LC45D40U Sharp I am re-asking this question since I mis-stated the symptom. This TV has flickering scan lines on the upper half of the screen. Otherwise the picture and sound are normal. I also noticed on the mail board there are 2 red led's 1 is solid red and the other is flashing red. Normal?? I was thinking that the T-Con board is the culprit for this Scan line issue.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Yes you are absolutely right it is either the T-con board in the unit has gone bad and/or it is not getting the required 12vdc from the power supply unit. If you have knowledge of internal circuitry of the unit then you can open the back of the unit and check the T-con board which is the last board before the LCD panel. Usually it is available with the LCD Panel. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 31, 2010
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
What is causing vertical colored lines on the left 25% of my Sharp Aquos display?
Bad TCON board or Damaged screen. You can try and replace the TCON "Timing Control Board" and see if that helps. Replacing the Screen itself is very expensive and normally about half of what the unit cost new. Here is a video to give you a clue on how to do so, it is pretty easy when you know which board to replace.
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
Jan 01, 2015 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
MY SHARP AQUOS 70" tv STARTED HAVING DARK SHADOWS ACROS 1/2 OF THE SCREEN, THE OTHER HALF OF THE SCREEN IS FINE. DO I HAVE A hdmi INPUT PROBLEM OR IS THERE A TV DEFECT?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Nov 15, 2014 | Sharp Aquos Televison & Video
I have sharp flat screen tv the tv want turn on and the opc light blinks one and the power blinks one time together what to do
- Flickering screen
- Dim screen
- Slow start
Apr 13, 2014 | Sharp Televison & Video
Black cloud like fogged on Sharp Aquos 37"tv
- Flickering screen
- Dim screen
- Slow start
Apr 13, 2014 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Luxor lux0140001B/01 1 week old picture has top half with a grey see through screen
- Flickering screen
- Dim screen
- Slow start
Apr 12, 2014 | Televison & Video
I have several lines on the top of the screen
- Flickering screen
- Dim screen
- Slow start
Apr 05, 2014 | Sharp LC-60LE550U Aquos 60" Class 1080p...
I replaced the T-con board in my LN46A650 LCD TV and still having the same problem, what else could it be? The capacitors are in good condition.
What is the issue with the TV? A defective T-Con board symptoms are half screen image and strange colors. Often lines in the screen are not the T-Con, but a bad LCD panel. A good supplier of Samsung parts is Tri-State Module. You can ask their technicians for advice as well. Good luck.
Nov 04, 2013 | Samsung LN46A650 46 in. LCD HDTV
I have an lc45d40u and i have no pic and or led light on its black i do have power but don't know where to look thanks for all help
Tv only have LED power light indication is on and but have totally black screen?Yes.This problems are alway the causes of the tv Tuner signal board it is shorted and dead.That the board,where the incomming signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Feb 25, 2011 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
SONY KV-27FV310: UPPER HALF OF SCREEN IS BLACK
You have a vert sweep problem and unless you know how to trouble shoot this cuircit bring it to a pro. I found out mostly in these sets that the vert output IC is bad.. Also sometimes the b+ filter cap off the fly is leaky and made the IC to fail. Another thing is Im surprised to hear you got a pic with the vert failure and a bright line in the pic!! This could be a big problem when the sets fixed so dont run it too long like this. It could burn a line all the way across the screen and you will see a dark faint line in your pic because of this. BE CAREFULL!!
Mar 25, 2006 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
