Question about Dometic RM2852 Refrigerator
Freezer was working, but refrigerator isn't
Freezer was working, but refregerator isn't working. the brand is a Domestic RM2852
    Problem Solver:
  • 11 Answers
Sounds like the defrost timer !!!!!!
Posted on Jul 31, 2010
REFREGERATOR NOT COOLING
You have a ice obstruction,or fan in freezer may not be moving air to fresh food part of fridge, or the defrost heater may not be working.try YouTube
Dec 22, 2017 | Refrigerators
I have a domestic rm2852 and the freezer freezes but the refrigerator part is warm. I can't get it below 50*
Inside the fridge is a dial to adjust the freezer and fridge temps make sure that is set lower. Also check to make sure the fan in the freezer behind back panel is working, and the vents are not blocked. The video should help with that part.
Jul 05, 2017 | Refrigerators
I've had the refregerator for 10 months.. All of a sudden water is appearing on the floor next to the refrigerator. Where could it be leaking from?
Pull it forward and seei if the drain pan is either overflowing or empty. If it,s empty, check the drain isn't blocked, causing meltwater to leak from inside. If it's overflowing, check the door seals properly and the defrost settings are ok.
May 22, 2012 | Samsung RFG297HDRS 29.0 CuFt French Door...
We have a Domestic Model RM2852 refrigeratro in camper with auto factory preset thermostat. but it freezes the food. What can we do to set temp. down. Product # 921 1460-57. Serial # 319 05815 Thank...
you have 2 choices #1 is replace the thermostat.#2 is check for air leaks around the door seals,if leaking air,compresor will run on overtime...trying to cool the air inside.
Aug 14, 2010 | Dometic RM2852 Refrigerator
Top refregerator not working
look for ice in back wall of freezer . this is a no frost and that means no frost .. you may have a defrost system failure .. mm
Jul 04, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Ref/freezer quit working. looks like somekind of liquid in back leaked out.. fuses ok.is this repairable? motorhome Domestic RM2852
motorhome refrigerators are a different system entirely than residential style refrigerators. I would do a search for dometic, not domestic, refrigerator repair
Feb 07, 2010 | Dometic RM2852 Refrigerator
Freezer works fridge doesnt?
most likely defrost problem . most refrigerators getting their cold air from the freezer, so if your frezzer frost up, no air gets to fridge side, u have to remove the frezzer panel and inspect the evaporator coil, if frosty, u have bad defrost system, which part is bad? depends on the brand and model.
Oct 31, 2009 | Dometic RM2852 Refrigerator
Bottom Freezer
This is the way it is supposed to work. Modern refregerators are designed to keep the freezer temp between 0 - 10 degrees. As long as it is not freezing food in the refrigerator compartment all is well. On most units the only real cooling control is in the refregerator. This is the one the cycles the compressor. The freezer control usually only controls the amount of cold air allowed into the fridge. All cooling coils are usually in the freezer. it just pushes cold air into the fridge
Jul 04, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Refregerator
if your sure its not working ,you have to remove the cover in the freezer on the back wall and it requires a volt meter to make sure its not working.
Jun 13, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Dometic RM2852 Refrigerator Logo
243 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
