Question about Maytag M7DH65B2A Dehumidifier
Dehumidifier works fine but every now and then the fan is very noisy, as if it is loose or hitting something. Is there a way of checking to see what is happening?
  • 6,993 Answers
With the unit unplugged, open the cover and check the alignment of the fan. If the fan is stuck or rubbing against the fan cowling, adjust the fan motor's mounting hardware so that the fan turns freely.
Good luck.
Posted on Jul 31, 2010
    Sergeant:
  • 170 Answers
Yes. remove parts to allow you room to see the fan and UNPLUG IT FIRST.
turn the fan and look if its hitting something. also look if the fan seems to be bent or damaged. wiggle it to see if it may have come loose also
  • mlouie Aug 24, 2010
    Does anyone know where I can get a replacement fan for this dehumdifier? Two of the fan blades have broken and the fan now is "out of round" and needs to be replaced. Thanks.
  • 10,865 Answers
Hi. If it is, the noises are probably caused by loose, vibrating parts.After disconnecting the power:
1) Remove the cover and look for loose screws or vibrating parts and check to see if the rubber compressor mounts have hardened so that they no longer absorb the unit’s movement. If they have, replace them.
2) Wiggle the fan to see if it is loose on its shaft. If it is, tighten the mounting fasteners. Lubricate the motor’s bearings if suggested by your owner’s manual.
3) If it still makes noise, call an appliance repairperson or take the unit into an appliance-repair shop.
How to fix noisy fan?
Hello friend, that's a great question!
It was best be recommend to take your appliance to a professional some of these intricate parts do require precision and patience. Therefore when replacing the exchange of electrical components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Matt
Sep 14, 2014 | Frigidaire FAD704TDB
Noisy when opporating
depends on what is cause of noise, if a fan, something in it, or could be a bearing worn
Aug 08, 2014 | Winix 50 Pint Dehumidifier WDH851
Why is a bhd501-d dehumidifier very noisy?. can you give me any ideas on fixing this?
Try pulling the grill off and see if the fan blade is rubbing on something. Check if anything else is loose while you have the cover off..
Jun 05, 2014 | Comfort-Aire BHD-301 Dehumidifier
Fan not working, outlet is live, product is 6 mos old, located in an indoor swimming pool (endless swim machine) Hi E Dry 100,
If the fan does not operate with the fan switch set "on", there is a problem with the power supply, internal wiring, or the fan itself.
First make sure the dehumidifier is plugged in to a working outlet.
Next unplug the dehumidifier and remove the cabinet cover. Check the internal wiring for loose connections.
Next remove the fan and check that it is able to spin freely (by hand). If it spins freely, it should be replaced. Call the manufacturer at 1-800-533-7533 for parts and instructions.
Feb 22, 2011 | Therma-Stor Hi-E Dry 100 Dehumidifier
The dehumidifier is making a loud noise. The noise gets louder when the fan speed is increased. What is the problem?
your fan is possibly hitting something didyou drop it or bang into it you should have some one like a tech. to checkit out and PLease stop using it till you do this you could be damaging this unit even more than it allready is
Aug 19, 2010 | Maytag M7DH65B2A Dehumidifier
My Haier dehumidifier is really noisy. If we turn it off and restart it, it will run quietly for maybe 4 minutes and then start getting really noisy again. Any ideas what is causing it and what I can do...
Take care.
Aug 14, 2010 | Haier Dehumidifiers
I HAVE 4 EA NEW LHD659EBK DEHUMIDIFIER and they make lots of noise and vibrate a bit, this is normal in these Dehumidifiers ..
These can be noisy.
Does the noise only happen when the compressor runs? These compressors float on rubber bushings to isolate the vibrations and maybe one of the three nuts on the mounting studs may be loose.
The fan bearings can also wear out.
Nov 21, 2009 | LG LHD45EL Dehumidifier
MY unit has become increasing noisy and the fan is the mane cause. The fan is now making different noises at differing levels high and low of loudness, and it often quits running all togetger. It is also...
It sounds like the bearings in the motor are worn out, especially as you said it quits running at times. You should be safe in just replacing the fan motor, but check the fan blade to make sure it isn't out of balance for any reason(dirty, missing a balance weight, or bent). Hope I was of assistence!
Nov 14, 2009 | Kenmore 53701 Dehumidifier
Goldstar Dehumidifier model# DH305Y7
Unfortunately this is quite common for most DH's of this type. The only one that I have found that does not have a reputation for losing the fan or compressor after a year or two is the Whirlpool.
May 27, 2008 | LG DH30 GoldStar Dehumidifier
Dehumidifier
same problem; any assistance is appreciated.
thanks
May 07, 2007 | Whirlpool AD40DSL Dehumidifier
Maytag M7DH65B2A Dehumidifier Logo
364 people viewed this question
Top Maytag Dehumidifiers Experts
Bill Long
Steve
Mike Squire
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
