Question about Dryers
FDE436RES1 - Frigidaire Overheating
This model dryer has suddenly decided to get freakishly hot to touch on the back panel and the top right side. I have completely taken the machine apart and cleaned it and the dryer vent hoses. The issue is still occuring. My gut tells me thermastat, but doesn't that usually mean the heating lelment quits vs. overheating? What might the issue be?
  • Anonymous Mar 26, 2014
    Our Samsung dryer lately has displayed runing lights in a rectangle with a hourglass timer. A bell rings right before this occurs. We've had the vent cleaned out and hose replaced but the chasing lights issue occurred again. What do the lights and hourglass mean?
    Genius:
  • 1,028 Answers
Tstat possible but make sure vent is open completely to outside ..may try load with rear hose off to verify
Posted on Apr 27, 2008
Top of dryer and the back panel get too hot.
Of course they get hot, that is normal.
Jun 30, 2017 | Frigidaire AEQ6700FS Dryer
Takes forever to dry clothes on a frigidaire modle# fde436res1. The exhaust seems tobe hot and everything looks ok.
Check for blockage / lint buildup in the exhaust tubing. Also pull the hose off the back of the dryer and look for lint buildup inside the dryer as well.
If your dryer is electric, you may also have a heating element that is burnt out.
Nov 27, 2009 | Computers & Internet
Dryer squeak and back panel is hot? Frigidaire Dryer FDE436RES1
It sounds like you have a rear bearing bad.
as far as over heating check the vent line. Your thermostats are ok or your high limit would blow and you would have no heat.
Sep 01, 2009 | GE DBXR463EDWW Electric Dryer
Frigidaire dryer overheating and shutting off mid cycle
Usually dryers have the exact opposite problem where the heat does not come on. Because most dryers have thermocouples (rated at 150 & 185 degrees) to prevent the dryer from getting too hot. You may have the blower fan come off of the motor. Check and see if you have air moving out of the vent. Also unplug the dryer and take the back off and inspect the area where it is getting hot. It may be some wires touching the case. Sometimes you can see the problem or smell something getting too hot. Either way be carefull. A dryer that overheats is a fire hazard!
May 18, 2009 | Kenmore 24032\24036 Top Load Washer
Frigidaire electric dryer; model # FDEB34RGS1- gets TOO hot!
I could not find the model number you listed. I also would be very concerned about over heating until we can find and locate the problem. Look inside the door and compare number with the on listed here at Fixya. Thanks, Sea Breeze
Mar 25, 2009 | Frigidaire FGR341AC Electric Dryer
Frigidaire dryer is overheating
Sound like the limit switch on the dryer is faulty and needs to be replaced. Hoped this helped
Mar 14, 2009 | Frigidaire Dryers
Squeeling noise when dryer runs
Replace the dryer rear drum support bearing.
Problem will be solved.
Feb 22, 2009 | Kenmore 62622 Electric Dryer
Very hot to touch on top
Sounds like you have a clogged vent hose or clogged duct work leading to the outside of the home. Make sure you have no obstructions in the exhaust system including a functioning flap on the outside wall cap.
Jan 03, 2009 | Frigidaire GLER341A Electric Dryer
the other tstat is on front of blower housing..lift top remove screws at top of front panel from inside remove switch wires front lifts off ..be sure to ck vent first most dryers have thermal fuses that will blow if overheating does occur since yours seems to be working i would suspect vent first..if your concerned about dryer being hot to touch along top rear this is normal heating element is located just below console at rear
Nov 13, 2008 | Dryers
Dryers Logo
243 people viewed this question
Top Dryers Experts
