Question about Refrigerators
I'm using a kenmore refrigerator as a kegerator and I need to know if there is anything I should be aware of on the side of the fridge walls as I have to drill a hole into it to attach the hose from the keg inside to the beer tap on the outside.
  • 145 Answers
Any lines that run through the cabinet should go up the back or and/or around the door. I would carefully cut a hole in the liner and pull the insulation out in small peices just to make sure.
Posted on Apr 24, 2008
Danby Kegerator runs but does not Cool
sounds like maybe no coolant in system if compressor is working. you know like in your car a/c unit, sometimes refrigerant needs to be added. just a guess, I'm not an expert.
Nov 08, 2012 | Danby DKC645BLS Compact Beverage Cooler
Freezer is at -10, Refrigerator is at 52. hat is causing this? Model 106.53562202
check and see if there is anything blocking the side to side vents in inner wall- small1x1 vents,also ,anything hanging past edge of selves in fridge side causes air not to move around like it should - can cause drastic temperature swings
May 30, 2011 | Kenmore 53562 / 53564 / 53569 Side by Side...
My Kenmore Refrigerator is not refrigerating
if the freezer and fridge are warm check the start device on the compressor,alot of times you can smell a burning oder when this pops,also you can remove it and shake it,if you hear pieces rattling around then it's bad,also if there's ice on the back inside wall of the freezer then you have a defrost problem,also when you open the freezer door do you hear the fan blowing,if not you could have a bad defrost fan motor,open the fridge door,up near the ceiling on the right side you'll see the model number,send it to me,let me know if you found ice or frost on the back wall of the freezer or what you see and i'll be glad to help you
Oct 31, 2010 | Kenmore 53642 / 53644 Side by Side...
Two door side by side fridge middle wall is hot ,fridge not working very well ,5 year old kenmore ,any soloution ?
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 14, 2010 | Kenmore 53642 / 53644 Side by Side...
Kenmore side-by-side not dispensing ice or water, the ice maker has been replaced, no water going into the tray. I cannot locate the water filter, does this model have one?
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
Jun 29, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
Connect ice maker
Almost all ice makers have a plug on them and the fridge has a corresponding plug. If you cannot find the plug in the Fridge - look in the area of the ice maker for a plastic plug in the wall of the fridge. If you've added this to the fridge after the fact then you may need to fish out the plug from the wall of the fridge.
Aug 06, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Burning smell and dead mini-fridge/kegerator
If the compressor is being used for extended times without resting or getting the product cooled, could be the problem. On small refrigerators the inside is sized for the work load. The condenser coil on back or in some cases under the outside skin of the refrigerator is designed to cool the area inside by releasing the heat from inside.. You may need to modify your cooler to handle such loads with more cooling capacity and condenser with fan to help bring the product temps down more efficiently. Let me know, Thanks, Sea Breeze
Mar 19, 2009 | Sanyo SR-4912M
Need to unplug fridge- Whirlpool Gold Side-by-Side
you will have at least a foot of flexable water hose. Pull it out slowly to make sure its not tangled.
Jan 05, 2009 | Whirlpool GD5SHAX Side by Side...
Kenmore Side by side model # 25357682790
is the freezer fan working?is there frost in the freezer on the walls?can you find the defrost timer?let me know and we can go from there-mike
Oct 15, 2008 | Kenmore 53542 / 53544 Side by Side...
Kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
