Question about SmartDisk FireLite 60 GB Hard Drive
Do I need a pwer cord for theis model or will it
Do I need a pwer cord for this model smart disk FWFL60-N or will it run off of the firewire
    Brigadier General:
  • 10,406 Answers
Look at the connectors on the outside of the case.
If there is a socket for an AC adapter, then it requires one.
If there is no such socket, then none is required.
Posted on Jul 31, 2010
NEED POWER CORD FOR SMART PLANIT MODELDR3
drink o matic power cord Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on drink o matic power cord related issues. ... Drink-O-Matic model DR-3 Found a smart matic model DR-3 Drink-O-Matic, the ... Drink-O-Matic model stopped working Hi, I have a Smart Planet ...
where can i find a power cord for a drink o matic coke machine ...
https://answers.yahoo.com/question/index?qid...
Dec 20, 2010 - Best Answer: Found this link to a company that sells the "drink o matic". Contact them for prices at http://www.esbuys.com/contact-us.html or ...
Oct 29, 2015 | Refrigerators
How do i boot my mac book air in fw mode?
FireWire booting, as the name implies, is the ability to start up a computer from an internal or external FireWire drive.
FireWire booting is possible on all Macintosh models that have built-in FireWire ports with the exception of the Power Macintosh G3 (Blue & White) and the Power Mac G4 (PCI Graphics) models. You may need to upgrade the computer's firmware before FireWire booting will work. You can download the latest firmware for your computer from the Apple Software Updates Web site at http://www.apple.com/swupdates.
Note: Do not confuse FireWire booting with FireWire target disk mode as described in this article: "FireWire Target Disk Mode".
If you are unsure if your computer has a FireWire port, look for ports that look like those in Figure 1, or look for the FireWire symbol shown in Figure 2.
[img width="68" height="29" src="http://km.support.apple.com/library/APPLE/APPLECARE_ALLGEOS/HT2699/58606_1.gif" alt="" data-hires="true">
Figure 1 FireWire Port
[img width="59" height="56" src="http://km.support.apple.com/library/APPLE/APPLECARE_ALLGEOS/HT2699/58606_2.gif" alt="" data-hires="true">
Figure 2 FireWire Symbol
Follow these steps to start up your computer from an external FireWire drive:
    1. Ensure the proper drivers for the FireWire drive are installed in your computer.2. Connect the FireWire drive to your computer and ensure the icon for the disk appears on the Finder desktop.
    3. Install the appropriate system software onto the disk.
    4. Open the Startup Disk control panel and select the FireWire disk.
    5. Restart the computer.The computer should now start up from the FireWire drive. If it does not, make sure you are using third-party drivers that support FireWire booting. Also ensure that the FireWire disk mounts to the Finder desktop and that the system software was properly installed. If it still does not mount, contact the vendor of the device to ensure it can be used as a startup disk.
May 28, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I have a Firelite Smartdisk External 60G hard drive - Model #FWFL60-N which I bought to back up my previous MacBook. It only has FireWire outlets and cable with only FireWire ends - no USB port...
Hi Selina It was a big mistake for Apple to omit the FW port on the white MacBook. The problem you hilite is the reason I don't recommentd the macbook to any of my clients. However, the problem is solveable - although you may/will have to do some breaking and entering.
There is no cable adaptor - nor will there ever be, the protocols are so radically different that they can never talk to each other.
The simplest option is to connect your drive to another mac that has got FW (800 or 400 - it doesn't matter as long as the cable will connect the two units) then use file sharing to transfer the conent of the drive to you MacBook either by ethernet (preferable) or by wifi (much slower).
The breaking and entereing option imvolves opening up the firelilte and removing its HD (it's easy) then get a unit like this Overview or this http://www.maplin.co.uk/sata-hard-drive-usb-docking-station-222999
There are other much cheaper units and they all work fairly well. I have several as I'm up against your problem regularly
Apr 01, 2011 | Computers & Internet
External Super Writemast DVD drive is connected via Firewire. The S.M.A.R.T. status says "Not Supported" on my imac os 10.6.6
The S.M.A.R.T. status is used to communicate information about a Hard Disk Drive.
Since your product is a DVD drive, it not does send S.M.A.R.T. information so MAC list it as "Not Supported" for that feature.
It is normal with a DVD drive and you have nothing to worry about.
Regards,
Jan 14, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Apple mac G5 freezes when booting up.
Try unplugging all Firewire/USB devices. Also, unplug the power cord from the computer. This resets the logic board. If that doesn't isolate the problem, put your Original system CD that came with the computer and hold down the C key. Boot up and run Disk Utility. Run the repair disk and then repair disk permissions. Reboot and try booting your system again.
Jan 03, 2010 | Apple PowerMac G5 Dual Mac Desktop
The hard drive powers up but wont connect
Is the FW drive have been formatted? You may need to run the Disk Utility on your Mac to use the external drive. Make sure you choose FAT 32 as the format option if you want to use the drive in both Mac and Windows machines.
Mar 31, 2009 | Computers & Internet
Macintosh computer not recognizing the LaCie external hard drive
1. If you have another firewire device test this device with the same firewire cord you are currently useing for the LaCie. (if there is no reasponse form the other device then it is the cord it's self) If not then 2. Check the Leads on the back of the LaCie where the firewire plugs in if the copper looks tarnished use a ear swab dipped in Lime Away or CLR to clean it then wait for it to dry and try the cord again. 3. if these physical connections are in good connection with each other and the firewire in port on your computer and on the LaCie are good then. Run a "Permissions" verify and repair through the disk utility program on your Mac with the LaCie turned on and plugged in.
FINALLY if none of these options repair the LaCie you may have to open the LaCie up and check to make sure the soldering from the firewire to the chip set is still in tact. I hope this helps Happy Macing.
Mar 28, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Having Problem with both LaCie hard drives being recognized on both macs
Try to connect to another computer, and see if it recognizes the drive. If Not, you can dismantle LaCie and take the disk out.
Connecto your disk to another external box (USB or Firewire) so you can have access to you data.
Jul 04, 2008 | LaCie (300740) 160 GB Hard Drive
SmartDisk FireLite 60 GB Hard Drive Logo
113 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
