Question about Whirlpool Duet GHW9150P Front Load Washer
Standing water in washer front load tub
After 24 hrs there is an inch or two of standing water in the front load tub
  • Whirlpool Master
  • 2,605 Answers
Welcome to FixYa.
Based on your description you likely have a faulty inlet/water valve.
Here`s an easy way to confirm or dismiss whether it is the vavle or not.
1) First drain the standing water which presently exists.
2) Unplug the washer from the wall/power outlet and allow the same period of time to pass, if the unit has standing water in it afterwards you need a valve.
If it doesn`t have water in it afterwards then the valve is being energized when it is plugged in even when it should not...that indicates a faulty control unfortunately, but not very likely,
The valve is part # 8182862 and varies in pricing around $40 - $75. It should be available at most brick and mortar appliance part locations or if you prefer on-line shopping try "searspartsdirect.com" "repairclinic.com" or "appliancepartspros.com" to name a few.
To swap out the valve simply follow these steps...
**Unplug the unit from the wall before attempting any repairs suggested here...safety first**
1) turn off the water and unfasten the hot & cold fill hoses going to the washer.
2) remove the three screws along the back of the top panel and then slide the top panel back slightly and pull up. The panel should lift away.
3) in the left rear corner ( when observing from the front of the washer )you should now see the valve which will look like this...
4) remove the wires, carefully the harness has little release tabs which must be bent back slightly to pull the wire & harness off.
5) remove the hose to the dispenser assembly, a pair of pliers or visegrips works well here.
6) remove the screw on the outside back wall of the washer and pull the valve out, voila !
Reverse order to put the new one in and good job. You potentially saved yourself $200 or more for parts and labour.
Hope this answers your question but more importantly solves your problem.
Thanks for choosing FixYa for your repair solutiuons today. Let me know if you need further assistance.
Please take a moment and rate the soluytion provided for you as well as a testimony if you feel it warranted.
Good luck.
macmarkus :)
Posted on Jul 31, 2010
Standing water
do you see water in tub?
if you are just spinning tub and hearing sloshing that is the liquid in balance ring and is normal
Apr 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
Tip
Does anyone know if this fix applies to the Kenmore Super Capacity 3.5 front...
I CAME TO THE SITE WITH THE PROBLEM OF MY WASHER NOT DRAINING. I HAVE HAD PROBLEMS WITH THIS FOR MONTHS. TAKING THE HOSES OFF. CLEANING THEM ETC... TODAY I FOUND THE BEST SOLUTION.. THE WOMAN WHO POSTED THAT SHE SAVED HER HUSBAND $300.00 BY TAKING THE BOTTOM OFF WASHER WAS RIGHT.....
BOTTOM OF FRONT LOADER.. THERE ARE THREE SCREWS.. YOU NEED ONE OF THOSE NOT PHILLIPS BUT ROUND LOOKING SCREW DRIVERS(SORRY).. ANYWAY TAKE OFF THREE SCREW.. ONE ON LEFT, RIGHT AND MIDDLE.. THERE IS A WHITE DRAIN HOSE WITH A CAP.. VERY HEAVY PLASTIC FRONT. IT IS HARD TO TWIST OFF CAP BUT KEEP TRYING. ANYWAY IT IS GONNA GET REALLY WET.. SOME WATER CAME OUT AT FIRST BUT I WAS NOT CONVINCED.. SO UNDRNEATH I STARTED TO SQUEEZE THE HOSE AND OUT POPPED 3 SOCKS AND AN ERASER.. THEN ALL THE WATER THAT WAS IN THE WASHER THAT WOULDNT DRAIN.. EVERYTHING WAS SOAKED INCLUDING ME AND MY SON SO BE READY WITH LOTS OF TOWELS. BUT IT WORKED. IM HAPPY TO SAY IM DOING MY FIRST LOAD NOW AND EVERYTHING IS RUNNING BEAUTIFUL...
on Feb 23, 2009 | Kenmore Elite 45986 Front Load Washer
Found standing water in the tub when about to
The problem is usually caused by either a water inlet valve leaking by, or a pressure switch malfunction. The following link explains:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
Included are tips on how to diagnose the problem and parts sources, if required.
The odor problem is a different story. Front loaders are notorious for musty odors, mold and mildew. A little diligence can help minmize potential problems and keepthem from coming back. The following link explains:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
Read through the link provided. In many cases, the problem is attributed to debris lodged in the drain pump reservoir, or some things the consumer should (or should not) be doing (e.g. using improper detergent or not leaving the door open when not in use). I personally own one of these washers and have never had an odor problem in the 8 years I've owned by following this regiment. It DOES work.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Standing water after nonuse
You need to clean out the drain pump. usually located at the bottm fron of machine. clogged drain pump = standing and very stinky H2O.
Jan 18, 2010 | LG WM-2277HW Front Load Washer
Sewer smell when I use the front load washer
try rid-x see if that helps pour down drain pipe for washer then add water you may also want to pour rid-x through toilet as well and bleach out washer
Dec 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer tub slowly (over several days) gets water inside
yes this is more than likely a leaking inlet valve, to confirm turn of water at wall valves
Sep 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Standing water in the tub
bad inlet water valve --turn water supply off and watch to see if machine continues to fill with water --suggest removing inlet water lines from machine and inspect the strain screens on the machine for sediment build up if so clean
Aug 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Gentle cycle did not complete leaving water standing in the tub.
Whirlpool downloader washer model number GHW9150PWO
PROBLEM Gentle cycle did not complete leaving water standing in the tub
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Standing water in washer after cycle
take off the bottom front panel and clean the coin trap it will be up front just unscrew it have some towels handy
Dec 20, 2008 | Whirlpool GHW9400 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
489 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
