Question about Dell (E210882) Motherboard
What if the computer doesnt have DVD/CD or floppy device. missing
    Brigadier General:
  • 10,406 Answers
Any Dell motherboard has connectors so that both a 3.5" diskette-drive, and a EIDE/SATA CD/DVD drive can be connected.
Posted on Jul 31, 2010
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
first check the boot drives to make sure that the computer is not trying to boot from a different drive to the one that contains Windows.
check that there are no CDs or DVDs 3 1/2 inch floppy discs
in the CD/DVD,3.1/2 floppy drives ,and no removable usb drives plugged in to the usb ports
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
don
Feb 23, 2011 | ASUS DVD- E616P3 QUIETRACK, SILVER,...
When I started my computer it stated that my NTLDR was missing,how can I recover it ??
First, check the boot drives to make sure that the computer is not trying to boot from a different drive to the one that contains Windows.
Check that there are no CDs or DVDs 3 1/2 inch floppy in the CD/DVD drives.your you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
test or replace leads that are attached to your
((motherboard to the hard drive))
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 09, 2011 | Computers & Internet
My pc doesnt detect my HL-DT-ST-DVD-RAM-GSA-H55N LG super multi dvd/cd-rom, i tried checking ide cables but still it doesnt read, i cant even see the dvd/cd-rom on device manager------there is no...
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Oct 31, 2010 | LG GSA-H55N DVD-RAM Burner
Hi, My computer doesnt recognize the cd\dvd drive....
Hello there!
You won't probably be able to find drives because Sony, the makers of Optiarc, rely on Windows to supply the drivers.
You can right click the devices and remove them. If Windows asks, check the box to removed files as well.
Then reboot the computer. That may do it on it's own.
If not, run Windows update, and make sure to check the section about optional updates.
Aug 04, 2017 | Computers & Internet
4600c not operating system error message bootmanager missing
You might have to go to the BIOS of your computer to ensure your drive is recognised. Once it shows there, make sure you change the Drive as your first boot device.
Thanks
Ranjit www.supportminds.com
Aug 14, 2009 | Dell Computers & Internet
''BOOTMGR is missing'' I can't boot from Windows XP CD
Open cpu cabinet and Refix RAM some times bootable files not load on ram properly so this error comes.
So refix RAM memory clean dust from circuit and RAM .
Also pull cmos cell from motherbord for 5 minutes so all settings are defaults then check.
Aug 01, 2009 | Computers & Internet
I con not setup win xp on the hard without floppy disk
Start your computer. Enter BIOS SETUP. Select "Boot Order". Configure to make the CD/DVD the *FIRST* boot-device. Put the Windows CD/DVD into the drive. Save/Exit from BIOS SETUP. Your computer will restart, and will "boot" from the Windows disk in CD/DVD drive.
Jun 08, 2009 | ASUS P4S800D-X Motherboard
Missing NTDRL
best thing to do is take out ur hard disk n copy the ntldr file from other workin system.
 u can find this ntldr in c:\. to see it go to folder option-- view-- check show all hidden files and uncheck hide protected oprating system files. in c;| u ll find ntldr. copy it in ur hard disk n boot.. it ll work...
Mar 18, 2009 | Compaq Computers & Internet
Thinkpad R51 CD/DVD Driver missing
Download "DRIVER MAX" it will automaticlly find devices, and find the drivers for them, then you choose what to update. And best of all it's free.
Feb 24, 2009 | IBM ThinkPad R51 Notebook
Dell (E210882) Motherboard Logo
37 people viewed this question
Alun Cox
