Question about Vacuums
Have a Hoover Steamvac Model #F7426-900 - Series AA12.0 On the bottom of the clean water tank and the detergent container, the gaskets leak and water constantly drips from the tank. How do you repair this?
    President:
  • 1,673 Answers
Inspect under the seals to see if the tank hasn't cracked, which is usually the problem. If it is a new seal that is needed, part #43513026. If a new tank is needed, part #42272104.
Posted on Apr 24, 2008
Hoover SteamVac LS F5899-910
Did you try to clean first the unit..
Jun 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover F7425-900 SteamVac V2
http://www.hoover.com/pdfs/manuals/F7452900.pdf Heres a link to the manual if you dont have one, Ive emailed them and they gave me the same solutions that are on page 17. ? Make sure tank is securely locked in position ? Clean water tank or detergent container empty ? Refill container according to instructions for surface being cleaned ? Recovery tank lid not on correctly ? Make sure lid is firmly in place ? Valve cap clogged ? Remove and clean valve cap (see following instructions) 1. Remove clean water tank. 2. Turn valve cap (A) counterclockwise and remove. Soak valve cap in warm water for at least 15 minutes. Wipe cap dry. 3. Align slots (B) on cap with tabs (C) in opening. Turn cap clockwise to tighten.
Sep 17, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
How do you remove the lower handle?
Check the clean water holding tank. I had this problem and found that was a crack near the outlet on the bottom of the tank. I replaced the tank and resolved the problem. I have taken this machine apart several times, if the tank is not the problem with yours, check the water tube.
Apr 26, 2015 | Hoover F7425-900 SteamVac V2 Widepath...
There are two containers, where do I put the water and solution
The upper tank holds the cleaning solution. Mix 5 oz. of Hoover detergent to 1 gal. of hot water. The line on the tank indicates 1 gallon.
Apr 10, 2011 | Hoover SteamVac F5914-900 SpinScrub...
My hoover steamvac wont **** up dirty water float
Check your filter screen insde the upper tank. if your model has a wrap around filter try to pull it down about 1/2" to maximize air flow.
Apr 15, 2010 | Hoover F7431-900 SteamVac Vacuum
I have a Hoover V2 Steam Vac widepath and the
This is a notorious problem with the Hoover V2 SteamVac's. In fact the tank design by Hoover on your SteamVac was so bad, that Hoover redesigned this tank almost immediately due to the numerous problems customers were having.
For your particular problem, you really have two options. The first option is putting a bandaid over the problem, but will still fix it. We sell the entire gasket assembly on the bottom of the detergent tank as a replacement part. Unfortunately it's sold together with the seal, spring, and valve together as an assembly;
http://www.govacuum.com/hoover-steamvac-dual-v2-tank-valve-part-43513015.html
You also may wish to fix the problem completely by replacing the entire clean water solution tank. Hoover has redesigned this tank, and the new one I don't see near the amount of problems that I do on the older style tanks. The plastic is much more sturdy, and less prone to having the gasket and valve issues that the old tanks do. It's important to point out that the new tank does not come with the handle. You'll need to remove the handle from your old tank if you buy a new tank assembly complete. Rest assured that if you do purchase any part from GoVacuum, you'll have 60 days to return it for a full refund, just in case the repair doesn't work. Not only do we not deduct restocking fees or shipping charges, but we also include a return label with every order that you may use to return any item to us, and we'll even pay for your return shipping!
Here's the Hoover SteamVac V2 Clean Water Solution Tank, Part 12002549
If you'd like us to do a repair photograph series on this repair of the valve and gasket assembly, please just request a repair clarification here on Fixya, and we'll be happy to do so. If you found this helpful, please be sure to rate the review as helpful by clicking on the 4 Thumbs Up Icons in the top right hand corner of the repair.
Thank you so much,
Chris J.
GoVacuum
Mar 23, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover steamvac F5826-900 leaks from bottom wheni put tank on ple
You may need to replace the gasket.if that dont work replace the whole tank
Aug 01, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover V2 SteamVac
Under the detergent side, there is a metering plate,(located on the machine) which can be removed. ensure that this is installed. have you verified whether the machine will dispense detergent only without any water in the water tank?
Jan 03, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Replacing valve on water tank on hoover steamvac
buy the whole tank not worth the time to repair the valve
Oct 08, 2007 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Vacuums Logo
177 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
