Question about Whirlpool Refrigerators
Whirlpool refrigerator model ED5RHEXNL03 side-by-side not cooling and freezer ices up. Defrosted freezer completely but fridge side still won't cool below 60 degrees.
    Brigadier General:
  • 3,917 Answers
Hi
It's the defrost timer switch that needs replaced. Sometimes it's the fan motor. You can change out the fan motor yourself. Just call around to your local appliance parts store and get the right fan motor for your fridge. Motors are about $30.
The defrost timer switch would have caused your coils to get frosted up solid with ice and the fan still running as usual. So no, I don't think it's your defrost timer switch at this point.
It's the fan motor. Had you said the fan wasn't running I would have said "Fan Motor" and not defrost timer switch. I've had previous experience with both problems.
http://www.ehow.com/how_2294818_troubleshoot-whirlpool-refrigerator.html
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 31, 2010
  • paugus Aug 02, 2010
    Thanks for the reply. Now my wife informs me that the freezer isn't cooling properly either (the icemaker is working though). Do you still think it's the fan motor.
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
On my Maytag side by side, stainless steel fridge, Model #: MSD2651KES. The freezer works perfectly, but the fridge will not get cold, but if you open the freezer it will start sending cold air to the...
Its defrost problem.--------- When you open the freezer door, then ice starts getting defrosted, because outside temperature is warm and due to that inside ice gets bit melted.--------- -------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is blocked by ice, because your refrigerator is not defrosting.But when you open the freezer door, the inside ice gets bit warm and it starts melting and this lets the fridge section get cool.------------------- In this case you will have to manually defrost the ice and inspect, if the problem solves.For manual defrost procedure, click the link below:-------- Click this below for more detail:--- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech.
Aug 11, 2011 | Maytag MSD2657H Side by Side Refrigerator
.everything defrosted, ice on back
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 27, 2011 | Whirlpool Refrigerators
Whirlpool 6th sense side by side fridge/freezer 25rid4 model,freezer working fine but fridge part does not cool
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Defrosted liquid will not drain
heatman101
Oct 27, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My regrigerator (GE Profile) is not cold on the fridge side, but ok on the freezer side. I found ice buildup in the freezer so I defrosted and dryed it completely, cleaned it- including coils...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 16, 2010 | GE Refrigerators
Water is leaking inside the refrigerator and the ice cube aren't freezing completely (cube is a hollow shell of ice)
Possibly it is because fridge is not cooling correctly(Ice cubes hollow).. Suggest proper defrost. if it is cooling partially, it shows cooling is trying to take place (Make sure before you switch on after defrost, check for proper water drainage.Water must flow to the compressor once defrosted.Take note if the fan runs correctly.
Sep 20, 2009 | Whirlpool 18.9 cu. ft. Top Freezer...
Refrigerators Logo
85 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
