Question about Samsung SyncMaster 173P 17" LCD Monitor
Does this LCD come with a separate power plug? Will it play just by just connecting it to my laptop?
  • 35 Answers
No, need a power plug.
Posted on Jul 31, 2010
Why after replacing the LCD in my laptop, the computer will not power up?
Replacing LCD is a big job, try to dissasemble your laptop again and check ALL CONNECTIONS are they plugged in and secured properly. If it is not static damage to the main board (worst case scenario, but it could be anything else), I would concentrate on connections first.
Sep 16, 2014 | Compaq Presario F700 F500 Series Laptops
Tip
Acer AL2216W DVI not working after connecting to a laptop
I have had an issue on 3 separate occasions where 3 separate Acer monitors would give me a no signal error after being plugged into a laptop. I have found that taking them apart, and then unplugging the main power line from the power supply to the mainboard seems to correct this issue. It may be some kind of power spike that causes this. I am not really sure though. just thought I would post something about it since I couldn't find any posts about the same issue but it has happened to me 3 times. Figured someone out there might find this helpful.
on Jan 17, 2011 | Acer AL2216W LCD Monitor
Tip
How to Hook Up a Laptop to a LCD TV by an adapter?
First of all check out does both the lcd tv and laptop both have adapter input socket This is the most important step, as it will allow you to buy the right equipment. In the unlikely event that your LCD TV lacks any of the inputs above, purchase an adapter that takes one of the aforementioned output signals and converts it to a component video or composite video input that your TV will accept. Composite video is the most basic connection and is a simple yellow jack, much like you'd use to connect a DVD player. Component video is three separate plugs: a red, a blue and a green. Both methods require separate audio connection. Turn on your devices. Once you've made the connections, turn devices on. Switch your TV to the input mode that corresponds with the input you used to connect your laptop, and you should now view your laptop on your LCD TV. This will help.Good luck.
on Mar 08, 2010 | Computers & Internet
Advent 4211 screen to base connection problem
Video Cable
The Video Cable connects to the motherboard.
It then runs along under the Left Hinge, and connects to the back of LCD screen.
{LED backlighting. Does not use a screen Inverter]
Due to just normal opening, and closing of the laptop; the Video Cable may be pinched.
This can cause the connection of the Video Cable TO motherboard, to be loose; and/or LCD screen.
Solution is to partially disassemble the laptop, and PHYSICALLY make sure the connection at motherboard is tight.
Visual inspection will NOT do.
Connection at back of LCD screen needs to be Physically checked also. (Try to plug in tighter)
Also visually inspect the sheath of the Video Cable, for apparent signs of damage.
Any signs of damage to the sheath, may mean damage to the tiny wires inside the Video Cable.
(Stretched/Broken)
Also due to the age of the laptop, suspect cracking of the insulation, of the wires inside the Video Cable.
If you have a multimeter, set it to OHM's (1K), and check continuity of every wire in the Video Cable.
Or take it to a small computer store, and have the resident tech check it.
The Advent 4211 is just a rebadged MSI Wind U100, according to my findings,
Disassembly guide,
http://www.bit-tech.net/hardware/laptops/2008/07/05/breaking-wind/1
That's the problem, the Video Cable,
http://microdream.co.uk/advent-4211-c-lcd-screen-cable-k19-3030019-h58.html
[ In the photo, the large connector at bottom plugs into the LCD screen.
The smaller connector at the upper right plugs into the motherboard.
The separate black wire you see with the eyelet on it, is a Ground wire ]
For additional questions please post in a Comment
Regards,
joecoolvette
Dec 14, 2012 | Advent 4211c Notebook
To connect with lcd with hdmi
Looks like your laptop has a HDMI port. Simply connect to LCD (HDMI if supported) port and make sure LCD is set to correct input (HDMI). It should be plug and play, but try connecting and then powering laptop, then LCD, then choosing input port on LCD.
Sep 30, 2012 | Lenovo IdeaPad Z560 Notebook
!!!no reaction on plugging the ac adaptor.!!!
Sound like the LCD screen's inverter is causing an short/overload and the power adapter is shutting down (thermal cutout).
Remove the LCD screen and connect an external monitor, power up the external monitor first and the boot up the laptop. The video should automatically on the external monitor. If the display on the external monitor is OK then the fault could be the inverter which is located at the bottom of the LCD screen between the hinges.
LCD screens and Inverters for your laptop maybe available from this WEB site.www.lcdparts.net
Apr 13, 2012 | Toshiba satellite c660
How do i connect aspire 5810t vista home pre 64b laptop to samsung lcd hdtv via hdmi
As long as you have an HDMI port on each hardware, just insert the HDMI cable into the ports and it should work fine.
Hope this helps
Mar 23, 2011 | Acer Aspire AS5530-5824 Laptop
Hp 6735s when power on not display
next time please, give clear description about the problem,
according to my understand, your display not work but all other things work, (switch on,CD drivers,Keyboard indicating lights so on...)
if it is try this...
connect a separate monitor to your laptop, that port has behind your laptop. then you can get a display on it, check your laptop LCD display, or its connected cable which it is in side the laptop, if you do not a profession about hardware do not do it.
Feb 11, 2010 | HP Computers & Internet
Power connection on back of laptop is loose, wont power up. Is this connector part of the motherboard or is it a separate piece ?
hi!
the power plug is on the main board
strip the laptop and re-solder the power plug quick and easy
regards craig
Jan 10, 2009 | HP Compaq Evo n610c Notebook
Having prob connecting my laptop to a TV via hdmi
try playing around a bit with the display settings, there are not many laptops that are setup to automatically adjust to the dual screen setup with an lcd tv. Also, iv found that Not using the lcd as a duplicate of the main screen is a good idea, set it up as a separate screen...if you know what i mean, if you do it right you will see only yourbackground on the tv and no start menu bar or icons.... In this configuration you can set the resolution to the max for the best quality possible for your television.
Nov 25, 2008 | Computers & Internet
Samsung SyncMaster 173P 17" LCD Monitor Logo
55 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
