Question about Danby DWC044BLP Wine Cooler
Danby dwc044blp wine cooler that will not keep a steady temperature. Some days it works fine 9cools to set temp), and other days its 71 degrees F and will not cool.
Demy
  • 20 Answers
SOURCE: danby wine cooler
Is it because your keypad not functioning, meaning does the number change when you press the arrow up or down? Or when you set it, (let's say 12 Cel.) it does not reach down to that temperature. Then it could be either it's a sealed system problem( leaking refrigerant or under charge if it's a new unit). Or it could be a control problem( electronic control or sensor)
Posted on Aug 01, 2007
  • 146 Answers
SOURCE: Three Temperature zones
Did you read the owners manual? It will be kind of hard to tell you because there are so many different settings for different areas.
Posted on Dec 26, 2007
  • 90 Answers
SOURCE: Danby DWC283BLS Wine Cooler - Error message E3 & E4
Is the compressor running? I don't know this unit, but know that if you are too warm that is the first thing to check. In reading about another unit that had a different problem, it was mentioned that there is a ciruit board. If it has relays on it then these are the most likely culprit. They are either not making contact or staying in contact too long... sometimes just tapping each relay usually a black plastic component will cause it to work intermittently..Not sure if you can get these but call the company help line at 1-800-263-2629.
Posted on Feb 16, 2008
SOURCE: how to reset the temperature on the danby silhouette wine refrigerator
This happened to me, I found that the cooler would not go below 70 degrees because the cooler had lost its coolant or wouldn't work. I do not know, but as it was under warranty, an appliance repairman came and said that it was worth fixing, so it was replaced with in a week. Normally you would just hole the button in until the desired temperature is selected. Once released the cooler would attempt to set this temperature. If it is not, then I suspect it too is broken. Good luck.
Posted on Jul 06, 2008
  • 44 Answers
SOURCE: danby wine cooler compresser not running and is hot
The compressor needs to be tested to see if it's operational. This normally needs to be done by a service tec.
Posted on Aug 21, 2009
I cannot set the temperature ... Keeps resting 75 degrees F
How long does it take to reset? What is the temp are you trying to set it to? How old is the unit? Has it always done this or just started?
Sep 02, 2013 | Danby DWC283BLS Wine Cooler
Danby dwc 044 wine cooler compressor is very hot to the touch. What could be the problem? relay?
check compressor relay..
also ok so check condenser coil heat no heat so check gas lickeg on capilary tube or" condenser lickeg or" jam capilary tube.
May 30, 2012 | Danby DWC044BLP Wine Cooler
Vinotemp wine cooler temerature won't stay on 54 degrees
If the unit is a thermoelectric unit it can be the cooling system.
If the unit is a compressor unit it will be the thermostat.
Aug 28, 2009 | VinoTemp 32 Bottle Stainless Wine Cooler
Magic Chef Dual temp. wine Cooler #MCWBC77DZC
I suspect the cooler can only actually regulate one of those temperatures and the other one just drags along behind. Perhaps the weather is now warmer and the cooler has to keep the motor on longer to keep cool. The unregulated bottom temperature ends up cooler as a consequence.
Either that or the opposite effect is doing it.
The answer might be to find a 61 degree place in your house to keep the reds.
Apr 28, 2017 | Magic Chef MCWC30MCG Compact Wine Cooler
Wine cooler doesn't cool
you need to turn the temp. setting all the way up,use a rag to hold the fan,now see if the compressor. is running,let me know-mike
Jul 11, 2008 | Danby Silhouette DWC512BL Wine Cooler
How to reset the temperature on the danby silhouette wine refrigerator
Jun 03, 2008 | Danby DWC283BLS Wine Cooler
Dec 26, 2007 | Danby DWC310BL Wine Cooler
Danby DWC044BLP Wine Cooler Logo
60 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
