Question about Samsung DV218AG Gas Dryer
Samsung dryer not firing. I have checked the vent and it looks to be clean. i even took the vent off the back of the drier and ran it for a few min in sensor more and dry mode and no fire. Any ideas?
  • saba_n23 Aug 01, 2010
    my expert has been great so far, but I havent been able to reach him today and I would really like to complete the diagnosis today. I am hoping someone can answer my question on the bottom on how to make the dryer run when its taken apart.
  • 10,865 Answers
Definitely get your vacuum cleaner hose and a brush into the area of the pilot light and the thermocouple as a little dust in this area is the most common cause of your problem. J.
Posted on Aug 01, 2010
    President:
  • 1,554 Answers
You should check igniter first when the dryer is started. It should glow red hot to ignite the gas. The issue is with the gas valve coils if the igniter glows red hot but no gas is ignited; replace both coils. On the other hand if the igniter fails to glow red hot, check the continuity of the thermal fuse and/or cycling thermostat on the blower housing and the high-limit thermostat on the burner assembly. You can bypass all of them then start the dryer. The burner should fire up then stop the dryer and un-bypass each of them one a time then restart the dryer. In this manner, you will be able to find the culprit. Replace it and the dryer should start firing up and working properly. Do not use the dryer with the previously mentioned components permanently bypassed to avoid fire hazards.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You can continue communicating with the expert as long as you need assistance regarding the issue stated
Posted on Jul 31, 2010
  • 23 more comments
  • saba_n23 Jul 31, 2010
    Thank you for the response. do you have some images on where these items are and some instructions on how to do these steps. or a phone number that you can walk me through the steps.
    thx
    saba
  • Jahn27
    Jahn27 Jul 31, 2010
    Remove the top cover by removing the screws attaching it to the dryer back. Slide the top cover towards the rear and lift from unit.
    Remove the screws mounting the Heater PCB Board and disconnect the connectors then remove the screws attaching Console to dryer. Rotate the console down and remove it from dryer.
    Remove the screws attaching the front panel to the dryer cabinet. Remove the screws in the door area then pull the front panel forward and disconnect the interior light harness. Lift the front panel off the three tabs across the bottom and remove.
    You now have access to the parts mentioned in the previous post. Reassemble the dryer in reverse order of the dissasembly procedures.
    thank you for the pics and instructions.. one more question...
    you said
    "On the other hand if the igniter fails to glow red hot, check the continuity of the thermal fuse and/or cycling thermostat on the blower housing and the high-limit thermostat on the burner assembly. You can bypass all of them then start the dryer. " how do i do that? do i just unplug them?
    thx
  • Jahn27
    Jahn27 Jul 31, 2010
    Simply disconnect the wires connected to the terminals and connect them or connect a jumper wire between the terminals. But never bypass the gas valve coils.
    so i have taken the top and front cover off. the control unit is still attached to the dryer. I am ready to go through your first check to see if the ignitor glows red or not. But when i plugged the dryer in and tried to started, it does not start. it just says do and nothing turns. do i need to bypass something to get it to run?
  • Jahn27
    Jahn27 Aug 01, 2010
    My apologies for the delayed response due to time zone constraints. The dryer says "do" because the door is off and the door switch is not activated. Simply bypass the door switch and you are good to go. The dryer will start and you'll be able to do the first check.
  • saba_n23 Aug 02, 2010
    Yes, i figured i need to bypass the door issue.. i dont know how. can you please provide some direction.
    thank you
  • Jahn27
    Jahn27 Aug 02, 2010
    Simply jump a wire between the wires connected to the door switch or disconnect the door switch harness and connect the wires.
    its a 3 prong connector that i think manages the door and the light or maybe just the door. which ones do i use to jump the door connection. dont see a way to disconnect it.
    the 3 prong connector has a purple wire on top, blue and yellow in middle and white on bottom.
    ok, figured out a way to get it run. the ignitor is not turning red after about a min. moving to next item on your list.
    ok, so i disconnected one of the thermal fuse and/or cycling thermostat. i am not sure which one. but the one that has a plastic housing and is further back inside the dryer. I took a wire and connected between the blue and red wire. i started the dryer and it runs for a few seconds and then gives me an error on the screen. what am i doing wrong?
  • Jahn27
    Jahn27 Aug 02, 2010
    You have shorted the thermistor and the error appeared because the control detected very low thermistor resistance.
    but i did what you asked me to do. what am i supposed to do now? did i break the thremostat? Please provide a solution in the response rather than just identifying the problem. if i was an electrician or a appliance technician, i wouldnt be on this site asking for questions. It will lessen the email chain.
    thank you.
  • Jahn27
    Jahn27 Aug 02, 2010
    Don't worry, you didn't break anything. Did the dryer fired up prior to the flashing of the code?
    yes it did. i tried it twice. and it ran twice and then gave the error. So what do i do now? how do i bypass it to test the thermostat.
  • Jahn27
    Jahn27 Aug 02, 2010
    Instead of the thermistor, bypass the other part on the blower housing if the dryer does not fire up prior to the flashing of the code after the thermistor is shorted, that part is the thermal fuse.
  • Jahn27
    Jahn27 Aug 02, 2010
    Then replace that part you shorted including the other one on the blower housing.
    i put the thermistor back and removed the fuse. I bypassed the fuse by using a jumper wire between the two leads. the dryer started but the ignitor does not turn red. Do i understand you correctly that the problem is now with the termistor and the fuse. and that I need to replace both of them?
    thank you
    can you recommend where I can get the parts? Is there a website I can use?
  • Jahn27
    Jahn27 Aug 02, 2010
    The problem can be either of the thermistor and the thermal fuse or cycling thermostat depending on the model of your dryer but both of them must be replaced since the failure of one is the result of the failure of the other. The parts can be purchased here if your dryer is DV218AG, indicate it otherwise. The parts are item 2-3 and 2-4 in the diagram and part numbers DC32-00007A and DC47-00016A respectively.
    thank you for the detailed reply. I have the parts ordered. stay tuned. hopefully i did everything right.
    thx
  • Jahn27
    Jahn27 Aug 02, 2010
    You're welcome. Feel free to update us about the development of the troubleshooting and repair.
    DC32-00007A part seems to be out of stock every where. any ideas on where i can get it?
  • Jahn27
    Jahn27 Aug 02, 2010
    It seems available here.
Samsung Dryer with a "TO" error code. vents are clear.
Samsung service manuals do not indicate a TO are you sure check my files: samsung https://drive.google.com/drive/search?q=samsung%20dryer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 30, 2017 | Samsung DV448AEE Electric Dryer
My dryer is taking three cycles to dry clothes and its only 2 yrs old. Air flow looks good and lint has been cleaned out. Any suggestions?
Yes, check the hose behind the machine. Pull the drier out away from the wall pull the vent hose off and make sure it is clear, then look at the connection on the back of the drier and the vent at the wall, go outside and look at it for birds nest or kids putting tennis balls in it.
Oct 18, 2010 | Whirlpool Dryers
Dryer takes hours to dry a load. I must run it through several cycles. Not much air coming out of outside vent so repairman suggested it be cleaned out. My husband completely removed it and found no...
My only thought is to look at the back of the drier. Check the hose coming out the back to the out side vent, and then run the drier with out the hose for a few moments. See if you have air moving then, if you have no air moving with out the hose attached. Your driers fan blades are ether clogged with lint or they have broken off some how.
Aug 22, 2010 | Electrolux EIGD55H Dryer
After 70 mins. of drying time my clothes still need another 30 mins. i cleaned my lint trap all the way to the back of dryer any help
Make sure your vent tube(from drier to outside)is clear,also check to make sure outside vent door is opening while unit is in operation.
Jan 19, 2010 | Whirlpool Dryers
Estate dryer kicks off circuit
you can check where the cord is connected to the drier did you use the cord off your old drier see if the cord is tight at the back of the drier and the center terminal of the cord should be on the center of the terminal block and why did you buy a new drier hold my rating till were done please
Jan 30, 2008 | Estate TEDX640JQ Electric Dryer
Dryer heats up but isn't drying properly
yes it does something is blocking your vent either its all coiled up behind the drier or something i need to ask a few questions go out side and look at where your drier vent has a hood make sure nothing is blocking it from opening it has a little round door on it ive seen some that have little plastic screens on them that gets clogged the screen is there to keep critters from building nests in the vent line then get a flash light and look over the back to see if the vents folded over mashed etc to find out if its a vent problem take your vent loose dry a load and see if it goes back to normal if all that's ok get back to me and we will clean the drier i need to know if your lint screen is on top or in door and your model #
Jan 02, 2008 | Dryers
Kenmore 80 series dryer...takes twice as long as it should to dry
no about all the time this kind of problem is caused by some kind of vent restriction start by looking over th back of the drier with a flash light and see if the vent is mashed folded over on its self or too long you only need enough to hook to the connector to the floor then go to the out side with the drier running and check to see if the drier hood attached to the house is opening i some have a plastic screen attached to the hood to keep critters out make sure that's clear rule is must have a 4" opening from drier to out side hood cant hang down under house and come back up as dryer will fill it with water over a peorid of time now easy way to verify vent restiction is to disconect vent run 1 load and see if it dries in proper time about 60 min
Dec 31, 2007 | Kenmore 659 Electric Dryer
Bosch WTL5400 Condensation Dryer
We continuously had a similar problem with signals forever coming on after just a few dryer loads. The problem was corrected when we took the back off of the dryer and cleaned the recirculating fan and removed a rubber glove that somehow came through the system and blocked the air flow at the heating element. Low air flow is the same as plugged filter and apparently the computer in our German-made Bosch dryer simply says that. We cleaned the area well, removed all traces of the glove and restored the dryer to operation. We have not had the filter problem since. We routinely clean the heater area at the back of the dryer to maintain our sanity. And we now dry our clothes. Bosch never responded to my query.
Dec 28, 2007 | Bosch Axxis WTL 5410 Electric Dryer
This dryer STINKS
most of the time this problem is caused by a vent restiction or mashed vent behind the drier what i tell my customers is to run 4' pvc plastic pipe from the outside hood under the house then use a90 degree elbow to come up through the floor and a small piece of metal flex vent and clamp for the final connection you'll never have a vent problem again i know how you feel and im not saying your not right just giving tech advice so you don't have same promb with new drier im a real svc tech and im concerned with you also call lgs cust relations people not cust service cust relations be nice say you didn't think lg was like this and you don't know if you just got a bad drier or what tell the whole story fire and all don't mention pile up of lint they want you happy with there products and most of the time will help some times even give you a new drier you got nothing to lose by trying all appliance mfg are afraid of the fire word worth a try do it right might get a new drier but do your vent before inst any time it takes more than an hour to dry clothes ita a washer promblem clothes too wet or a vent promblem sorry for you promblem just trying to help
Nov 29, 2007 | LG DLE2532W Electric Dryer
Samsung DV218AG Gas Dryer Logo
246 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
