Question about Schwinn 430 Elliptical Trainer
E2 error and no resistance
I own the Schwinn 420 elliptical and I keep getting the E2 error on the console and the resistance will not work. I've checked the wires, what else could be causing the problem?
3 Suggested Answers
SOURCE: The console does not work. E-2 shows up on the console.
We had this problem after assembly as well, it turned out to be a bent pin inside the connector to the flywheel housing (where the wires connect inside the lower part of the main mast). It was so bent that it never actually made contact with the connector.
We straightened the pin, carefully reconnected the wires, and everything worked just fine.
This says to us that the "E-2" error message means the console is missing at least one connection from the system. This could be caused by a bent pin, a torn/cut/frayed wire, etc -- anything that might make it lose signal.
So check the lower connection for bent pins, check the upper connection for bent pins, and check all along the wires for any kind of damage.
Hope this helps!
Posted on May 03, 2009
SOURCE: My Schwinn 430 Elliptical is not changing
I think I am experiencing the same problem and have removed the shrouds. Are you experiencing a clicking sound while the unit is plugged in? All of this seems to deal with the servo motor. Don't be fooled by suggestions to replace the rpm sensor...this is NOT the problem. I am trying to find out what the initial setting for the servo motor and the tension cable should be. I found a site where you can order the servo motor, but it tells me that it could be months to receive this part. Sigh...
Posted on Sep 13, 2010
On my shwinn 420 I can only get manual on program settings
If you wish to get some details About elliptical; check the site linked here. Pull up older posts.....
http://electro-medical.blogspot.com/
Jul 15, 2016 | Schwinn Fitness 420 Elliptical
My Schwinn 420 elliptical is not powering on. The breaker and outlet source are fine. When I plug the machine in nothing powers on. The console displays nothing, no lights, etc.
test the power cord plug, in another device and see if working
2) replace batteries if your system has( clean the contacts from oxide,corrosion with contacts cleaner) and try again when you have isolated the problem
God bless you
Nov 05, 2013 | Schwinn 420 Elliptical Trainer
The digital read out on my 420 elliptical schwinn system blinks on and off. There is no error code
follow this steps and replace batteries too. God bless you
Check power problems if the console on the elliptical machine does not light up. Make sure that the plug for the machine is secure in the outlet. If it is plugged in, ensure that the outlet is receiving power. Check the breaker to make sure it has not tripped off.
Be sure that you are using the correct adapter that came with the elliptical machine. Because different adapters are able to handle differing amounts of energy, the wrong adapter will not transfer electricity like it should. If the adapter is pinched or damaged, this could also alter its effectiveness.
2 Make sure the correct adapter is being used if the resistance settings seem to be too hard or too easy. If the correct adapter is being used, reset the machine. To reset the machine, either switch the "On/Off" button or unplug the machine from the wall. Doing this will allow the device to reset itself to the default resistance. Turn on or plug the device back into the wall and retry all of the levels of resistanc
Oct 01, 2013 | Schwinn 420 Elliptical Trainer
E2 code no heat
The "E2" error code indicates a shorted thermistor. The thermistor is a component that the control board monitors in order to regulate the operating temperatures. The thermistor is a component that changes its resistance value according to temperature. If the control board does recognize a certain range of resistance of the thermistor, the control board will stop the dryer and display "E2".
Feb 14, 2013 | Kenmore Dryers
E-2 message on schwin 420
You may be able to reset the main board by detaching the ribbon connector, then reattaching it. Unscrew the four screws that hold the display panel, and you will see a ribbon connector and a round connector. Gently squeeze the tab in the center of the ribbon connector and pull it off. Wait a couple of minutes, then reattach the connector by gently pushing it into the socket. The display should show a boot-up process and then the normal blank screen with the prompt to select user. If the E2 error returns, repeat the process. If this procedure does not reset the board, you will need to contact Schwinn about possibly replacing the board. You can contact them by going to Schwinn.com (http://www.schwinnfitness.com/schwinn_fitness_us/customerservice.jsp) and select the "email us" link or call the 800 number.
Jan 30, 2013 | Schwinn 420 Elliptical Trainer
Error code 1 on schwinn elliptical 420
Dear Sir:
adjust the speed sensor see the diagram attached.
2) the main board can be faulty.
3) Run the software calibration.
5_3_2012_12_02_47_am.gif sincerely. God bless you
Apr 30, 2012 | Schwinn 420 Elliptical Trainer
Eliptical is showing E2
E2 Error Code - As researched here, I found a problem with the electrical wiring to the motor, dc module (P/N 000-8453}. I checked the plug connection for bent pins and bad continuity in the circuit. Okay. What I found was bad connections at what I will call the stepper motor that is located on the module. This motor adjusts the location of the Magnet Pack Assembly in relation to the Flywheel to change workout resistance. The terminals where the wires are soldered to the motor are of a riveted type of connection. By removing the resistence adjusting cable lock nut, threaded end and the cable, I was able to cycle the pulley back into operating range by plugging in and unplugging the power cable multiple times. Each time that I would plug the power in, the pulley would rotate a couple of degrees in the clockwise direction. Then, reattaching the cable assembly, and applying pressure to the stepper motor terminals, the unit would time and orient itself properly when powered up with No Error. To remedy the problem, I applied a little solder using a soldering iron to the riveted type connections making them a Better, soldered connection. I hope this helps.
Jan 22, 2011 | Schwinn 430 Elliptical Trainer
Error code 2 on schiwnn upright bike
Console displays “E2” error code
Solution: A. Check data cable integrity. All wires in cable should be intact. If any are crimped or cut, replace cable. B. Check data cable connections/orientation. Insure cable is connected securely and oriented properly. Small latch on connector should line up and snap into place. If the above tests reveal no problems, replace the DC Motor.
• TECHNICAL/CUSTOMER SERVICE Nautilus, Inc. World Headquarters 16400 SE Nautilus Drive Vancouver, Washington, USA 98683 Phone: 800-NAUTILUS (800-628- 8458) Fax: 877-686-6466 • CORPORATE HEADQUARTERS
Apr 01, 2010 | Schwinn 430 Elliptical Trainer
Schwinn 430 Elliptical Trainer Logo
1,251 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
