph or character style set up in the target document. For example if the document that you are copying from has a normal style that has bold setting and then you copy it into the target document that has a normal style with say italics, the normal style in the target document will apply.
This is the case in programs like quarkxpress and indesign. Hope this gives you some ideas to help you out.
Dec 09, 2010 | Computers & Internet
I messed with some of the picture settings and now i can't figure out how to change it back to normal.. help?
Go to the menu find reset
Initialisation
All camera menu and function settings will be restored to their
default values. However, values for DATE / TIME, LANGUAGE,
and VIDEO OUT will not be changed.
- Sub menus
[Yes] : A window to confi rm the
selection will be displayed.
Select the [Yes] menu and
all settings will be restored
to their defaults.
[No]* : Settings will not be restored to
their defaults.
May 06, 2010 | Samsung TL100 Digital Camera
I have the Red Blinky Light Deal
your power supply is turning the tv off because of a higher than normal drain on on it . it could be anywhere in the set . but most of the time but most of the time its in the horz dirver or output , hv driver thansformer (flyback) or hv spliter system . it might even be in audio or in the power supply itself . you will need the service manual a good trvm and a scope . to go through the system by system .injecting signals when needed to make parts of the set come alive ....... messing with this set without proper tools and training may kill you . there are high voltages in this set that will kill even if the set is off and unpluged for a week .i can provide test point volts and waveforms and voltages that you should be looking for if you know of someone (or yourself) with the equipment and know how to make the tests .... please let me know ..............if this answer helped please rate 3 or 4 stars if you think i was a waste of time please dont rate at all a 1 or2 may knock me out of the paid answer department and right now the shop is slow so i need the $$ .......i have all the flow charts on your tv if i can help you look something up please ask thanks
Apr 07, 2009 | Toshiba 57H81 57" Rear Projection...
When I try to use the timer for a family photo the pic is blurry.
hi check if there is a setting called macro or maybe on your camea there is a symbol that looks like a flower that is for taking close up photos if that is on then your photos will be blurry if this works can you let me know thanks
Dec 20, 2008 | Kodak EasyShare P850 Digital Camera
Flash settings Sony DSC-H7
I had the same problem with my DSC-H9. The flash setting is set off when in BURST record mode. Go into MENU, scroll down to REC Mode, change it back to NORMAL.
Now go shoot someone or something... with your camera of course!!
Mar 12, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Konica Minolta Dimage x1 solarizes all pictures so that they appear as negatives
Send it back - obviously didn't do a good job on this one. They will give you another Don't mess with it.
Jun 21, 2007 | Konica Minolta DiMAGE X1 Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
