Question about Fisher and Paykel Washing Machines
I HAVE A GWLO8 WASHER ..DRAIN MOTOR SHORTED OUT ,BLEW FUSE . PUT IN NEW DRAIN MOTOR NOW WHEN I PLUG IN THE WASHER THE DRAIN MOTOR WILL NOT STOP RUNNING UNLESS I PULL THE PLUG. ALL THE PANEL LIGHTS RESPOND ,THE REG WASH MODE SEEMS TO BE TRYING TO WORK ,ALLTHE TIME THE DRAIN MOTOR IS STILL RUNNING. THANX JOE
  • Fisher and P... Master
  • 713 Answers
Hi Joe.Unfortunately if your drain pump shorted out and when you replaced it with a new one, it keeps draining, then the fault now is your MOTOR CONTROLLER.It became faulty when your pump shorted out.This happens sometimes with the Fisher and Paykel washers.Hope this helps and if you need further assistance then please reply and I can help you replace the CONTROLLER if you decide to change it.Just a note before you go and purchase a new controller ring your local FISHER and PAYKEL dealer and ask them if they can test your CONTROLLER for you,Just to be sure.I know my diagnosis of your fault is correct but I think we must cover all our bases.Looking forward to your reply.
Posted on Aug 01, 2010
2005 ram 1500 wipr fuse keeps blowing with the motor plugged off....fuse #8
Shorted wiring in harness ? Unhook battery check resistance from fuse to ground should be open with motor unplugged and no battery hooked up.
Apr 25, 2017 | Cars & Trucks
2004 chevy aveo. my wipers stopped working in the front. i thought it was just a blown fuse. so after replacing it, it blew again. so then maybe i thought the motor. so after replacing the wiper motor it...
Looking at a wiring diagram would be a good place to start . Then leaning how to test automotive electrical circuits with a DMM - digital multimeter .Plus you never put a higher amperage fuse in place of a lesser amperage fuse . This is how cars burn down to ground . You can find free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model and engine size . Under system click on body & accssories . Under subsystem click on wipers/ washers .Click the search button then the blue link .Then watch this videos
Electric Testing Techniques You Need to Know
Finding The Source Of Electrical Shorts In Your Car
Finding active short
How to Diagnose and Find Short Circuit or Wire in Your Car
Jul 31, 2017 | Chevrolet Aveo Cars & Trucks
No lights, no power, whatsoever when plugged in
hello obviously you've checked the fuse in the plug if thats ok it could have blew the fuse inside the washer it will be on the power board glass type . beware if you put another 1 in and blows again then there's a dead short someware good luck
regards
shaun
May 29, 2010 | Kenmore HE2 Plus Front Load Washer
Power outtage at my house caused my front load washer to stop working.. can this be repaired or would it be a better investment to purchase a new one?
hello it might have blew the glass fuse in side the washer it's located on the power supply board .but beware if you put another 1 in and it blows again then theres a dead short somewhere good luck
regards
shaun
May 26, 2010 | Kenmore 44102 Front Load Washer
How to find a short in my wiring harness for a 1989 honda prelude? The fuse blew and now my tach,gas gauge,clock and blinkers don't work I put a higher amp fuse in and it lasted about 5 days and blew...
at least you know were to start,key on the fuse that blew.and everything controlled by it.i'm assuming that every time you replace the fuse now,it blows .think back before the short,was there any electricial problems,or devices that didnt work.,wires are melted together,or motors are shorted out.putting a bigger fuse in probably burnt a wire open(meaning got too hot and broke)whatever blew the fuse to start with,is most likley where the meltdown is ,start unplugging the things on that fuse,one at a time,remove tail lightbulbs,inspect thre sockets,look up under the dash at the wiring ,your clock,tach.and gas gauge ,are there,observation is almost 90%of trouble shooting anything .fixing it is easy pop the hood spend some time just looking at every thing follow wires make sure they arent melted together ,and are plugged in,just unplugging something and plugging it back in will show problems,things will fall apart.clips will break and hopefully you will see something obvious,shorts are never fun,do you have any electrical background?and know how to use a multimeter .if you do reply ,
Sep 14, 2009 | 1989 Honda Prelude
1992 Jeep Cherokee climate controls just stopped working
unplug the blower motor, try that, i have seen a direct short in the blower motor cause that. also check the blower moror resistor--again another fault---hope that was helpful
Aug 05, 2009 | 1992 Jeep Cherokee Briarwood
Washer was in fill cycle and stopped
You've got a short circuit somewhere in that electrical circuit.
First, unplug the washing machine.
Replace the fuse. If it doesn't blow immediately, then there is likely a short in the washing machine, and from what you describe, it's in the motor.
If it blows, then there is something wrong in that circuit, and you can likely rule out the washing machine. Check all devices on that particular circuit, of which there can be a number of plugs.
Jan 23, 2009 | Maytag LAT3600A Top Load Washer
Fuse blew in plug
your main moter as a fault in its winding making it have a short which blows fuse
Jul 28, 2006 | Hotpoint WMA44 Front Load Washer
Washing Machines Logo
77 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
