Question about Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU
Led 11 on the back of the circuit board is on?
LG 47LN5400-UA LED picture has gone out. Audio works. Using flashlight I can see faint menu image. LED Driver or LED Strips? How can I tell?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board..
Dec 23, 2016 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
LED TV screen has flickered momentarily and faded to black. I have sound and power buttons light up. LED solid black, not lit. Bad LED Driver board?
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jul 16, 2016 | LG Electronics 55LE5400 55LE5400 55 LEDLCD...
Vizio e550i-b2 no led backlight
May 03, 2016 | Vizio E550i-B2 55" LED TV 1920x1080, 120...
Hi....I have a Samsung tv made on 11-11-13, model number un32f6300af,s/n z6q93cfdb00878f. The back light has gone out.
Mar 29, 2016 | Samsung Televison & Video
LG 47LN5200 no picture led blinks then shuts down
Mar 08, 2016 | LG Televison & Video
Babisant Jan 19, 11:22 Hello , i have a Samsung Plasmaand her problem is , has sound but not picture. Can you tell me what can be the cause of the problem.
Jan 19, 2016 | Samsung Televison & Video
I have a LG LED television that has no picture but does have sound. I have narrowed the problem down to 3 circuit boards. I'm trying to find out which one is faulty.
www.electro-medical.blogspot.com
also check the video
Oct 09, 2015 | LG 47" 5700 Series LED HDTV - 47LN5700
I have a panasonic tv, TH-21FAB when I open no picture but I can hear the sounds and the channel only 11 and 13.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Jul 30, 2015 | Panasonic Televison & Video
Error code 11 flashes shown on the power LED
HI:
Sorry for your luck. If you just bought it I would definitely return it. Here are the codes for your set.
12G Models :
X24 / C2 / U2 / S2 / G20 / G25 / VT20 / VT25
Code:
BLINKS PROBLEM CHECK POINT
2 blinks 15v SOS D-Board / P-Board
3 blinks 3.3v SOS D-Board
4 blinks Power SOS P-Board
5 blinks 5v SOS D-Board
6 blinks Driver SOS 1 SC-Board / D-SC FPC
SC Energy Recovery Circuit
D-SC FPC DET
7 blinks Driver SOS 2 SU-Board / SD-Board
SU/SD Connector DET
SU/SD Scan and Logic IC
8 blinks Driver SOS 3 SS-Board / SS2-Board
SS FPC Detect
SS Energy Recovery Circuit
9 blinks Discharge Control SOS D-Board
10 blinks Sub 5V SOS / Sub 3.3v SOS A-Board / SC-Board / SS-Board / P-Board
Sub 9V SOS / Tuner Power SOS
MIHO 3.3 SOS / LED 8v SOS
11 blinks Fan SOS A-Board / Fan
12 blinks Sound SOS A-Board / Speaker
Good luck
Apr 20, 2011 | Televison & Video
Bought in Dubai 3 years ago Pan.Viera LCD 32"\r\nStandby light flashing red/green. Have to switch on with on/off button after a few minutes switches off itself..........then back on itself
Power LED Blinking timing chart
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
blinking
1 dg board, (stv 5v sense time out)
2 d board
3 d board
4 p board
5 d board
6 su sd sc boards
7 su sd sc boards
8 ss board
9 panel config
10 digi board-
11 pb board
12 h board
13 dg board
Tom Miller
Broadcast Eng
Mar 04, 2011 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU Logo
101 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
