Question about Neff U1721 Double circotherm Electric Oven
My Neff U1721 element went with a bang. We have replaced before on 3 occasions successfully - but the elements have not lasted very long. On this occasion have replaced element - but not working. Please could you advise Kind Regards Helen
  • David Unite Sep 16, 2012
    Hi Helen, did you solve the problem?
  • 10,865 Answers
Hello Helen. You should not have to replace the elements often unless you are a commercial establishment using the ovens constantly. If you are commercial you may not have any thing wrong. Otherwise, I would recommend that you check the wiring that feeds the elements and those connections. If the connection to the element is loose you may be getting intermittent sparking which would shorten the life of the heating element. J.
Posted on Jul 31, 2010
My Neff U1721 bottom oven has just stopped working - the fan still works, although is a bit noisy - what could be the problem/
Sound like the element has burnt out but if your fan is also noisy it is probley running slow which may have caused the element to overheat and burn out so it would be a good idea to replace the element and the fan motor
Regards
Ian
Apr 20, 2011 | Neff U1721 Double circotherm Electric Oven
Hi - have a Neff U1721 double oven, the element in main oven went bang cracked the element and blow a hole in fan cover. replaced the element but now temp light comes on but doesn't heat up, can you...
Test element check for continuity across the terminals and it is getting power when switch onon. If both ok, chances are the front selector switch has blown.
Feb 01, 2011 | Neff U1721 Double circotherm Electric Oven
My Neff U1721 oven does not heat up, Element
YOU CAN BYPASS IT HOWEVER BEAR IN MY THIS IS A SAFTEY DEVICE AN MAY HAVE FAILED BECAUSE OVEN OVERHEATED,( FIRE RISK PRESENT) IF THIS IS THE CASE, A BYPASS SHOULD BE CONSIDERD VERY TEMPORARY.
Jun 10, 2010 | Neff U1721 Double circotherm Electric Oven
Neff U1721 repeatedly trips RCD. Have replaced lower element 4 times in last 18 months am I likely to have an underlying earth fault, or are "cheap" elements more prone to failure
Sounds more like the power supplying the oven is at fault. Need to make sure that all power is correct from stove to box. Very unusual for that many elements to be going bad.
Feb 04, 2010 | Neff U1721 Double circotherm Electric Oven
The bottom (fan oven) of my Neff U1721 made soft bang noise and failed. The fan stopped, the oven light went out and the thermostat light. I replaced the burnt out heating with a new element with a 32.5...
The power to the fan and thermostat is the fault. You will need to trace wiring from these elements to power source and I suspect that where the power cord meets the oven is where you'll find the cause.
Dec 15, 2009 | Neff U1721 Double circotherm Electric Oven
Lower oven not heating up everything else is working fine
hi, we have had the same problem. You can order the element from many places online, the cheapest is about £25 ranging up to £60 from neff themselves. Fitting it is ok the hardest part is getting the fan off to change the actual element. However, be warned, we are now on our 4th element and it just went again last night. Neff deny that this is a known fault that the elements keep going. However, at least 10 of our neighbours have had the same problem with their oven too!
Jan 18, 2009 | Neff U1721 Double circotherm Electric Oven
3rd blown element
no connection between lights on fan. problem is that bulbs these days are poor quality (but cheap)
it is common for these circular elements to go. usually last about 2 years. worth checking tho that fan is turning at right speed
Jun 21, 2008 | Neff U1721 Double circotherm Electric Oven
Neff u1721fan oven element has been replaced 3 times in two months
is it the right voltage?is the new element screwed tight when fitted?they should last alot longer than that--Ire close bye.
Nov 26, 2007 | Neff U1721 Double circotherm Electric Oven
Neff U1721 Double circotherm Electric Oven Logo
202 people viewed this question
Top Neff Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
