Question about Panasonic VIERA TH-65PV500 65 in. Plasma Television
Will not turn on.
While watching TV all of a sudden the set turn off. Will not come back on and the front LED never lights up.
our tv jst shut down and blew fuse at wall.changed fuse and it blew this one as well 2years old.how much do u think to fix/or not worth it?
  • 2,334 Answers
If the TV is blowing the fuse in your house, It looks like a component in the power supply is shorted.
To fix the TV, you will need to buy a new power supply module or get the one inside the TV fixed.
Good Luck.
Posted on Apr 24, 2008
  • Cherylanne Loop Dec 05, 2013
    In applying your answer to my issue I wanted to elaborate. It appears that it is my "microwave" that is in fact the culprit because the tv works fine until I use the microwave and it blows a circuit (fuse) in the house. When I flip the fuse box the microwave will operate again just fine but the TV doesn't reset or reboot easily. am I possible using the wrong volt on the power strip?
  • Jaime Hernandez Dec 07, 2013
    i would suggest to connect the microwave and the plasma to different outlets. That should work.
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
Had a power outage while watching tv. Then 3 blinking lights.
This is an on-going problem with DLP sets. Normally you shut the set off and the cooling fan cools the lamp down and then it shuts off. In your case, of which it's not your fault, however your lamp has taken a major hit by not properly cooling down, in turn, you need to replace your lamp at this time.
I suggest in the future if you have an electrical storm and a chance of a power outage while your watching tv, I would'nt play that model or any other model of a DLP set.
Jun 23, 2009 | Samsung HL-S5087W DLP TV
TV SHUT OFF WHILE WATCHING. UNPLUG AND THEN PLUGED BACK IN. RED LIGHT CAME ON IN FRONT FOR A SECOND AND WENT BACK OFF. TV WILL NOT COME ON.
power in the tv has nothing related with the DVD. The tv has to have raster (white screen) even without signal (cable, DVD, others) if the tv alone is just having the led flashing and neither sound nor video (black screen) The tv has a short circuit in some of the boards that are part of the tv system. the blinking is part of a protection when the tv was created in the factory. Refer to the technician to repair this problem.
Apr 14, 2009 | Hitachi 61SBX59B 61" Rear Projection...
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Standby LED flashes red 4 times with pause then 4 times
You either have a bad fan or one of the rotation sensors mounted on one of the fans has failed. Take the back off the set and see it the main fan slightly right of center is rotating. If it is, there are two more fans, one mounted right above the lamp and another on the optical block itself. You will have to pull the optical block to check those.
Oct 25, 2008 | Sony KDF-E42A10 42 in. LCD Television
Panasonic projection tv (shuts down)
Does the power indicator blink? Let me know and I will try to help you out. Just keep responding to this same psot so previous info will still be available.
Jun 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Hitachi 61UWX10B 61 in | TV will not turn on
If your set all of a sudden won't come on, e.g., the screen is blank, but the LED on the under the screen next to the on/off switch keeps flashing, then there may be an internal fault on the set that needs to be reset.
To force the reset, try this:
  • Unplug the set and wait a few seconds
  • Replug and see if the video returns
Whenever the set senses an internal fault through its monitoring circuitry, it essentially shuts down the set. The flashing LED provides the indication that a fault has been detected. Removing power to the set resets the monitoring circuitry. When plugged back in, the circuitry again does a check of the system1.gif. If it finds that there truly is a problem, then the set is shut down and the LED will again flash.
Jan 30, 2008 | Hitachi 61UWX10B 61" Rear Projection...
Shuts down after power up 50ux53k bought new 1998
Refer to owners manual will tell you what blinking light means. But at the front not at the back.
Dec 16, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Panasonic VIERA TH-65PV500 65 in. Plasma Television Logo
266 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
